Old 04-16-2003, 04:48 PM   #1
IA Performance
Member#: 25194
2008 Forester XT 5mt
Dark Gray
Default TEIN coilover owners please read my Q.
I have the wagon version on my WRX wagon. They are lowered about 1.5" all the way around. The other day I noticed that the front "dust covers" for the shocks are eaten up. They've been getting eaten by the springs sitting on them. On my driver side I had to remove the entire assembly to pull the bump stop off which had actually stuck part of the dust cover up into it. The rears are fine, but the front rubber boot covers need replacing. Anyone else?
IA Performance is offline   Reply With Quote
Old 04-16-2003, 06:13 PM   #2
Mr.Hanky
Member#: 22053
2002 Black WRX Wagon
Stage 3, Element Tuned
Default Re: TEIN coilover owners please read my Q.
Well that sucks, I am thinking about getting those for my wagon too. Thanks for the heads up.
How do you like them otherwise?
Steve..
Mr.Hanky is offline   Reply With Quote
Old 04-16-2003, 07:00 PM   #3
Nat
Member#: 759
2004 WRX
2000 SV650
Just to let you know, I've been running the HAs on my 99RS WITHOUT covers for about 3 years now, maybe more. This is in the northeast too, where the roads aren't known for being so nice in the winter....sand/salt/etc. They didn't have the covers when I bought them, and after doing research I saw that a fair number of people running other coilovers didn't have them either so I didn't think anything about it. I wish I had them, but nothings failed me yet, at least due to contamination. I whacked a huge pothole which ripped apart the top seal, but a quick turnaround/rebuild by Tein took care of that. I know this doesn't really deal with your question, but I wanted to throw this out there.
Nat
Nat is offline   Reply With Quote
Old 04-17-2003, 11:46 AM   #4
IA Performance
Member#: 25194
Dark Gray
The coilovers ride GREAT. They have received many compliments from other owners as well. The other owners had setups ranging from full STi struts/springs, just springs on stock struts, and full blown HKS coilovers. Plus this is on my 18s with tower and sway bars
Old 04-17-2003, 01:09 PM   #5
kenchan
Member#: 15106
yep, typical problem on the HA's...mine is like that not only
on my wrx, but on my 98 prelude as well. i called up TEIN Jpn
like 5 years ago when my prelude's tore. the guy there told me
that unless i rally or drive under heavy dust/small rock conditions
i should be fine without the boots. fine from salt too. i only drive on road so
i pulled them off and as a precaution, bought some black duct tape
and taped over the coils. that way no rock could hit the shaft.
those duct tape is amazing... its on there since 5 years ago
and no one tear or sign of peeling off. did the same on the wrx as well.
dont worry, you're not the only one with a torn front boot.
i think the FLEX comes with the solid ones which hold up
much better.
kenchan is offline   Reply With Quote
Old 04-17-2003, 01:45 PM   #6
slater
Member#: 5848
1992 vw corrado vr6
silver w/ schrick/quaife
i run dust boots under my eibach ERS springs on my ground controls... they're heavy-duty mofo dust boots - made by trailmaster for crazy 4x4 suspensions. also, they were the only boot i could find that was small enough to find inside 2.5" ID springs, and they barely fit. plus they come in 10 different colors and are only $12 for a set of 4!
peter
slater is offline   Reply With Quote
Old 04-17-2003, 02:25 PM   #7
WR xplosive
Member#: 33031
2008 4B11T
P26 MZ314000
I've checked mine just now, no problems, yet. but I'm using TEIN SS on my WGN tho. I'll keep my eyes open for this issue.
WR xplosive is offline   Reply With Quote
Old 04-17-2003, 03:09 PM   #8
IA Performance
Member#: 25194
Dark Gray
My passenger side is this one, it looks the worse of the 2.
This is after 8K miles. No track events, just city driving.
Old 04-17-2003, 03:29 PM   #9
WR xplosive
Member#: 33031
2008 4B11T
P26 MZ314000
damn! I better keep checking mine every week!
