Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 04-15-2003, 01:38 PM   #1
wrx2
Member#: 13852
2002 WRX vf22 SOLD
Now E46 M3 Vert
Default Questions for vf22 turbo?
Hello guys and gals
I just bought used vf22 turbo with good deal. But I don't have enough money for supporting mods(ie.injectors, fuel pump, etc).
However I'm running Vishnu stage1(aggressive map for IC hose and 3" catless all the way setup) unichip with EMI adapter.
Can my car run with this set up for a while without any problems? I know that I have to reduce boost but how much? I'm running 16.5~17 psi now. Your response would be greatly appreciated.
Here are my mods:
Godspeed uppipe
Helix downpipe
Greddy EVO cat back
IC hose with STi scoop and splitter
Pulley, colder plugs
HKS BOV
K&N filter
Unichip with EMI adapter
wrx2 is offline   Reply With Quote
Old 04-15-2003, 02:01 PM   #2
MAD REX
Member#: 18163
2002 2.5 WRX
MBP
You'll have to keep the boost down to 14-15 max.
You will also need to get your Unichip reprogrammed.
And...you will need a mbc to keep the boost down I think. If not it'll spike like mad.
MAD REX is offline   Reply With Quote
Old 04-15-2003, 03:31 PM   #3
TCENGEL
Member#: 8302
2002 WRX WRB Sold!
2006 Scion TC-T
I ran 15-16PSI on a TXS unichip for quite a while. Just make sure you have at least an EGT guage to make sure your still rich.
TCENGEL is offline   Reply With Quote
Old 04-15-2003, 03:51 PM   #4
wrx2
Member#: 13852
2002 WRX vf22 SOLD
Now E46 M3 Vert
Thanks guys for reply.
MAD REX: I think that my aggressive stage1 map is already max out for fuel delivery for stock injectors. But do I still need to remap? I don't know how much Shiv can add more fuel for stock injectors from current map
Old 04-15-2003, 05:25 PM   #5
Vishnu Performance
Vendor
Member#: 14494
WRX Porsche 996
blue & black
My suggestion is to not install the VF22 until you get larger injectors and a pump. While it is possible to wiggle another 10 wheel hp or so out of the car with the VF22 and stock injectors, it does require careful mapping on the dyno as to not induce any lean run.
Shiv
Vishnu Performance is offline   Reply With Quote
Old 04-16-2003, 02:11 AM   #6
wrx2
Member#: 13852
2002 WRX vf22 SOLD
Now E46 M3 Vert
Thanks Shiv for your suggestion.
I will get injectors and pump near future and send you my unichip to remap. But I still wanna run my vf22 right now So I'm okay if I don't go over 14.5psi or 1bar, right? Thanks.
Old 04-16-2003, 02:27 AM   #7
Vishnu Performance
Vendor
Member#: 14494
WRX Porsche 996
blue & black
Hard to say, honestly. I'd suggest against it. But if you must, make sure you aren't hearing detonation. If you don't know what it sounds like, find someone who does
shiv
Old 04-16-2003, 02:37 AM   #8
tdxflex
Member#: 13634
i definately wouldn't install it. you'll probably have to turn the boost down even lower than 14psi to be safe, and then with the added lag while not going any faster, and constant worry of messing something up, you'll wish you had your stock one back on.
tdxflex is offline   Reply With Quote
Old 04-16-2003, 04:16 AM   #9
wrx2
Member#: 13852
2002 WRX vf22 SOLD
Now E46 M3 Vert
OK, Guys
I will wait until I got injectors and pump. Can't wait
Thanks.
Old 04-16-2003, 04:43 AM   #10
Sunkist
Member#: 26387
2002 2.5 Hybrid WRX
Platinum
I know someone who was running it on a stock WRX and she had her boost down to just under 13PSI but it did still give her a nice power boost. I am running at 13PSI with my VF23 until I get injectors and a pump and my car has a bit more umph.
Sunkist is offline   Reply With Quote
Old 04-16-2003, 11:16 AM   #11
Twelvz
Member#: 11302
11 GT-R
10.x @130+
just fyi...
anything over 13psi and your idc's will be well over 100%
14 psi you'll be around 120%
Twelvz is offline   Reply With Quote
Old 04-16-2003, 11:28 AM   #12
tdxflex
Member#: 13634
The 22 flows a bit more than the 23 and has more lag. the 23 is probably more comparable to a 30. Are you sure you're not getting any detonation, pulled timing, etc? even if the car pulls a bit more and everything appears safe, i would keep an eagle eye on my gauges. it's not like people didn't have problems with their stock turbos, so even if you lowered the boost to try to match the cfms, you can still have problems.
Old 04-16-2003, 12:43 PM   #13
Sunkist
Member#: 26387
2002 2.5 Hybrid WRX
Platinum
It seems to be running perfectly, I had a shop install it for me and they said it is running very reliably and should last if I keep it this way for a long time.
Old 04-20-2003, 06:45 PM   #14
wrx2
Member#: 13852
2002 WRX vf22 SOLD
Now E46 M3 Vert
Hey Shiv
I just ordered injectors and pump. My credit card bill will kill me next month. Anyway I will send you my unichip tomorrow to remap. Do I have to send you EMI adapter with unichip? or just unichip? Let me know. Can anyone give me the answer this question? Thanks.
Old 04-20-2003, 06:54 PM   #15
tdxflex
Member#: 13634
i don't know how they can come up with that assumption without doing any datalogging. i'm sure it is somewhat reliable, to what extent is unknown. and you may also have trouble spots in certain rpm ranges.
he just needs the unichip
Questions for VF22 owners Agent_50 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 02-19-2004 10:29 AM
Question for M2 turbo back users WRX7 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 09-28-2002 01:35 PM
Question for MRT Turbo Back Owners lbk16 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 08-28-2001 10:30 AM
Question for the turbo gods out there skyliner33v Normally Aspirated Powertrain 17 02-10-2001 01:30 AM
Is my car out of the question for a turbo? GregBolby General Forum Archive 4 01-12-2001 08:58 PM
