Old 04-18-2003, 11:19 AM   #1
dmross
Member#: 2818
2000 2.5RS
Angry Hesitation at 4K (another case)
Wow... I am surprised to find so many reports of the 4K hesitation problems. I have a MY2000 2.5RS with 52,000 miles and I just started noticing the hesitation problem around 4K. As with everyone else, it isn't too bad and only happens sometimes and to make it worse, I just got the car back from having it serviced (the 52k mile service).
I just spent a ridiculous amount of money getting some bad problems fixed (one of my wheel bearings was so screwed up that my front left wheel could move an inch in and out) and I would like to be able to fix this myself without spending too much.
I checked the wire plugs for any corrosion and can't seem to find any. Based on the other threads, I plan to do the following:
1. Check/replace air-filter (I am replacing it this week anyway)
2. Check/replace coil pack for corrosion
3. Check/replace fuel filter
4. Reset ECU
Does anyone have any other suggestions to add to this list?
Thanks...
dmross is offline   Reply With Quote
Old 04-18-2003, 11:28 AM   #2
Monas
Member#: 31418
1999 2.5RS
you could try the Single Point Grounding Mod. i did that on my MY99 2.5RS and it seemed to help.
The hesitation is coming back but i think it has more to do with my exhaust leak and my MAF is starting to go.
Monas is offline   Reply With Quote
Old 04-18-2003, 06:24 PM   #3
RigdenZW
Member#: 4531
2001 2.5 RS Sedan
Silverthorne Metallic
Has your car had the ecu reflashed under recall?
Mine has. That's what fixed my hesitation.
RigdenZW is offline   Reply With Quote
another problem! strange hesitation at wot felixk Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 02-06-2009 06:49 PM
hesitation at 3k-4k rpm SubyBean Normally Aspirated Powertrain 6 07-24-2004 12:38 PM
what can be the problem. hesitation at 4k and a lot of popping. AzNStiImpreza Normally Aspirated Powertrain 14 10-17-2003 08:53 PM
Hesitation at 4k PRODRIVEN Normally Aspirated Powertrain 6 10-11-2001 07:07 PM
