Old 04-17-2003, 03:32 PM   #1
xtrred
Member#: 23237
2002 wrx wagon - bye
07 yaris - 45mpg so far..
Default New RS wheels ---->> WRX ...
Does anyone know if the newer model RS wheels will fit (offset, width, etc. ) on a WRX? I know that the older style rims will fit, but how about the newer ones? Thanks.....
xtrred is offline   Reply With Quote
Old 04-17-2003, 04:54 PM   #2
Takashi
Member#: 2536
2012 STi Hatch
in a word, yes.
don't know the offset or dimensions, but they should fit. imprezas are standard accross the board, +53 offset. the only thing is i don't know if they have the same brake sizes. if for some reason the wrx has larger stock brakes (which i doubt), then the rs wheels may not fit. but i doubt that is the case...
i'm pretty sure they have virtually the same stock wheels...
greg
Takashi is offline   Reply With Quote
Old 04-17-2003, 06:27 PM   #3
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
PLEASE do not make 'blanket' statements like this- the +53 offset doesn't hold true for every rim width! That being said, the 98-01 RS wheels are all 16" by 7", +53 offset. They will fit on the WRX fine- it's still an Impreza . The WRX has larger rotors (4 pot size) but retains the same two piston front caliper size the old school RS has. The old school RS rim's 7" width leaves more room for brakes than the stock WRX 6.5" wide rims, and you need a set of them (or a set of similar 7" wide rims) to fit say a Subaru 4 pot brake caliper.
Brian
Old 04-17-2003, 07:17 PM   #4
Takashi
Member#: 2536
2012 STi Hatch
my mistake... i was refering to the fact that from 1998-2003, the 2.5RS and, more recently, the WRX have come from the factory with wheels that have a +53 offset. meaning that the new 2.5RS (MY02-03) should fit a WRX.
greg (hoping he's not wrong about it this time... )
Old 04-17-2003, 07:57 PM   #5
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
If your talking about the bug eye 2.5 RS, yes the wheel will fit. They are the exact same wheel. There is no difference.
mbiker97 is offline   Reply With Quote
Old 04-18-2003, 12:43 AM   #6
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
This thread is moderately confusing me. Do the 04 WRXs come with 4pots?
ss
subysouth is offline   Reply With Quote
Old 04-18-2003, 08:00 AM   #7
xtrred
Member#: 23237
I thought they were cosmetically a little different, like "larger" spokes without the small space in between.........
Old 04-18-2003, 11:39 AM   #8
Takashi
Member#: 2536
2012 STi Hatch
ss
okay, i take responsibilty for the confusion...however, i don't know. my interpretation of brian's thread is that the wrx has large 4pot-sized rotors, but has 2pot calipers. so that means that the wrx does not have 4pots (?). okay, so my question is, does that mean that to upgrade to the sti 4pot front brakes, would i only have to get the calipers?
greg
Old 04-18-2003, 10:12 PM   #9
khail19
Member#: 14489
2005 FXT 5 spd
Cayenne Red
02 and 03 2.5RS and WRX wheels are identical. 16"X6.5" with a 53mm offset. The ones you are talking about sound like the wheel covers that come on the 02-03 2.5TS, which is the wagon version of the RS. They use steel wheels with plastic covers that look like you are describing. And then there's the 02-03 Outback Sports, which I believe also use a different wheel, but I'm not sure if it's a 15 or 16 inch.
Khail
khail19 is offline   Reply With Quote
Old 04-18-2003, 11:13 PM   #10
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
greg
If you have a WRX yes all you need is the calipers to use the 4pots. You already have the rotors.
ss
Old 04-19-2003, 07:40 PM   #11
Samirr76
Member#: 4835
2003 Baja 5MT
Yellow w/ 220,000 miles
This thread just made me a little more dumber.
Samirr76 is offline   Reply With Quote
Old 04-20-2003, 12:38 PM   #12
blueimpreza25rs
Member#: 21821
2004 Fxt
Psm
02 RS wheels = 02 WRX wheels
blueimpreza25rs is offline   Reply With Quote
Old 04-20-2003, 02:58 PM   #13
Takashi
Member#: 2536
2012 STi Hatch
no applause please
RS Wheels on a WRX? bjteel Brakes, Steering & Suspension 28 08-05-2002 02:00 PM
Pictures of 98-01 RS wheels on a WRX? Neil Wallerstein Brakes, Steering & Suspension 8 08-04-2002 11:55 PM
2001 RS wheels on a WRX???? StarDogChampion Brakes, Steering & Suspension 5 01-21-2002 09:24 PM
Color for 00-01 RS Wheels on my WRX? [freeman] Interior & Exterior Modification 7 11-26-2001 07:14 AM
rs wheels on a WRX? racerwad Brakes, Steering & Suspension 8 06-03-2001 11:19 AM
