Old 04-16-2003, 05:20 AM   #1
uluv69Marines
Member#: 32047
1998 Impreza 2.5 RS
WR Blue...7000 miles away
Default Car hesitates from stop
Hey guys got a wierd question...every since i put my weapon r intake on, my 98 rs lunges, pauses, and slowly starts to accelerate if i jump on it from a stop. if i'm rolling at 2grand, it opens right up...my mods: venom 400, random cat, borla cat-back, pro-ecm.
uluv69Marines is offline   Reply With Quote
Old 04-16-2003, 08:24 AM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
that sounds like the typical bogging associated with free-flowing intakes.
I had it when I had my intake on my legacy, and several friends reported similar problems with theirs.
Solution....put stock box back on.....or look into a cobb CAI
Legacy777 is offline   Reply With Quote
Old 04-16-2003, 11:46 AM   #3
Deznuts05
Member#: 1410
2011 X5 Diesel
Space Gray
yup... common problem... but this may seem like a stupid q's but did you reset your ecu?
if so you'll just have relearn how to drive the car
Deznuts05 is offline   Reply With Quote
Old 04-17-2003, 02:32 AM   #4
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
One of the many reasons you no longer see Weapon-R intakes on Subaru's...
Old 04-17-2003, 08:03 AM   #5
lucien2
Member#: 1519
1998 Volvo V70R
I'm not sure how the intake is set up on an RS, but I do know you have a Phase I DOHC like me, and it needs the torque chamber to be in the pipe line. What's happening is the chamer normally hold a reservoir of pre-filtered air for the intake plenum to use when asked for a lot of throttle, as in from a dead stop. So with the Weapon R (or JC Sports, etc) it isn't there anymore so it has to suck new air through the whole intake. It becomes momentarily starved for oxygen and bogs down. I went back to stock intake minus the snorkus after I really had a close call at an on-ramp construction zone.
lucien2 is offline   Reply With Quote
Old 04-17-2003, 09:38 AM   #6
uluv69Marines
Member#: 32047
1998 Impreza 2.5 RS
Default thanks
appreciate it guys...I heard something about it before. Do you think that the same thing would happen on a tubo setup without an intercooler?
Old 04-18-2003, 01:50 AM   #7
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Default Re: thanks
I'm not following you on this one... What do you mean?
Old 04-18-2003, 03:32 AM   #8
uluv69Marines
Member#: 32047
1998 Impreza 2.5 RS
saying that engine is temporarily "starved" of oxygen, could the same thing happen on a turbo setup without an intercooler (resevoir) to hold filtered air?
Old 04-18-2003, 06:23 PM   #9
dentprone
Member#: 18588
1999 busted car
silverthorn
im pretty sure the N/A engines subaru makes need the torque box...ya know that big ugly black box right before the throttle body... to supply enough air to the engine because the intake manifold is so small it runs out of air and lacks power on the low end. or wherever you find a bog in the power band...a good intake should hold enough air to be twice the engines displacement... this manifold without the torque box is better suited for turbo boost where it never runs out of air... just an idea
dentprone is offline   Reply With Quote
Old 04-19-2003, 02:23 AM   #10
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Not quite, but There have been issues with intakes on WRX's not doing anything power wise, so in that reguard the stock system (after silencer removal) works quite well unlike the N/A cars. An intercooler just keeps the air colder before it goes in the engine, as turbos get quite hot and heat the air up.
Old 04-19-2003, 02:56 AM   #11
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Bingo. Basically the engine runs out of air and very briefly (VERY briefly) wants to stall until the charge starts moving through the runners again
Eric SS is offline   Reply With Quote
Bog/Hesitation on acceleration from stop, 2005 RS w/ injen CAI kevinmwolf Normally Aspirated Powertrain 9 01-03-2008 01:27 AM
Car very sluggish from stop and go wrxrex Newbies & FAQs 2 08-05-2007 02:45 AM
Hesitation from 3300-3400rpm only..sensor on the fritz? Basshead Normally Aspirated Powertrain 3 09-19-2003 10:35 PM
Slight hesitation from 4k-4500 JHSPayBar Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 03-31-2003 02:38 AM
what is stopping japanese car makers from... elemental General Forum Archive 23 03-20-2001 03:18 PM