Old 04-17-2003, 09:58 PM   #10
WR xplosive
Member#: 33031
2008 4B11T
P26 MZ314000
East Coast Scooby, it looks like the clearance between your spring and shock is too tight. I'll post some pic tomorrow of mine.
Old 04-17-2003, 10:09 PM   #11
Red Rocket
Member#: 10507
'04 Ex STi Owner
'97 4Runner
What exactly did you do with the tape?
Thanks,
Kevin
Red Rocket is offline   Reply With Quote
Old 04-18-2003, 01:35 AM   #12
kenchan
Member#: 15106
i cut the black duct tape in about 5inches lengths and just taped up the spring so that the shaft is no longer visible. the tape will protect the shaft from any rocks that might fly towards the shaft. you dont want to tape up the entire spring as you want the shaft and its rubber seals to be able to breath to dry moisture. works great for the last 5 years.
Old 04-18-2003, 12:29 PM   #13
WR xplosive
Member#: 33031
2008 4B11T
P26 MZ314000
I just realized that the dust boot for TEIN WGN and HAs are just like the OEM ones.
This is mine, TEIN SS came with solid boots.
Old 04-24-2003, 08:59 AM   #14
redobs
Member#: 1501
2009 WRX wagon
Dark grey
I just picked up a set of used Tein Wagons, and the rear boots are ripped like East Coast Scooby was describing. The fronts didn'thave any boots, but they looked fine. I'll try and get some pics up tonight.
redobs is offline   Reply With Quote
Old 04-24-2003, 11:40 AM   #15
WR xplosive
Member#: 33031
2008 4B11T
P26 MZ314000
maybe you guys need to install what slater did.
Old 04-24-2003, 01:16 PM   #16
kenchan
Member#: 15106
i wont take the strut off the car and apart just for that.
ive yet to raise the car every night just to admire the teins....
Old 04-24-2003, 02:05 PM   #17
slater
Member#: 5848
1992 vw corrado vr6
right on!
peter
Old 04-24-2003, 02:35 PM   #18
Cosworth
Member#: 3887
08 Taco, 98 M3/4/5
'00 RC51, '08 KTM
These are the boots that slater and i use. They fit fine under 2.4" coils.
Cosworth is offline   Reply With Quote
Old 04-24-2003, 07:44 PM   #19
mlambert
Member#: 13831
The front boots on mine came with a hole in them, manufactured like that. I wouldnt worry too much...atleast I dont
mlambert is offline   Reply With Quote
Old 04-24-2003, 11:31 PM   #20
atomicapples
Member#: 12626
02 2.5 rs
how much was a rebuild from tien?
atomicapples is offline   Reply With Quote
Old 04-25-2003, 12:33 AM   #21
SubyDoobyDoo
Member#: 9374
2004 Berlina Blk S2K
02 WRX Sold!
my driver side front is totally eaten up, so much that the car is slightly higher on that side for some reason...Rides great though despite all the noises. People always think my car is falling apart.
SubyDoobyDoo is offline   Reply With Quote
Old 04-25-2003, 12:11 PM   #22
kenchan
Member#: 15106
scoobydodoo- ?! why is it higher? can't you just lower that
corner? the wrx (or any car that i know for that matter) will
not lower completely flat due to corner weight unless you
do some minor tweeks on the height.
i believe the corners were as much as 1/4in off on the rear
and a bit less on the front.
AttN: Tein Coilover Owners / any coilover owners teck7droid Southern California Impreza Club Forum -- SCIC 0 11-22-2004 01:33 PM
Another Tein coilover owner please read 99TS Brakes, Steering & Suspension 3 04-24-2003 06:01 PM
Noises from the rear with CUSCO Swaybar and TEIN RA's, Experts please read! BADWRX Brakes, Steering & Suspension 0 06-18-2002 01:15 AM
Tein coilover owners? UU AR EX Brakes, Steering & Suspension 0 09-05-2001 02:54 AM
Tein Owners....Please Read! SCOOBER Brakes, Steering & Suspension 10 10-21-2000 07:01 AM
Message Board Statistics All times are GMT -4. The time now is 06:41 PM.
