Old 04-15-2003, 02:07 PM   #1
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
Default Wheel/tire losing air, what to check?
I put 45psi into my tire yesterday and I'm down to 28psi today. Is there any way to check the wheel to see if it's cracked or maybe the valve stem? Is there a test that can be done at a tire/wheel place? Thanks
garface is offline   Reply With Quote
Old 04-15-2003, 02:09 PM   #2
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
yes they can 'test' it at a wheel tire place....
if there's a pin hole even, they'll find it... likely you just ran over some crap on the road, it happens... they can patch/repair it for a minimal fee...
but if i were you, i would not delay. get it taken care of now...
good luck..
Jamie www.subiegalracing.com
Old 04-15-2003, 02:17 PM   #3
Safir
Member#: 3873
. Paradise is
like Disney with hookers
check to make sure there is nothing stuck in the bead of the tire, then (if possible) remove the wheel and inspect the tire carefully for anything lodges in it - nail/etc. Inflate the tire fully and put some soapy water around teh bead and anywhere that looks suspicious, if there is air leaking out it will create bubbles. This is the first thing they will do at the tire store if you take it in there and you can save yourself some tiem there if you at least give it a once-over and tell them either a) there is a hole and it's right here or b) you checked the tire with soap and could not find a leak. they, of course, may choose to ignore you and check anyways, but you can try.
Safir is offline   Reply With Quote
close to 30k miles, what to check/repair/look at Jonny07subie Service & Maintenance 1 02-06-2009 05:37 PM
drifted into curb, bent bottom of wheel, top of wheel is cambered out what to check? PhilJensen Brakes, Steering & Suspension 14 01-15-2008 08:30 PM
Going to a car auction what to check for? Riot Type WRX Off-Topic 7 11-27-2006 04:57 PM
Tire losing air suddenly? Ruined my TSD Costas Brakes, Steering & Suspension 7 04-08-2003 01:24 PM
feathering tires, what to check? WRX4me Brakes, Steering & Suspension 1 09-23-2002 11:42 AM
