#1 |
Member#: 793
VIC
Vehicle:2000 Impreza 2.5 RS Silver |
Thanks Jamie!!
![]() Do you know the extent of the modification to the hub? I would like something reliable Is the momo hub the same as the sparco unit?Thanks again!! ![]() Ashton |
#2 |
Member#: 793
VIC
Is anyone using an aftermarket momo steering wheel with hub adapter on a MY00+ RS? If so, please post here with the hub modifications you needed to make to get it to work. I was told it works on a MY99 without any problems/modifications.
Also, were you able to use cruise control after the mod (ie. just move the switch?). Thanks ![]() Ashton |
#3 |
GC84Ever
Super Moderator |
i have it on MY O1....
hub was modified... and i relocated the cruise switch - Jay_uk modified the hub for me... but i hear www.rallispec.com has a modified one that will work... pix... j. www.subiegal.com |
#4 |
GC84Ever
Super Moderator |
the rallispec momo hub is modified to allow your horns to work... not your cruise...
unless you get really creative, you'll probably lose the cruise... i am not sure i can duplicate what Jay_UK did to mine... it's quite trick... email rallispec or phone them.. they are super nice guys... please let me know if you have any questions at all! j. www.subiegal.com |
#5 |
Member#: 4093
Vehicle:01 Impreza BRP |
What about the air bag? Can you just take it out?
#6 |
Member#: 793
VIC
Hi Jamie, I have one more question (okay, 2)...
Was the hub modified in any way mechanically? If it just a case of wiring, I can do all that myself pretty easy. I called MOMO Canada and he said I would have to run a horn wire, but he didn't say anything else. I was also told I would lose the cruise, but its just a switch, so again, pretty simple to move. Also, did you have any trouble with the air bags? ie. the SRS light coming on in the dash or any warnings about the passenger bag not functioning? I heard that there was some sort of plug you could use at the end of the SRS unit? Merci! ![]() Ashton |
#7 |
GC84Ever
Super Moderator |
the airbag came right out.. i've done this twice now - no problems...
but my airbag light is on.. i dont care... i cant see it so it doesnt even bother me... hehehe i imagine you could pull the rear dash assembly out and pull the light bulb out... that is one solution if it bothers you... j. www.subiegal.com |
#8 |
Guest
Member#:
When you do pull the airbag, make sure you disconnect the battery. Don't want to make any mistakes...POP!
Also, passenger bag will be disabled and light will stay on. Airbag light...removing the dash housing and getting behind there is gonna be a chore...light isn't bright enough to be a problem. |
