Welcome to the North American Subaru Impreza Owners Club Tuesday July 7, 2015
Old 02-12-2001, 09:35 PM   #1
Longitude
Member#: 2216
0000 Gee See
dented
Post C-West Grill/Grille Install
This is a thread for installing the C-West front grille. The steps I wrote up are based on my experiences and mistakes. I will post my pics when I have them developed. Stay tuned.
If you have comments, questions, or contributions, do not hesitate to post here. Please share your experiences with this mod if you have the same item.
<center>C-WEST FRONT GRILLE INSTALL</center>
Refer to the following links for diagrams.
<a href="http://albums.photopoint.com/j/View?u=1509404&a=11400210&p=40118315" target="_window">http://albums.photopoint.com/j/View?u=1509404&a=11400210&p=40118315</a>
<a href="http://albums.photopoint.com/j/View?u=1509404&a=11400210&p=40118314" target="_window">http://albums.photopoint.com/j/View?u=1509404&a=11400210&p=40118314</a>
1. Paint and clear coat wire mesh (if desired).
2. Position wire mesh in front of grille; bottom part of mesh through the prongs of the grille; bend down all prongs.
3. Put screw+washer into each of the bottom holes of grille to hold mesh to grille.
4. I suggest that you position the grille onto the car to see whether you need to sand off the bottom-left and right corners of the grille to prevent the grille from rubbing onto front bumper & also prevent the top of the grille from rubbing onto the hood.
5. For upper holes of grille, will fasten screws+washers into holes of the plastic extensions from the carís headlights.
6. For upper holes of grille, you need larger washers (the given washers appear too small and can slip through the hole of the headlights).
7. Use 2-sided tape to hold nut+washer onto a screwdriver (or something else long in order to extensively reach into back of hole of headlight. IF you have a small & long enough arm you can reach in through the upper part of the front bumper grille to get behind the hole).
8. Position nut+washer behind headlight hole that should also be already behind the upper hole of grille.
9. Get shorter screws for the upper holes (the given screws are much too long and will hit the chassis before you can finish screwing it in. I used ĺ inch machine screws with matching size washers because I donít know where to get those kinds of screws like those given, which need hex wrenches rather than simple flat-head screwdrivers).
10. Put upper screw+washer into each of the upper holes of grille, to connect with the nut that you are positioning on the back side (this is very tricky!).
11. Re-touch paint on scratches and on screws+washers. Done!!!
Longitude is offline   Reply With Quote
Old 02-13-2001, 05:18 AM   #2
omahasubaru
Member#: 1594
1995 WRX
2002 Legacy
Post
Why can't products come ready to paint and install... Why is it that one the supplied install hardware isn't quite right and that one must mock install the grille in order to see if it needs trimmed for fit and finish. For $125 for a grille you'd think all these things would have been resolved.
I like this grille don't get me wrong, I'm just upset to hear that install isn't a direct swap like it should be.
Jon
omahasubaru is offline   Reply With Quote
Old 02-13-2001, 11:55 AM   #3
Longitude
Member#: 2216
0000 Gee See
dented
Post
I do love this grille..but if I knew the kind of effort involved way before I got it, I may have gone with a genuine Subaru product instead, which should simply snap in like the one that comes with the car.
Old 03-25-2001, 09:22 PM   #4
Longitude
Member#: 2216
0000 Gee See
dented
Thumbs up
I finally got pics of mine. Enjoy:
<IMG SRC="http://albums.photopoint.com/j/View?u=1509404&a=11400210&p=44817306" border=0>
<IMG SRC="http://albums.photopoint.com/j/View?u=1509404&a=11400210&p=44817308" border=0>
<a href="http://216.242.153.40/MembersList/ViewMemberPics.cfm?MemberID=2145&PicNumber=2">more pics</a>
[This message has been edited by G0DZILL0NG (edited March 25, 2001).]
Old 03-26-2001, 10:20 AM   #5
adamsrs
Member#: 3768
Post
I LOVE THAT GRILL. I want it so f'ing badly!
adamsrs www.unnatural.org
adamsrs is offline   Reply With Quote
Old 03-26-2001, 01:11 PM   #6
Overtime
Member#: 1346
Post
If you're interested in the above grille, PM me for a discounted price. Just don't expect TOO much.
Overtime is offline   Reply With Quote
C-WEST Rear Wing and CF C-WEST style Grill (MD) StillBoostin Exterior/Styling 25 10-14-2007 11:53 PM
Replica C-West V2 grill for sale kenny Southern California Impreza Club Forum -- SCIC 3 07-16-2003 01:19 AM
anyone makes C-west copy grill? scoobypuff Interior & Exterior Modification 2 04-27-2002 05:32 PM
c-west wrx grill? initialWRX Interior & Exterior Modification 1 04-16-2001 08:42 AM
C-West Front Grill Give-away ! B-SpecUSA Southern California Impreza Club Forum -- SCIC 3 03-27-2001 01:48 PM
