Old 04-17-2003, 08:56 PM   #1
a2cpc
Member#: 10139
WRX 09 Outback 15
Miata 93
Question Tire pressure help
I need some advice. I just put a set of Kumho 712's on some older Impreza rims. They are 215/50/16s. There is an autocross in Indy next weekend I would like to do. Does anyone have any expirience or thoughts for tire pressures for this setup? I drive an '03 WRX Wagon. I was running 48psi front and 42psi rear with my RE 92's. Any help will be appreciated.
Chris
a2cpc is offline   Reply With Quote
Old 04-19-2003, 01:24 PM   #2
a2cpc
Member#: 10139
WRX 09 Outback 15
Miata 93
No One???
Old 04-19-2003, 02:25 PM   #3
WRXpkr
Member#: 13607
82 Suzuki GS 1100E
Gold-ish
Id ask someone @ the autoX when you go next weekend.
Im sure if you bump this on monday youll get responses.
The only advice i have is to make the difference front to rear 3 or 4 lbs instead of 5... then again it might not matter too much really.
Also, from reading Porter's thread on tire pressures you should know that it comes down to a few things, you need to find out what you like, and how to set the tires up to suit your style...ect...
Good Luck!
Trent
WRXpkr is offline   Reply With Quote
Tires Pressure, HELP! Sabre06 Tire & Wheel 33 05-18-2010 12:44 PM
Tire Pressure Help Please necratis Newbies & FAQs 1 09-24-2009 11:43 AM
Tire Pressure Help!!! Nads07 Tire & Wheel 14 03-12-2006 02:52 PM
tire pressure help Drowner Tire & Wheel 5 09-14-2004 11:02 AM
Tire pressure help Qbushido Tri-State Area Forum 2 08-02-2002 12:44 PM
