Old 04-15-2003, 08:55 PM   #1
fej
Member#: 24147
2003 Subaru WRX 5mt
Sonic Yellow w/ few mods
Default utec and ECU resets
Quick question for the experts here ... I just picked up a UTEC and got it installed ... I don't have the boost turned up too much yet as I am still getting accustomed to the logging/maps. (This may be part of the problem ... not sure yet).
Mods are:
Perrin Catless DP
MRT uppipe
stock axle back
I am currently running the stg 2 map and seeing less than 1bar boost. Granted I have only made two pulls and I am curious if the ECU is still learning my style. Gonna post a small log where I got more knock than I wanted for sure ... if you can let me know what you suggest.
3912 013 -7.9 00 ECU. 13.5 00000
3921 014 -6.5 00 ECU. 13.2 00000
3940 015 -4.7 00 ECU. 14.2 00000
4006 017 -3.0 00 ECU. 14.6 00000
4040 017 -1.2 00 ECU. 14.9 00000
4125 018 +0.2 00 ECU. 14.7 00000
4095 018 +1.3 00 ECU. 14.5 00000
4214 018 +2.1 00 ECU. 14.6 00000
4251 019 +2.7 00 ECU. 14.5 00000
4306 019 +3.1 00 ECU. 14.7 00000
4301 020 +3.1 00 ECU. 14.7 00000
4345 019 +2.9 00 ECU. rich 00000
4391 019 +2.5 00 ECU. rich 00000
4498 019 +1.7 00 ECU. rich 00000
4541 018 +1.7 00 ECU. rich 00000
4559 018 +1.1 00 ECU. rich 00000
4642 018 +0.6 00 ECU. rich 00000
4662 018 +0.4 00 ECU. rich 00000
4642 018 +0.4 00 ECU. rich 00000
4701 018 +0.0 00 ECU. rich 00000
4694 017 +0.0 00 ECU. rich 00000
4782 015 -0.8 00 ECU. rich 00000
4816 014 -1.4 00 ECU. rich 00000
4768 014 -2.2 00 ECU. rich 00000
4803 014 -2.8 00 ECU. rich 00000
4866 014 -3.2 00 ECU. rich 00000
4923 014 -3.6 00 ECU. rich 00000
4887 015 -3.2 00 ECU. rich 00000
4923 014 -3.2 00 ECU. rich 00000
4990 014 -3.0 00 ECU. rich 00000
4997 014 -3.2 00 ECU. rich 00000
5144 047 -2.0 00 ECU. 14.2 00000
5089 095 +0.4 30 ECU. rich 00000
5208 095 +3.7 50 +16.0 rich 00002
5184 094 +8.2 60 +16.0 rich 00000
5291 094 +10.6 70 +16.0 rich 00000
5350 095 +11.9 70 +16.0 rich 00002
5446 094 +12.9 70 +16.0 rich 00000
5500 094 +12.7 70 +16.0 rich 00000
5500 094 +12.3 60 +16.0 rich 00001
5659 094 +12.7 70 +16.0 rich 00000
5698 094 +11.9 70 +16.0 rich 00000
5847 094 +11.5 60 +24.3 rich 00000
5817 092 +12.1 70 +16.6 rich 00008
5878 091 +11.9 70 +16.3 rich 00000
6127 091 +12.7 70 +16.7 rich 00000
6150 090 +12.7 70 +16.9 rich 00002
6105 088 +12.5 70 +17.0 rich 00000
6161 086 +12.1 70 +17.0 rich 00000
6116 079 +11.7 60 +25.0 rich 00000
6385 053 +11.7 00 ECU. rich 00000
6600 002 +9.4 00 ECU. 12.4 00000
6289 031 +4.5 00 ECU. 12.9 00000
6535 095 +2.9 10 ECU. rich 00000
4728 095 +3.1 50 +17.0 rich 00033 ouch ***?
4522 095 +6.4 80 +6.1 rich 00014 ouch ***?
Have double checked map .. exact replica of the stg 2 map at TXS. Boost was less than 13. Always use 91 octane .. best I can get here in CA. Either Arco or Chevron.
Thanks in advance
Fej
fej is offline   Reply With Quote
Old 04-15-2003, 10:03 PM   #2
AWMIII
Member#: 3980
2004 SVT Focus
Screaming Yellow!
You are going to blow up your engine! I have never seen a knock count go to 33. That is crazy. What kind of fuel are you running. There is something seriously wrong with the map that you are using. Use logger number 1 it gives more information. From what I can see it looks like your timing map might be messed up. Please turn down your boost until you get your car running without detonation. Then if you are using reasonable fuel, get some help from Turbo XS. JUst so you know, I run a really really agressive map and my car NEVER EVEN SHOWS A DET VALUE OF 1. While I was developing my map I occasionally say a det of 10 but no more.
DO NOT CONTINUE WITH A PULL IF YOU GET A DETONATION! FIX IT AND TRY AGAIN.
AWMIII is offline   Reply With Quote
Old 04-15-2003, 11:07 PM   #3
Member#: 13004
2002 Pump Gas Homo
Im very scared also!! use logger 1 I cannot see what the prob is +6 timing and 17 of boost??? Is there fuel in there?
