Old 04-18-2003, 08:13 PM   #1
Stickee
Member#: 530
2005 9-2x Aero
FastAr Red
Unhappy Help! Sparks between distributor cap and spark plug wires!
Here's the problem, I'm seeing and hearing sparks right where the distributor cap meets the spark plug wire for spark plug 1. The spark is coming from under the rubber of the wire.
Also, when driving, it seems to bog off the line, and I'm hearing pops from my exhaust, I normally hear pops from my Borla, but not to this extent. I usually hear a pop when switching gears or when letting off the gas, but now, it's just popping at idle.
Last thing, it's alot worse when the car is cold, I'm starting up for the first thing in the morning.
Anyone know what's wrong? And how I could fix it?
Oh yeah, MY99 OBS. 120k km (~70k miles). Catback exhaust w/Borla Turbo muffler. Removed snorkle. K&N air filter.
TIA
Stickee is offline   Reply With Quote
Old 04-18-2003, 08:35 PM   #2
orndog
Member#: 34670
2013 No gears!
Saltine American
Forgive me if I'm wrong, but we don't have a distributor, much less a cap for one, right? Distributorless ignition...
You have a cracked boot or a cracked coil pack, unless it's just loose. Check if it's loose, then pull the wire off (engine NOT running) and examine things. If all looks well, apply some dielectric grease around the inside of the boot and reinstall.
orndog is offline   Reply With Quote
Old 04-18-2003, 08:51 PM   #3
Stickee
Member#: 530
2005 9-2x Aero
FastAr Red
whoops. i'm no gear head. Here's a pic (not my engine, but you get the picture)
Old 04-18-2003, 09:28 PM   #4
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Switch two spark plug wires, if the sparks follow its the wire. Im willing to bet your coil pack is bad though.
Old 04-19-2003, 12:48 AM   #5
orndog
Member#: 34670
2013 No gears!
Saltine American
Should be simple to diagnose, as we have posted.
Brings up a good question, is an aftermarket coil pack worth the dough for a stocker?
Old 04-19-2003, 02:23 AM   #6
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
If you can find someone who makes an aftermarket coil pack for the Impreza, let alone any newer model Subaru, I would be very suprised. MSD didn't touch the old school late model Impreza (97-01) as they said something to the effect of the stock system being better than what they came up with .
Brian
Old 04-19-2003, 09:42 AM   #7
obyone
Member#: 16523
this anymore???
I don't want to hijack the thread, but since you guys are already here, I have a question.
When doing a tune up, do you have to change the coil-pack, or can you go with just new plugs and wires?
obyone is offline   Reply With Quote
Old 04-19-2003, 10:56 AM   #8
orndog
Member#: 34670
2013 No gears!
Saltine American
Just plugs and wires. A "real" tuneup would consist of checking the coil packs.
Old 04-19-2003, 02:53 PM   #9
Fred Zaplitny
Gone... But not forgotten
Member#: 92
1999 2.5RS Coupe
Blueish Kind of
Man, this has been a bad week for coil packs! Seems like everyday this week somebody has poted a thread like this.
Fred Zaplitny is offline   Reply With Quote
Old 04-19-2003, 03:50 PM   #10
Stickee
Member#: 530
2005 9-2x Aero
FastAr Red
This seems to have fixed the problem, if only temporarily. I'll probably get a new coil pack and/or new spark plug wires.
Thanks for all the input.
Old 04-19-2003, 05:17 PM   #11
obyone
Member#: 16523
this anymore???
How, with a multimeter or something?
Old 04-21-2003, 04:27 PM   #12
ciper
Member#: 15543
90BJ Legacy LS ABS
Pre 97 systems can use an external ingitor, like the MSD DIS-2 but later units have a combo unit.
Old 04-21-2003, 08:16 PM   #13
orndog
Member#: 34670
2013 No gears!
Saltine American
Stickee: No prob.
Obyone: Yep.
Old 04-23-2003, 12:23 PM   #14
BlueTDimly
Member#: 24475
1999 Forester L
Dirty
Stickee: a coil pack will run about $150, so you don't want to replace it if you don't have to.
BlueTDimly is offline   Reply With Quote
Help me settle this spark plug dispute between my mechanic and tuner! jsavage Service & Maintenance 19 07-15-2008 05:58 PM
NGK Spark Plug Wires and Distributor snowcrzy 1993 - 2001 Impreza Specific Parts 7 08-01-2007 12:19 AM
help oil on spark plug wires and scoobie Normally Aspirated Powertrain 6 04-11-2005 11:27 PM
spark plug wires? need help! motorswapsleeper Subaru Conversions 3 09-06-2003 08:58 PM
Someone Please Help me! (Need Stock Spark Plug Wire ASAP!) BrysImpreza New England Impreza Club Forum -- NESIC 3 04-23-2002 09:58 PM
