Old 04-18-2003, 08:20 PM   #1
SCOOBER
Member#: 223
1999 Impreza 2.5RS-T
Default Oil/Coolant connections for turbo
I have seen a few ways people have done this, but I wanted to see if anyone else has input on the connections for the oil and coolant lines to the turbo on a 2.5 motor. I don't think taking my pan off to tap it is a good idea....I live in Cleveland and the bolts look pretty small and rusty....which could translate into broken bolts in the bottom of my block...not something I have time to deal with at this stage in the game.
Anyway.....show us some pics of the hookups for the turbo cooling and maybe what lines you used / where you got them!!
Thanks,
Doug
Soon to join the RS-T forces!!
SCOOBER is offline   Reply With Quote
Old 04-19-2003, 01:13 AM   #2
Mancini
Member#: 20726
Tapping the pan is probably easiest. I think some other people have tapped a cylinder head. But you might want to try to get the bolts off the pan. I have a 98 and mine came off with very little effort. I think they are only torqued to 10 or 11 lb ft.
Mancini is offline   Reply With Quote
Old 04-19-2003, 09:44 AM   #3
Revision
Member#: 242
MY05 PSM GGA !STOCK
MY99 RS-RIP / MY95 MX-5
Tap the pan, its easy!
Revision is offline   Reply With Quote
Old 04-19-2003, 12:08 PM   #4
Mancini
Member#: 20726
What I did was use a -10 AN bulkhead fitting. Drilled a hole then used a dremel to widen it just enough to get the threads to fit through. I used the dremel to cut off the set of thread on the inside of pan. An I put the nut on the outside of the pan. I used a healthy helping of rtv to ensure no leaks. So far I've had non.
If you don't know what a bulkhead fitting is look here...
http://store.summitracing.com/partde...t=EAR%2D983210
The side with two sets of threads is for the nut and the -10AN return line. The other side is inside the pan with the thread cut off. The plate is on the inside and the nut on the outside hold it together.
need upper coolant line for turbo t4nk AKIC Private Classifieds 0 09-13-2008 04:53 PM
FS OH: WRX oil pan tapped for Turbo oil return AWDrivin Engine/Power/Exhaust 3 08-07-2006 09:37 PM
Water connections for turbo? bugeyes Subaru Conversions 3 12-22-2005 02:13 PM
Removing coolant reservoir for turbo... Joey_WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-18-2005 04:44 PM
Coolant source for turbo Boostup! Normally Aspirated with bolt-on Forced Induction Powertrain 27 05-10-2002 08:08 AM
