Vancouver Impreza Club
Old 04-16-2003, 07:47 PM   #1
ScoobySubieDoo
Member#: 24822
2003 Impreza WRX
World Rally Blue Pearl
Default 5w30 in your WRX??
I took my 2003 WRX in to the Subaru Dealership for its first Oil Change and I found out that my dealership uses Quaker State 10W30 as a general rule on Subaru Vehicles. I pointed out to the service rep that the Subaru OEM recommendation is 5W30 and they should change their practice to reflect it.
I was wondering what anyone else in BC or Canada, or even in the southern BC interior is getting at their Subaru dealership for Oil Grade.
Technically, at high temps (at 100 degs C), both 5W30 and 10W30 possess similar viscosity properties. At low temps, is where we see the benefit where 5W30 is lighter.
Is there a case to push this dealership to change their Oil Specification to 5W30? if so, can you please help me build the case.
Thanks
ScoobySubieDoo is offline   Reply With Quote
Old 04-16-2003, 09:31 PM   #2
KIMUTAKU
Member#: 19776
2012 GVF SWP
Ninja Lime Green
my dealer uses 5w30 for my wrx...it seems like that's the standard they use if ppl ask for synthetic oil..
i think i'm gonna buy some motul oil next time i need an oil change...heard many good things about it..
KIMUTAKU is offline   Reply With Quote
Old 04-16-2003, 09:36 PM   #3
tora
Member#: 5851
09 Forester XT
+ NA Miata
Why do you have to make a "case"? If you want 5W30 then tell them to use it for your car.
tora is offline   Reply With Quote
Old 04-16-2003, 09:53 PM   #4
Koyo
Member#: 19332
You can always bring in your own oil, unless you don't trust them. Does Kamloops really get that cold that you need 5W30?
Koyo is offline   Reply With Quote
Old 04-16-2003, 11:24 PM   #5
silvscorp
Member#: 28480
i guess different dealer uses different oil (sponsor source?) The two I have experienced with use valvline and another one uses mobil!!.
based on where you are located the temp should drop to pretty low during winters so I would use 5w30. Though 5w30 and 10w30 won't make a major difference in hot weather but in winter you definatly want a smoother one.
silvscorp is offline   Reply With Quote
How often do you change your synth oil in your wrx D-I-Z-Z-L-E Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 58 12-03-2012 09:30 PM
How fast have you driven in your WRX.........in reverse??? hellonwrxwheels Texas Impreza Club Forum -- TXIC 45 12-15-2007 07:43 PM
Spotted: Your pregnant wife in your WRX staticfritz Tri-State Area Forum 17 10-09-2004 09:28 PM
