Old 04-17-2003, 05:23 PM   #1
dunk
Member#: 15359
Default Forester TD04
I apologize if this topic has been brought up before. I've done a search but couldn't find exactly what I was looking for. I own a 2002 WRX and am in the process of buying a 2000 Forester. Looking around my garage the other day I noticed that I have an awful lot of WRX parts lying around. I was curious on the feasibility of turboing my forester with the stock turbo from the WRX.
I have searched for information on the Forester chassis, but I need confirmation on the following points. Will the turbo legacy or WRX crossmember fit on the forester. I have or am buying the following parts. Any suggestions for other things needed would be helpful. I don't mind bleeding the WRX for parts, it's going in the garage for awhile as I save up for a turbo, intercooler, etc for it. Well, here's my current list.
WRX manifolds
vishnu uppipe (making a spacer is no problem, work in a machine shop).
WRX downpipe and catback
WRX turbo
WRX intercooler ( don't mind modifying it, see above comment about machine shop )
Voltage clamp for the MAP
RRFPR
J&S safeguard.
I assume that I can use the WRX fuel pump.
Water pump off WRX.
I would also assume that doing the parallel fuel rails mod off scoobymods would also be advisable.
What other hoses and fitting would I need. I'm aware that I would need to run oil lines from the high pressure side of the motor to the turbo, and then return to the block. I assume I will have to buy new hoses for this purpose. i couldn't find by searching what I should do with the coolant hoses. Are there any other fittings that I would need to make this project work?
dunk is offline   Reply With Quote
Old 04-18-2003, 02:23 PM   #2
iceweazel
Member#: 6816
01 yeller wrx
triumph tiger,klr,cb900f
Just like turbo'ing an RS. Move this to aftermarket induction for all the right answers...
Ed
iceweazel is offline   Reply With Quote
Old 04-18-2003, 03:15 PM   #3
AndyHidley
Member#: 1031
Not to start ruhmors, but subaru is going to offer a turbo version of the froester and baja soon....
AndyHidley is offline   Reply With Quote
Old 04-18-2003, 03:34 PM   #4
driggity
Member#: 7453
2014 Scion FR-S
Hot Lava
If by rumors you mean things that Subaru of America has already announced and shown then you are correct.
And I agree that you'll probably get more/better answers in the Aftermarket Forced induction forum.
driggity is offline   Reply With Quote
Old 04-18-2003, 04:45 PM   #5
dunk
Member#: 15359
I posted it there, but someone moved it here. I've pm'd a moderator in aftermarket forced induction to have it moved back. td04 must of set off some flag.
-Duncan
Forester Guru Needed - Stock TD04/Service Manual denn Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 12-09-2008 02:34 AM
2.5rs with 2001 forester engine +td04? b-man1 Normally Aspirated with bolt-on Forced Induction Powertrain 0 04-08-2008 11:36 AM
Forester td04 needed Tadsmith Private 'Wanted' Classifieds 2 04-01-2008 07:59 AM
NY FS: TD04 Turbo, STi short shift kit for the Forester. Zumble Private 'For Sale' Classifieds 3 02-02-2006 02:53 PM
TD04 and 04' Forester 2.5XT ECU- both 6k mi! adamnquickcivic Private 'For Sale' Classifieds 2 02-23-2005 06:26 PM
