#1 |
Member#: 29825
Vehicle:2002 WRX Wagon WR Blue |
Hello,
I FINALLY got a WRX after lusting for one since they came out. I have a few questions about taking care of it. Polish has mild abrasives and does something to the paint. Doesn't that mean that frequent use will degrade the paint? Since my 2002 still looks new, it seems to me that I should just wash and use pure wax, not polish or cleaner wax. My thought is that if it still shines I shouldn't start polishing away good paint. One other question. Right now I'm planning on using Prestone High Protection Wax (a synthetic wax). Does anybody have any advice on whether this is a good or bad idea? I chose a synthetic because I don't want to have to wax it frequently and I don't mind if the shine is not optimal. Thanks!
#2 |
Member#: 33915
Vehicle:2003 Impreza 2.5RS silver |
pure polish is just a pure polish...shouldn't have abrasives in them. a paint cleaner, on the other hand, is abrasive.
almost all waxes are synthetic polymer blends. there is no pure carnauba wax out there, because pure natural wax is cement hard. so go ahead and polish and wax away. |
#3 |
Member#: 5885
NWIC
Vehicle:2000 RS (GME) SilvAr |
There may be detailers, whos' oppinion may differ, but I'd say if the car is less than 3yrs old then the use of a cutting agent is more likely to harm than to heal the topcoat (likely a clearcoat). Best bet, deep clean with claybar annually or semiannually. And use clean, high quality cloths (microfiber) with everything that touches the car. Think about very infrequent (every couple of years) use of a fine cutting agent only after its 3rd or fourth birthday.
- Ken |
#4 |
Member#: 29825
Thanks for the advice guys.
What wax/sealer do the two of you recommend, given that it's a year old car? |
#5 | |
Member#: 33915
for polish, the meguiar's consumer line in the red bottle is easy to use...if i get bored w/ that i usually use 3M. For wax, there's an even bigger selection. Meguiar's Gold Class Liquid wax gives a very reflective finish that is nice but IMO there is very little "depth" to its shine (i know, im very picky). Some people swear by Zaino products. and once again, Meguiar's Medallion wax and 3M i like as well. |
#6 |
Member#: 33249
South East
Vehicle:2003 WRX (white) aka Little John |
If you want the absolute best but a real pain to apply get Zaino Bros wax http://www.zainobros.com/ . Use all cotton white towels (I dont touch my car with anything less)good quality ones like Fieldcrest or Cannondale, then cut off all the designs and edges so you wont take a chance on them marking up the paint/clearcoat.
If you want to just take the easy route, go to your local paint shop or call around to see if they offer teflon coating. I can get it around here for about 150 and you dont have to wax your car for a year. Makes it a hell of alot easier to wash too. ![]() |
#7 |
Member#: 30050
Vehicle:2009 STI |
I owned a detail company in CA and used nothing other than Production Products. Nothing comes close. Nothing. Ask any top-down restoration body shop or professional detailer. I did exotics almost exclusively and couldn't run the risk of using even "good" products. Only the best with Production
There's a distributor based out of Oakland, CA you could look up. And stay away from cutting cremes and polish right now. You won't need that for at leas a year (depending on where you live/sun exposure/garaging, etc...). And for future reference, PLEASE, for the love of all that is scared, stay away from claying. I can't tell you how many high end vehicles I worked on that had fallen to a nasty "claying". A good wash, a good wax...keep that up for now and you'll be more than happy with the finish a Subaru can provide ![]() Hope that helps. T. |
#8 |
Member#: 33249
South East
So even supposedly using a clay bar to remove "rail dust" form the paint is a bad idea?I got 3500 on mine and I can see the little rusty brown spot where it's embedded in the paint.
#9 |
Member#: 30050
Vehicle:2009 STI |
I'd have to see what the blemish looks like, but as a general rule, using clay is a serious last resort, last-ditch effort, it's always a no no in my book though. Clay can be used be someone who knows how to handle it, lubricate it with the right products, apply and "slide" it correctly for problem childs like paint overspray and extremely embedded particles/faded paint/older vehicles. Clay should not go anywhere near a new/er vehicle. A good cutting creme and/or synthetic polish can eliminate virtually ANY blemish a "new" car may have.
