#1 |
Member#: 15359
I apologize if this topic has been brought up before. I've done a search but couldn't find exactly what I was looking for. I own a 2002 WRX and am in the process of buying a 2000 Forester. Looking around my garage the other day I noticed that I have an awful lot of WRX parts lying around. I was curious on the feasibility of turboing my forester with the stock turbo from the WRX.
I have searched for information on the Forester chassis, but I need confirmation on the following points. Will the turbo legacy or WRX crossmember fit on the forester. I have or am buying the following parts. Any suggestions for other things needed would be helpful. I don't mind bleeding the WRX for parts, it's going in the garage for awhile as I save up for a turbo, intercooler, etc for it. Well, here's my current list. WRX manifolds vishnu uppipe (making a spacer is no problem, work in a machine shop). WRX downpipe and catback WRX turbo WRX intercooler ( don't mind modifying it, see above comment about machine shop ) Voltage clamp for the MAP RRFPR J&S safeguard. I assume that I can use the WRX fuel pump. Water pump off WRX. I would also assume that doing the parallel fuel rails mod off scoobymods would also be advisable. What other hoses and fitting would I need. I'm aware that I would need to run oil lines from the high pressure side of the motor to the turbo, and then return to the block. I assume I will have to buy new hoses for this purpose. i couldn't find by searching what I should do with the coolant hoses. Are there any other fittings that I would need to make this project work?
#2 |
Member#: 6816
Vehicle:01 yeller wrx triumph tiger,klr,cb900f |
Just like turbo'ing an RS. Move this to aftermarket induction for all the right answers...
Ed |
#3 |
Member#: 1031
Vehicle:2002 WRX Blue |
Not to start ruhmors, but subaru is going to offer a turbo version of the froester and baja soon....
#4 |
Member#: 7453
TXIC
Vehicle:2005 Legacy GT Wagon 2006 LJ Rubicon |
If by rumors you mean things that Subaru of America has already announced and shown then you are correct.
And I agree that you'll probably get more/better answers in the Aftermarket Forced induction forum. |
#5 |
Member#: 15359
I posted it there, but someone moved it here. I've pm'd a moderator in aftermarket forced induction to have it moved back. td04 must of set off some flag.
-Duncan |
| Thread Tools | |
| Display Modes | |
| Forester Guru Needed - Stock TD04/Service Manual | denn | Factory 2.5L Turbo Powertrain | 6 | 12-09-2008 02:34 AM |
| 2.5rs with 2001 forester engine +td04? | b-man1 | Normally Aspirated with bolt-on Forced Induction Powertrain | 0 | 04-08-2008 11:36 AM |
| Forester td04 needed | Tadsmith | Private 'Wanted' Classifieds | 2 | 04-01-2008 07:59 AM |
| NY FS: TD04 Turbo, STi short shift kit for the Forester. | Zumble | Private 'For Sale' Classifieds | 3 | 02-02-2006 02:53 PM |
| TD04 and 04' Forester 2.5XT ECU- both 6k mi! | adamnquickcivic | Private 'For Sale' Classifieds | 2 | 02-23-2005 06:26 PM |
