#1 |
Member#: 34810
Vehicle:2005 Legacy GT Garnet Red |
ok, i'm considering getting the performance guage package (oil temp, boost, and volt) when i order the wrx. my question is, are these gauges decent? or should i look for a different set?
if so, what do you guy's recommend?
#2 |
Member#: 33979
Vehicle:2006 STi,'11 OBS WRB & Black/Silver |
Not even close - my biggest regret agreeing to pay for the gauge pack. Save the money and get better gauges for the same price. Get a 45mm or 52mm boost, EGT and either an oil temp or pressure in imperial units for the center. Or even better get a 45mm boost for the column (lots of people have been replacing the lameco's with the Omori) and get EGT, oil and whatever as the third one for the center pod I personally like having an intake temperature gauge.
Thaison over at J-Spec sells 52mm gauges that match the dash board lights unlike the lamecos that don't and also a 1 din gauge face that will fit in the pod. You can buy the pod by itself from several places or better a CF one from Thaison as well. His info: http://www.j-spectuning.com/omori.htm sales@j-spectuning.com 408-772-9719 Ed. |
#3 |
Member#: 34810
thanks. just wondering though, what's bad about the oem gauges?
#4 |
Member#: 33979
They seem fine overall, but overpriced and some genuis at Subaru decided to make them with red needles and a white backlight instead of the yellow needles and green backlight that the instrument cluster has. It is a question of whether or not you get value for the amount of the option charged, I don't think so. However, if right after you get the price you want on the car you can get the price of the gauges reduced it may be OK for you.
#5 |
Member#: 13634
NESIC
Vehicle:2002 WRX WRB |
heard way too many oil temp probes go bad, either the probe or the gauge itself, volts gauge i don't feel is important at all, the boost gauge is ok but for the same price you can get really fast responding gauges.
#6 | |
Member#: 5887
BAIC
Vehicle:2002 GDAA 797 |
That's a nice freudian slip.On a serious note, I agree with jehcpa, one would expect a nicer looking set of gauges for the price. There's also something odd imho about placing a boost gauge rather far from the center of your field of view. |
#7 |
Member#: 33979
If only it had been fruedian
rather than an intended pun!I control my subconscience dang it! Really, though rNF it is not the gauges in and of themselves you can just do much much better for the price. I agree unless you plan on loading up your electrical system (:cough: rice) why did they even bother putting a volt gauge in. The boost gauge is far too small for its location. And you would think by now the rest of the world would understand that us arrogant Americans are not going to metric. I mean nPA, give me something that is intuitive to my culture like PSI and I am sorry but I get concerned when my oil temperature is only 100 degrees. Doh! its celius so it is a normal temperature. Sorry, I have had my pod for about 3 months too long and I won't have it replaced for another couple weeks so I am frustrated. At half the option listed price - it is almost worth it. |
#8 |
Member#: 18642
Vehicle:2005 Impreza WRX STi |
You can build your own set up, or if you don't feel confident doing that. These guys have some pretty good set ups at www.wrxtra.com Check out their catalog page.
Much better stuff for less money than Subaru. I did my own using a factory Subaru pod and Autometer gauges, including an EGT gauge with a competition type probe about $150 less than the Subaru gauge pack cost. Subaru should at least have put in an Ammeter or an EGT, but I guess they were interested in ease of installation by the dealer. G |
#9 |
Member#: 21248
i vote for Defi BF gauge.
| Thread Tools | |
| Display Modes | |
| OEM Subwoofer, is it worth it? | Jonesy08054 | Impreza Forum | 8 | 10-12-2009 09:46 AM |
| Are cheap gauges worth it | VideoGameWrx | Factory 2.0L Turbo Powertrain | 15 | 08-15-2004 03:32 AM |
| Omori gauges worth it | Subdav | Car Part Reviews | 57 | 11-06-2002 05:38 PM |
| OEM foglights worth it? | smallschip | Interior & Exterior Modification | 1 | 04-30-2001 11:43 PM |
