Welcome to the North American Subaru Impreza Owners Club Friday October 21, 2016
Old 06-14-2001, 05:15 PM   #1
Member#: 2701
'00 obs
Post problematic wash points
anyone been able to solve any of the problems with water staying in the:
mirror assembly
panel under the taillights
headlight assy.
whenever i wash, its usually at night, when i drive in the morning, water magically seeps from these spots and leaves marks on the car because i have nothing to wipe it off with... =( oh, and something f-ed with my windows, i dry them, roll them down, roll them up, what do you know, they're wet, even after a whole night to let the water go wherever gravity/weather dictates
elemental is offline   Reply With Quote
Old 06-14-2001, 07:14 PM   #2
Dori Dori
Member#: 6780
1993 Nissan
You have a few options.
You could wash during the day and let it sit in the sun for a couple hours...the water won't dry at night, especially if you live in a humid area like I do (FL)
You could take your car for a fun ride after the wash to let everything drip out, then dry the the water when you get back home.
You could blow very hard into the problem areas, and the water will spray out (that makes me dizzy though)
I do my 2nd suggestion. As for the windows, either bring a little terry cloth w/ you to re-dry them, or let it sit in the sun. Hope I helped
Dori Dori is offline   Reply With Quote
Old 06-14-2001, 10:28 PM   #3
Member#: 5744
usually to get the water out of the mirrors on my honda, i open and slam the door 3 or 4 times and that gets most of it out... then blowing the rest out usually gets it all.
my tail lights leak a lot of water too, so i usually smack them with my towel to try and get the water out.. not too hard though. :P
actually im worried that one day i might smack it hard enough to mess up the bulbs, but oh well, hasnt happened so far! i guess the same would go for the headlights as well.
hope that helps!
Kagato is offline   Reply With Quote
Old 06-15-2001, 01:15 AM   #4
Member#: 6467
1999 Impreza 2.5 RS
i dunno about all the other stuff but for the mirrors you can drill a very small hole in the bottom (make sure you dont hit anything) this way most of the water that gets in there will run out. good luck
NateDogg is offline   Reply With Quote
Old 06-15-2001, 06:15 AM   #5
Member#: 7107
2014 Mustang GT
For detailing my motorcycles and cars I have always used a wet/dry vac with the blower attachment. I picked up a piece of non marring rubber for the end to avoid any scratches if I bumped my car or bike. After drying, simply blast the spots to drive the water out. I use a large craftsman wet/dry vac. Hope this helps
My other toy. Welcome to my world of 2 ticket getting modes of transportation! Weeeeee
[ June 15, 2001: Message edited by: Tex-WReX ]
Tex-WReX is offline   Reply With Quote
Old 06-15-2001, 06:21 AM   #6
Member#: 4925
You could just go for a quick blast down the street.
WRXING is offline   Reply With Quote
Old 06-15-2001, 06:43 AM   #7
The last time I tried the "High Speed Air Dry" (ie: driving it) method of drying my car, I ended up with bugs splattered all over my windshield, mirrors and hood. It was more fun than using a towel though
ABS, Airbag, and Rear Diff light on after washing engine Acejam2k Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 06-02-2010 12:32 PM
MY04 ABS still problematic? superb00b Brakes, Steering & Suspension 1 10-15-2003 04:11 PM
Lowering a Car More in the Front... Problematic? Fred C Brakes, Steering & Suspension 19 01-17-2003 03:33 AM
Solution for problematic replacement shifter/bushing combo's JayGold Transmission (AT/MT) & Driveline 4 03-24-2002 05:27 PM