Clays, until now, have always been used by body shops to remove paint overspary. Think about what that means. Try a good cutting creme or a good polish, applied in the shade, 50-80 degrees, on cheesecloth or a diaper cloth. Buff it out (and another NO NO - forget machines-if you're as anal as I am, you'll understand machines with fast rotating blades and fine finishes shouldn't come within 100 yeard of eachother). Apply a good dose of wax, apply, take it off, wax again...paint should look better than when you got your car from the dealer ![]() Hope that helps. T. |
#10 |
Member#: 33249
South East
yeah I've tried cleaner wax might try a polish next, it looks just like it sounds, little brown specks thta dont wash/wax off all over, mostly on front and back. And you can feel it when you run your hand over the paint.Not glassy smooth like it's supposed to be
#11 | |
Member#: 30050
Vehicle:2009 STI |
Using cotton is ok, but the weave pattern in most cotton towels can actually scratch paint. Also, never wash the towels in anything more than 1/4 cup detergent/washload, and NEVER use bleach. Just hot hot water. Use diapers. Use cheesecloth. The towels you mention are usually good for interior dressing and that's about it (by my book). 0260 - do not waste your $ on "teflon" coatings. Nothing can replace tlc and good products. Teflon doesn't sound like something you'd want coating your car anyhow, does it? Seriously, Simonizing (sp)/Teflon, etc, is a complete waste of money. A good detail from a reputable company will do wonders for your finish, while things like Teflon may harm the finish over time. Keep teflon on your frying pan and away from your cars finish ![]() T. |
#12 | |
Member#: 30050
Vehicle:2009 STI |
Clients were sometimes perplexed to find out all I had done to restore a finish was simply apply some good wax with some good 'ol elbow grease ![]() |
#13 |
Member#: 33249
South East
ok on the other point about the weave of cotton towels , lightly buffing with the nap there shouldn't be a weave right? And the nap helps keep the wax and stuff up away from the paint?Thought thats why your supposed to use em.
#14 | |
Member#: 30050
Vehicle:2009 STI |
If you have already been using terry towels or 100% cotton towels, now would be a good time to switch. Once you make the change, the advantages will be visible after your first detail. T. |
#15 |
Member#: 30050
Vehicle:2009 STI |
0260
pm'd ya |
#16 |
Member#: 5885
NWIC
Oh man! I'm must be behind the times. I hope I'm not hijacking, but how can something that feels as good as claying be as evil as described above...or is it dependent on brand and technique. And some of you more experienced here may advise on high-end microfiber vs cotton, in terms of safety. Ignore me if I'm hijacking. Thanks.
-Ken |
#17 |
Member#: 29825
I hope you guys don't mind all of the questions; I'm learning a lot.
I'm still curious to know what people think of synthetics. Dr. Ken's latest post reminds me of something else I wanted to ask about. I have seen people say that technique is more important than products. What is good technique? For example, is buffing more about pressure or repetition (how many times it's wiped back and forth) Thanks |
#18 |
Member#: 26654
Vehicle:2003 Impreza WRX Silver |
this is the best site evAr for washing tips http://www.properautocare.com/ , also another good thing to use is a pure sheep skin mit, its VERY soft and actually pulls the dirt deeper into the mit so it isnt grinding on your paint
#19 | |
Member#: 33915
Dr Ken: as for clay bar-ing and abrasives, think of it this way...every time you use it, you are thinly taking off the top clearcoat to expose a clean coat below it. automotive paint is applied in very very very thin mm's. clearcoat is no more than .04mm, so after clay baring and wet sanding and using abrasives over and over, you will just have no more coating left. RhinoRex: buffing something out is more about finding a fine line between pressure/heat and repitition....on a d/a or other non-orbital machine, you really don't wanna let it heat up too much. if you are referring to 'buffing' as in using an orbital buffing machine to polish/wax your car, then as long as you don't get too crazy about how long you've buffed one spot, you should be ok. you can visually see if there is enough polish/wax on the car or not. |
#20 |
Member#: 29825
I actually meant buffing by hand. I'm never sure what to put more effort into.
#21 |
Member#: 8302
Vehicle:2002 WRX WRB Sold! 2006 Scion TC-T |
1 coat meguiars show car glaze (polish)
1 coat meguiars or Zymol carnauba wax. Makes the car look absolutely beautiful every time. You only have to use the glaze 2 times a year. Wax every month to two months. |
#22 |
Member#: 29825
In terms of wax choice, this is exactly what I want to avoid (waxing every 2 months). I'm trying to figure out what's the most durable and doesn't harm the car.
| Thread Tools | |
| Display Modes | |
| Deodorant, when is it too old to use? | rice h8r | Off-Topic | 12 | 10-25-2009 10:23 PM |
| Why is it so hard to find polishing pads???? | toofast4u | North West Impreza Club Forum -- NWIC | 8 | 07-20-2009 04:51 PM |
| Is it OK not to get an alignment for a while? | joker11 | Brakes, Steering & Suspension | 5 | 03-15-2008 09:30 AM |
| Installing raamat is it better to use big peices or small on the inner door? | Dub02 | Car Audio, Video & Security | 2 | 11-17-2007 02:43 PM |
| is it wrong not to tell anyone about several vendors are scamming or dont really know | STEALTH-WRX | Off-Topic | 19 | 06-26-2003 03:28 PM |
