Old 04-16-2003, 12:38 PM   #1
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Default Front spacing question for wheel offset wizards
I had done some math and wanted to see if it was correct.
For my question disregard tire width/size etc.
My Legacy comes stock with a 6.5" wide wheel with +55mm offset. This equates(if I've done the math right) to ~ 27.6mm of wheel in front of the mounting surface. This sure doesnt seem right to me, but this is how I arrived at this:
(6.5 x 25.4mm)/2 - 55mm = 27.6mm
Is there really only a little over an inch of space from the face of the wheel to the mounting surface? Have I gone wrong here somewhere?
ss
subysouth is offline   Reply With Quote
Old 04-16-2003, 01:30 PM   #2
Tire Rack Moderator
Member#: 1215
ext. 4362
actually it is 27.55 mm from the bead area of the wheel to the mounting pad of the wheel
Old 04-16-2003, 03:24 PM   #3
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
hehe - OK.
It just SEEMS farther back than that. Hey Luke the prob I am having is that I currently have 01 RS wheels on my car and they are about at the limit of what I want a wheel protruding out of my wheelwell. I may be in trouble as far as 17" options go.
RS wheel(+53mm) extends out 35.9mm
SDRs(7.5" +48mm) extends out 47.25mm
Wheel X(7.5" +45mm) extends out 50.25
Any thoughts?
ss
Old 04-16-2003, 04:13 PM   #4
Tire Rack Moderator
Member#: 1215
ext. 4362
17x7 with a 48mm offset or higher does work on the Legacy GT with no problems ... but tire choice is critical because the widest that works is 205
Old 04-18-2003, 12:58 AM   #5
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
OK Luke I had a little to much time on my hands this evening and I have to say the above is incorrect. And I learned something new today.
I needed the tires pulled from my Legacy GT wheels anyway so I had them pulled today. And then I took some measurements on the bare rims:
With the wheel flat on its face on the ground the measurement from the front mounting bead to the mounting surface is 1 5/8" or 41.275mm. So it was farther back like I thought, but I think I figured out why. When I measured my 6.5" wheels from front to back, they are 7 5/8". Splitting that extra in half and adding it to the 27.55mm is just about spot on.
So I guess a wheel listed at 7.5 inches wide is closer to 8.5 inches then?
ss
Old 04-18-2003, 09:51 PM   #6
Bottom Feeder
Member#: 2808
No, Luke is right. He's measuring from the bead, and you're measuring from the face. Wheel width is measured between the beads, not the extreme outer edges.
Bottom Feeder is offline   Reply With Quote
Old 04-18-2003, 11:16 PM   #7
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
AHHHH! My mistake, I thought the bead was the small lip on the outside edge of the rim that the front part of the wheel weight nesteld under. The bead is the entire ~1/2" thick section of the edge of the rim then?
ss
Old 04-19-2003, 05:11 PM   #8
Bottom Feeder
Member#: 2808
Pretty much, yeah. Try measuring the diameter of the wheel, also. You'll see that it's something like 17.5" instead of 16", because that is also measured from the inside of the beads and not the outer edges.
stoptech BBK 328mm Front kit... questions for wheel fitment... WRXINTX Brakes, Steering & Suspension 12 03-21-2007 03:34 PM
Question on wheel offsets blindclown Brakes, Steering & Suspension 7 04-10-2003 01:13 PM
Quick question about wheel offset mattdesmond.com Brakes, Steering & Suspension 3 02-20-2002 10:42 PM
A new question about wheel offset (I think) jasony Technical Forum Archive 3 08-26-2000 08:52 AM
If you've ever had a question about wheel offset and/or backspacing... Patrick Olsen Technical Forum Archive 0 06-18-2000 08:56 PM
