Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 04-16-2003, 08:30 PM   #1
dman918
Member#: 11202
2009 Infiniti G37X
Prev: 2006 STi with stuff
Default Stupid, quick questions about ABCs for Utec/Unichip
Does the unichip and utec both use the same ABC? I have a blue ABC from my unichip, but the utec came with the silver one.
Also, is the ABC required to set my boost with the UTEC?
Thanks,
Mike
dman918 is offline   Reply With Quote
Old 04-16-2003, 08:42 PM   #2
Ugly
Member#: 19143
02 WRX
When I had my TXS Unichip and now that I have my Utec they came with the same ABC. Also like you the Unichip ABC was blue and Utec ABC is silver.
The ABC isn't required to up the boost with the Utec, but unless you have another form of boost control the OEM set up will only allow you to hit 1 bar. While the Utec stags require a little more then that.
Ugly is offline   Reply With Quote
Old 04-16-2003, 09:20 PM   #3
DocDetroit
Member#: 24977
2003 WRX
I have run 18psi with the ABC fully closed. I think it depends on your particular setup (specifically turbo and down-pipe) and your altitude.
Now maybe one of the TurboXS crew can answer this question. Since I can hit 18 psi with the ABC closed is it better to run it closed, or open it a turn and adjust the boost map values accordingly?
DocDetroit is offline   Reply With Quote
Old 04-16-2003, 11:03 PM   #4
Bolster
Member#: 22290
2002 WRB WRX Wagon
My ABC is also fully closed. I had it open 3/4 turn when I was running stage 2. I never tried it closed then. When I went to stage 4, Phil advised me to try it with the ABC shut first, and it's worked well like that.
Bolster is offline   Reply With Quote
Quick Question About Rockband for XBox 360 skimmilk68 Off-Topic 6 08-12-2008 03:50 AM
Quick question about utec Tucci Engine Management & Tuning 0 04-17-2005 08:51 PM
Noob question about ABC 03 WRX Drifter Engine Management & Tuning 1 07-25-2003 12:19 PM
quick question about stage0 unichip wire connectors titsataki Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-09-2002 11:11 AM
Help, need quick answer to quick question about ezpass munkis General Forum Archive 2 09-29-2000 03:45 PM
