Old 04-17-2003, 03:49 AM   #1
flent
Member#: 4706
2001 2.5rs
silverthorn metalliac
Question Weird Sound From Front End
Well I started to notice this sound about a week ago. While I am driving from about 30 mph or above I hear this whine sound comeing from the front end.
It does not change with the sound from the engine but with the faster the speed. Like the faster I go the louder and faster the sound gets. It does it at all times, (meaning it does it if the clutch is depressed or not, or if I am in gear out nuetral). I cannot figure out where it is comeing from, but it souds like the center of the front of the car..
I have check the cv boots and they both look fine.
Does anyone have any idea what this could be??
flent is offline   Reply With Quote
Old 04-17-2003, 09:47 AM   #2
Ghomer1
Member#: 8091
2007 335i
Monaco Blue Metallic
Belts? Your bearings might be going bad in your alternator....
Ghomer1 is offline   Reply With Quote
Old 04-17-2003, 09:56 AM   #3
ChicksDigWagons
Member#: 20508
1998 Red Wagon
New Turbo Project...
It could be a bad wheel bearing possibly, or something rubbing against the wheel or brake rotor. Something like that.
Jack up your front end and try to wiggle the wheel around. There shouldn't really be any play. If there is, its very possibly a bearing.
But then again it could just be tread wear, or something stuck in your tires.
-Brad
ChicksDigWagons is offline   Reply With Quote
Old 04-17-2003, 10:49 AM   #4
flent
Member#: 4706
2001 2.5rs
I already checked my tires and found nothing in them. I have not tried to wiggle the wheel though.
It can not be the alt. because the sound does not change with engine revs, but speed. I.E. coasting at 60mph in neutral and still hear the sound plain as day.
Thanks
Old 04-17-2003, 02:34 PM   #5
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
Wheel bearing most likely. The sound in the cabin can be deceiving for location. Check to see if the noise changes when you take high speed, high load corners. If it does, then it's likely a front bearing. If not, then it's coming from the rear. Check the warranty forum, I think there are few mentions of bum wheel bearings in there.
-Rob
rob is offline   Reply With Quote
Old 04-20-2003, 11:59 PM   #6
imprezey
Member#: 17178
2001 2.5RS Coupe
Silverthorn Metallic
how much does it cost to have wheel bearings replaced? also, i remember hearing that some people change the bearings from the legacy because theyre stronger? i might be wrong.
imprezey is offline   Reply With Quote
Weird Sound from front end. blackproject18 Brakes, Steering & Suspension 1 08-08-2009 12:33 PM
Weird Rubbing sound from front driver side ogboot Brakes, Steering & Suspension 17 05-09-2008 07:39 PM
help: weird sound from boost gauge mrmcderm Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 12-03-2002 01:54 PM
Weird Sound From CD Player? TinyIvan Car Audio, Video & Security 4 03-18-2002 12:45 PM
Help, more weird sounds from my baby. nightshade000 Technical Forum Archive 4 06-28-2000 01:23 AM
