Old 04-17-2003, 12:48 PM   #1
STR8OUT
Member#: 15533
2010 Dodge Ram Hemi
boat, dirt bikes, bobcat
Default Need help! Perrin Fuel rails installed but I need help with Fuel Evap Line
Hi,
Thank you for looking because I seriously need some help with all these fuel lines. The fuel feed and fuel return lines are fine. My problem is with the Fuel Evap line.
Here is my question:
Does the Fuel Evap line (hose) connect from that blue plastic hose on the firewall and then run to the blue nipple on that thing next to the alternator?
Also, Did you just disconnect the factory hose that was on that blue plastic hose and then run a 1/2" hose directly from that blue plastic hose to the blue nipple?
Please let me know. Thank you so much in advance.
Best regards,
-Brian
ps. The blue nipple is next to that red cap on your alternator. The blue nipple is also connected to some other things since it is a "T" shape.
STR8OUT is offline   Reply With Quote
Old 04-17-2003, 03:24 PM   #2
STR8OUT
Member#: 15533
2010 Dodge Ram Hemi
Going to get hoses today after work. If ANYone will chime in, I'd appreciate it.
Thanks!
Old 04-17-2003, 05:28 PM   #3
AZScoobie
Member#: 8785
02 c_turner@ix.
netcom.com
Default Re: Need help! Perrin Fuel rails installed but I need help with Fuel Evap Line
Originally posted by STR8OUT
Hi,
Best regards,
-Brian
Brian, Just follow the stock Evap line. It runs from the firewall to the stock rails and then under the manifold to the Evap solenoid. You have the right idea but you can just follow the stocker to make sure.
CT
AZScoobie is offline   Reply With Quote
Old 04-17-2003, 10:52 PM   #4
STR8OUT
Member#: 15533
2010 Dodge Ram Hemi
Thanks AZ, you always seem to be really kind and help out when people are in need. We appreciate that.
As for my stock rails, they are gone. I tossed them after I installed my Perrin Rails.
Can you confirm that all I have to do is run a hose from that blue plastic hose to the blue nipple thing near my altenator?
Thanks so much.
-Brian
Old 04-18-2003, 12:11 AM   #5
AZScoobie
Member#: 8785
02 c_turner@ix.
netcom.com
Thanks so much.
-Brian
Thats what we did on my car.... it should work just fine. We ran the line under the manifold to hide it.
CT
Old 04-18-2003, 10:41 AM   #6
STR8OUT
Member#: 15533
2010 Dodge Ram Hemi
Superduper,
Thanks man, I'm gonna run it tonight.
You are the man.
-Brian
Old 04-18-2003, 01:01 PM   #7
TypeRex
Member#: 7204
2002 WRX Wagon
WRBP
Default yes
Yes, what AZscoobie said.
TypeRex is offline   Reply With Quote
Old 04-18-2003, 01:11 PM   #8
IA Performance
Member#: 25194
2008 Forester XT 5mt
Dark Gray
I did like wise on my car too. I don't have any pics of that area though, you should really look at some pics of the front side of the manifold since there are several boost looking hoses that all come together at one point.
IA Performance is offline   Reply With Quote
2005 STI - Perrin Fuel Rail install help needed (Looking for Picts) dexterous Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 47 11-09-2010 03:38 PM
Help with Fuel rail install, injectors loose noonagon Newbies & FAQs 1 02-28-2009 07:10 PM
perrin fuel rails install question. Which lines where? skate enjoi Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 09-23-2008 07:41 PM
Perrin Fuel Rail Install WRXThis Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-10-2002 06:25 PM
Perrin Fuel Rails Installed (lots of engine pics) DanMan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 07-08-2002 01:28 AM
