Old 04-17-2003, 10:06 AM   #1
Achilles38WRX
Member#: 4419
2002 S2K - 2013 ISP
i don't have a wrx
Default helping a friend, question on 92 legacy trans. fluid fill location
the car is supposedly a 1992 legacy, fwd, automatic. a friend of mine helped somone out by putting transmission fluid in the car for them. now they claim there is a serious problem with the car and my friend is to blame, so he called me.
i'm not knowledgeable on old legacies, so i need your help. My friend says he poured the fluid into a location similar to where the filler is on my wrx (passenger side, near the firewall). Sounds correct to me.
The owner is claiming he put fluid into a "differential fluid valve" instead of the transmission, and now the "engine is shaking"
I waved the BS flag, and told my friend not to worry, he wasnt responsible for anything. The owner of the car bought the trans fluid, and my friend only put 3/4 of a bottle in it. What I like best is the owner of the car cant even figure out where to put transmission fluid in the car, but they can correctly diagnose a problem with it.
Any help, re-assurance is greatly appreciated.
Mark
Achilles38WRX is offline   Reply With Quote
Old 04-17-2003, 10:43 AM   #2
subarurabbit
Member#: 4083
2011 OB 3.6R
the ATF fill tube is on the right side of engine - with a yellow handle.
yep, your friend put ATF in the diff filler tube.
subarurabbit is offline   Reply With Quote
Old 04-17-2003, 12:05 PM   #3
Achilles38WRX
Member#: 4419
2002 S2K - 2013 ISP
i don't have a wrx
by right side do you mean passenger side? or, if your standing in front of the car, it would be on your right? He said the handle was a round loop.
I didnt think there was a seperate filler for differential fluid. Do you think 3/4 of a bottle of atf would do any damage?
mark
Old 04-17-2003, 12:37 PM   #4
subarurabbit
Member#: 4083
2011 OB 3.6R
ATF is on driver side.
it too has a yellow loop handle.
yes, drain the front diff - you need a 21mm socket and roughly 1.7 qts of 80w-90 gear lube. use a transmission funnel!
Old 04-18-2003, 03:32 PM   #5
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Old 04-19-2003, 02:06 AM   #6
Achilles38WRX
Member#: 4419
2002 S2K - 2013 ISP
i don't have a wrx
thanks everyone for the replies, and thanks ciper for the link.
i have informed my friend he (or better yet someone else) should drain the front diff fluid and fill it with the correct oil.
i have also informed him to always check the instructions on any car before adding any fluids to it, and to never work on a car in the dark.
thanks again
mark
4EAT trans fluid fill location? Mobius118 Newbies & FAQs 3 06-01-2009 11:58 AM
CEL questions about 92 Legacy. Dealer Xing Legacy Forum 8 01-22-2004 10:24 PM
0-60MPH time on 92 Legacy turbo!! Ben Legacy Forum 1 04-02-2001 07:20 PM
0-60mph time on 92 Legacy turbo!!! Ben Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 04-02-2001 05:55 PM
G-tech Pro Result on 92 Legacy Turbo!! Ben Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 04-02-2001 09:31 AM
