Old 04-17-2003, 12:25 PM   #1
vladn
Member#: 35369
1997 Legacy Outback
Unhappy blown HG, pls. help finding mechanic in NJ
My car engine (EJ25 DOHC) developed symptoms of blown HG - periodic overheat, traces of oil in coolant, CEL with 4th cylinder misfire.
Could anyone suggest a shop in NJ (northern / central) that can do HG replacement for a reasonable $. Subaru dealership quoted $2.5k for HG (parts+labor) which is IMHO way out of line (40hrs ?!?!).
Please help !!!
Vladimir Novichkov
vladn is offline   Reply With Quote
Old 04-17-2003, 12:30 PM   #2
Puckaveli
Member#: 1518
00 2.5RS
The only place I can think of is Rallispec.
Puckaveli is offline   Reply With Quote
Old 04-17-2003, 01:05 PM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
If you post in Tri-State you might get some help. Are you sure that's just for a head gasket and not a complete head replacement?
Old 04-17-2003, 01:15 PM   #4
vladn
Member#: 35369
1997 Legacy Outback
Contacted rallispec already - they responded that they no longer do regular maintanance/repairs :-( due to high demand for performance/tuning work.
The quote from dealership was for HG job, maybe I should try few more places just to make sure. There is always DIY option but it's well beyond what I've done in the past.
Old 04-17-2003, 02:50 PM   #5
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
Default Re: blown HG, pls. help finding mechanic in NJ
A new shorblock would cost you less money. 40 hrs is rediculous, you may want to check with other dealers (even if they aren't near you) and compare quotes... if dramatically different call SOA and file a complaint. The torque specs are easily found online and the procedute isn't that bad. Any shmuck-o mechanic can do it, just make sure you torque everything correctly.
Old 04-17-2003, 03:26 PM   #6
vladn
Member#: 35369
1997 Legacy Outback
40hrs was my guess based on $2.5k quote and parts being <$150 (again my guess). I've seen posts suggesting that you have to pull the engine out if it is DOHC to change HG (even if that is not true for someone who is familiar with the procedure it is probably needed for a first time try).
Old 04-17-2003, 03:30 PM   #7
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
IIRC you can do the procedure with the engine in the bay but it is much easier to work on once removed.
wanted: mechanic in NJ bruno Tri-State Area Forum 5 12-02-2005 01:01 AM
Looking for a Mazda tuner or mechanic in NJ 02rex Tri-State Area Forum 2 11-28-2005 09:12 PM
blown HG, pls. help finding shop in NJ vladn Tri-State Area Forum 1 04-17-2003 10:24 PM
Subaru Performance Mechanics in NJ petros Newbies & FAQs 3 10-05-2001 07:25 PM
help finding apartment in San Diego Sin Southern California Impreza Club Forum -- SCIC 5 06-24-2001 03:39 PM
