Old 04-18-2003, 04:02 AM   #1
2.5RSMatt
Member#: 30497
00 RSTi
FUK HDR
Default Anything I should know before installing my COBB intake?
So my intake is a few days away, which means about 2 weeks and I want to know if there is anything specific I need to do once I have installed it.
I'm guessing resetting the ECU would be one thing to do, have I to worry about anything? Or is it straight forward?
Thanks.
-Matt
2.5RSMatt is offline   Reply With Quote
Old 04-18-2003, 02:32 PM   #2
imprezey
Member#: 17178
2001 2.5RS Coupe
Silverthorn Metallic
do the ecu reset after you install it.
imprezey is offline   Reply With Quote
Old 04-18-2003, 04:16 PM   #3
2.5RSMatt
Member#: 30497
00 RSTi
FUK HDR
yeah, i sorta figured after would be better than before
Old 04-18-2003, 04:38 PM   #4
JC
Member#: 692
2011 Grand Cherokee
Triumph Speed Triple R
You could do it before if you just didn't drive until you put the intake on.
Install is pretty straight forward. Put mine on today took ~10min. I'm using a catch can though, most of the time was fighting with that. Should take you ~30min.
JC
JC is offline   Reply With Quote
Old 04-19-2003, 02:26 AM   #5
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
JC
30 minutes?! I didnt know you were that slow JC
Old 04-19-2003, 03:50 AM   #6
imprezey
Member#: 17178
2001 2.5RS Coupe
haha, sorry for that post. i was hella tired and read it wrong. have fun with the cobb.
Old 04-19-2003, 07:03 AM   #7
dRu888
Member#: 8305
2001 2.5RS
Gunmetal
watch out for a pointy metal thing... that used to be a brace for the stock intake i think.... that pokes at the filter
...i put a piece of hard plastic to protect my filter
dRu888 is offline   Reply With Quote
Old 04-19-2003, 08:36 AM   #8
obyone
Member#: 16523
I used some Velcro patches (the furry sides) to protect my filter. It works pretty well but the brace mount will eventually eat it away. The only real solution is to bend that mount away from your intake.
obyone is offline   Reply With Quote
Old 04-19-2003, 11:38 AM   #9
JC
Member#: 692
2011 Grand Cherokee
It took me 10min, I said it would take him 30min. Seriously though, if you have small hands putting on the tubing should be easy and the install would go fast.
dRu888
I took it off (as per the instructions I might add).
JC
Old 04-19-2003, 04:15 PM   #10
joefocker20
Member#: 13745
2015 STI
Before you start the install, disconnect your negative battery cable, and when you're finished hook it back up. Kill 2 birds with one stone
joefocker20 is offline   Reply With Quote
Old 04-19-2003, 07:47 PM   #11
dRu888
Member#: 8305
2001 2.5RS
Gunmetal
pSh..instructions? Instructions r for losers =P
I had a shortram before so when I got the cobb I just stuck it on...did you take off that whole bracket thing? I didn't want to mess with it too much...
Old 04-20-2003, 02:30 AM   #12
RokketRide
Member#: 17984
1967 Barracuda
2000 OBSTi
Oh yeah take off all the bracket thingies. The two stantions coming up from the engine that hold the stock airbox. It really cleans up the look of the engine compartment.
RokketRide is offline   Reply With Quote
Anything I should know before installing SPC's camber bolts? eastcoastGC8G Brakes, Steering & Suspension 5 03-02-2010 09:20 PM
Anything I should know before Turn Key 98rsblues Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 03-25-2008 02:01 PM
Anything I should know before I swap this DVD-ROM for my other one? eurojax Off-Topic 10 04-05-2005 09:01 AM
Any Tips or Things I Should Know Before Installing OEM WRX Rear Lip Kit? clsmooth71 Interior & Exterior Modification 9 04-25-2003 12:18 PM
('93-'01) So I just installed my Cobb intake 2.5RSMatt Impreza Forum 12 04-24-2003 02:10 AM