David@Vishnu is offline   Reply With Quote
Old 04-15-2003, 11:15 PM   #4
mr2guru
Member#: 10334
91 RX7 LSx swap
'09 CC 3.6 4motion
Yeah any knock above 20 is usually audible. Thats some serious knock Definately pull some timing there. I would stay out of higher boost until you get some different gas in that tank though. Just incase it is the gas.
mr2guru is offline   Reply With Quote
Old 04-16-2003, 12:00 AM   #5
Rich10
Member#: 14934
IIRC, the stage 2 map is for 93 octane.
You may have gotten a tank of bad gas. I'd close the ABC and burn the gas off without going into boost. Then try again with a new tank of gas and a less aggressive map.
Rich10 is offline   Reply With Quote
Old 04-16-2003, 11:48 PM   #6
DocDetroit
Member#: 24977
2003 WRX
Yeah you are knocking all over the place. Something doesn't seem right. When I was on a stage 2 map it was like 10 degrees here. Even then I only got knock at one or two spots.
One little quirk of the UTEC is that it isn't "guarenteed" to log the knock event. Looking at the timing values is a better indicator of knock.
From 5200 - 5700 RPM you are "stuck" at 16 degrees of timing even though the stage 2 map should be at 25 degrees there. You only show three different knock events in that range, but you were knocking through that whole range. We know this because if you weren't, the UTEC would start advancing timing again within 100 crank cycles (default knock retard duration).
You can see at 5847 you jump to 24 degrees of advance. This is because that was the first time since 5200 RPM that you went 100 crank rotations without knock. You come up to 24 degrees of advance, but immediately start knocking again and continue knocking until you take your foot off the gas at 6105 rpm.
Something is definately wrong. You don't just have a couple of sporatic knock events. You are knocking over entire RPM ranges.
I think I would run this buy the TurboXS guys before you make any more runs, just to be safe. Hopefully you got some terrible gas or something.
DocDetroit is offline   Reply With Quote
Old 04-17-2003, 12:03 AM   #7
gpatmac
Member#: 18446
2002 WRX wagon
psm
Thanks Doc,
I've had the UTEC for 8 months and never realized that. I've seen quite a few logs with 'no knock' like you described. Although now, after you've described it, it seems like it's so basic that I should have extrapolated it, I just never put two and two together. I never asked the question, "why is my timing acting so quirky?"
gpatmac is offline   Reply With Quote
Old 04-17-2003, 02:21 AM   #8
fej
Member#: 24147
2003 Subaru WRX 5mt
Default thx
Thanks Doc for the info and description ... I spent a lot of time today looking at my two runs that I did make (driving the car out of boost and in stock default ECU mode atm) and made some preliminary changes to a stg2 map after I talked to Nathan this morning. Fortunately this tank of gas is almost gone and I will have a dyno day with some other UTEC cars coming in the next 2-3 weeks that should help. Hoping it is mainly a bad tank of gas that caused that god awful log. Any more help or suggestion is appreciated. I wish I had a datalog from #1 but unfortunately I am a little hesitant to say the least to make any more runs on any map until I lose this gas at least based on that knock count and timing data.
Thanks again
Fej
Old 04-17-2003, 02:29 AM   #9
DocDetroit
Member#: 24977
2003 WRX
Did Nathan look at the log? What was his take on it?
Old 04-17-2003, 04:11 AM   #10
fej
Member#: 24147
2003 Subaru WRX 5mt
not yet .. could not get the laptop online today but gonna try and email the log to him tomorrow after work. Am too lazy to save the file to a disc and send it blah blah. Anyways thanks again for the info and will post any findings I have when I hear back, hopefully to help more people out who have similar mods ....
I am really curious as to what nathan would say about the log as well .. its really too bad I did not have it on #1 ... ah well I know now hehe
Fej
Old 04-17-2003, 01:24 PM   #11
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
For your 91 octane situation you should probably pull 2 degrees of timing from your entire map (maybe even more). You are definately knocking quite a bit that the Utec is not logging. IIRC every 1 octane point is about 1-2 degrees of less timing. I feel for you since I have to run winter blended gas 4-5 months out of the year.
mbiker97 is offline   Reply With Quote
Old 04-18-2003, 07:06 PM   #12
fej
Member#: 24147
2003 Subaru WRX 5mt
I talked to Nathan and he emailed me a stg1 map slightly modified that I ran last night. Car ran better but still ran with less timing than mapped at the 70%+ load range with one logged incident of knock. Pulled 1 degree more timing in the 70 and 2 from the 80-90-100 in the 3750-5k range and smoothed some timing bumps out from 5k-5500. Will run that new map tonight and see how things go.
Thanks again for the advice ... a new tank of gas goes in tonight as well .. hopefully for the better.
Fej
p0031 and misfires after a brand new front o2 sensor and ecu reset 1gcrazy Newbies & FAQs 25 09-26-2008 01:17 PM
GanzFlow aftermath and ECU reset question heatseeka Normally Aspirated Powertrain 16 06-19-2001 03:21 PM
Intercoolers and ECU Resets Kevin Thomas Normally Aspirated Powertrain 2 03-09-2001 10:55 PM
AFC and ECU reset Spectre23 Normally Aspirated Powertrain 0 03-03-2001 11:06 AM
changing octane and ECU reset Jonathan Kent Normally Aspirated Powertrain 10 10-25-2000 10:09 PM
