Old 04-16-2003, 12:33 AM   #1
Kotir
Member#: 17300
1993 Widebody Wagon
748whp e98
Default 225/50-16 on a GC6 (16x7.5" rim)
How much camber or fender roll would I need to have to run SVX rims on my 2001 2.5RS? Their stock size is 225/50-16, 16" by 7.5" rims. They are the same overall diameter, 24.9" which is 829 rev/ mile, as the stock 205/55-16 which are the stock tire for my car. My car is lowered with H&R Sport Springs aswell.
Anyone lowered running wider rims?
Would going to a different series of tire help? These are going to be autocross rims/tires so dropping the gearing would be acceptable.
Kotir is offline   Reply With Quote
Old 04-16-2003, 11:24 AM   #2
omahasubaru
Member#: 1594
1995 WRX
2002 Legacy
those won't lower your gearing.. You could run them on your stock rims if you wanted.
Do you know what offset the SVX rims are? 7.5" wide rims??? Where did you find that at? Do you know how much the rims weigh?
Thanks - Jon
omahasubaru is offline   Reply With Quote
Old 04-16-2003, 11:48 AM   #3
tora
Member#: 5851
09 Forester XT
+ NA Miata
Do SVX rims fit? I heard they had a completely different bolt pattern.
tora is offline   Reply With Quote
Old 04-16-2003, 12:40 PM   #4
Safir
Member#: 3873
. Paradise is
like Disney with hookers
225/50/16 on 16X7 raceline RL-7 on a MY01 GM6
took it to the track yesterday and did not have any apparent rubbing issues. only thing is i am on stock springs and struts, so no lowering. I do have to run 3mm spacers in the rear to avoid rubbing on the strut.
Safir is offline   Reply With Quote
Old 04-16-2003, 12:49 PM   #5
Blindeye_03
Member#: 4418
2016 Focus ST
Yea they wont even bolt up to your car, unless you had different hubs to convert it to what the svx has (114x5 I believe).
Where did you get the spacers at...I want some .
-justin
Blindeye_03 is offline   Reply With Quote
Old 04-16-2003, 01:24 PM   #6
tora
Member#: 5851
09 Forester XT
+ NA Miata
I got 5mm aluminum spacers from a local shop. They are kind of a semi-universal spacer but work fine. Cheap too...$12 for four.
Old 04-16-2003, 04:36 PM   #7
Safir
Member#: 3873
. Paradise is
same here - i have friends at the local tire shop.
BTW i only needed spacers in the rear, the tires were ALMOST touching the shock without them.
Dunlop SP 5000 225/50/16 on stock rims on lowered WRX? MY03WRX Tire & Wheel 3 03-23-2004 09:57 AM
225/50/16 on Rota Slipstreams on a GC8...? Kostamojen Brakes, Steering & Suspension 4 02-21-2003 01:20 AM
205/45-16 vs. 225/50-16 on stock rims? japriljr Brakes, Steering & Suspension 1 08-14-2002 02:58 PM
205/55-16; 215/50-16; or 225/50-16 on stock rims? WRXNE1 Brakes, Steering & Suspension 12 07-08-2002 10:45 AM
225/50/16 on 16x7 okay with AGX H&R? iBlueVirus Brakes, Steering & Suspension 11 05-31-2001 03:48 PM
