Welcome to the North American Subaru Impreza Owners Club Friday December 19, 2014
Old 04-18-2003, 09:38 PM   #1
AnimalMother
Member#: 11835
2004 Honda Pilot
Dark Blue
Default Ground Control / Koni vs. coil-overs
I'm wondering, does anyone have any experience/opinion on what would be best for a daily-driver/autox/occasional track day suspension...focus is on strut/spring/top hat and this is for onroad stuff only...no DMS rally struts, or anything over 2K, etc. Autocross would obviously be in STX or beyond.
I'm leaning towards the Koni insert, Ground Control and MRT camber/castor plate front and camber plate rear. How do you think this would compare versus say a Tein FLEX setup or even JIC or other under $1800ish coil-over? I KNOW Koni is great, and I know it is only single-adjustable...what about these other brands?
I searched around but didn't find much...thoughts? If this has been discussed, please point me in the right direction.
AnimalMother
AnimalMother is offline   Reply With Quote
Old 04-19-2003, 12:00 AM   #2
slater
Member#: 5848
1992 vw corrado vr6
silver w/ schrick/quaife
cosworth is your man, he has that identical setup. PM him.
peter
slater is offline   Reply With Quote
Old 04-19-2003, 01:05 AM   #3
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
The Koni/GC/MRT setup is exactly what I'll be going with. I have a similar setup on my Mustang (Koni Double-Adjustables, Grigg's coil-over conversion sleeves, Max Motorsports C/C plates) and it offers all the adjustability one could need. The Subaru Konis are only single adjustable, but so were my DMS 40s (which were junk and returned), so I don't see that being a problem.
I won't be able to give any feedback for months, though. I'm currently about halfway through a 6-month deployment, just making a port visit now. I won't see my car again for over three months, and then I have to get all the stuff ordered and installed.
Pat Olsen
'97 Legacy 2.5GT sedan
Old 04-20-2003, 10:03 PM   #4
AnimalMother
Member#: 11835
2004 Honda Pilot
Dark Blue
TTT
Old 04-20-2003, 10:23 PM   #5
teiva-boy
Member#: 22825
No matter how you look at it, your saving some ~$400 or so buying the Koni setup vs a true coilover setup from <insert coilover here>. If your not a real track hound, the Koni's should be more then enough.
teiva-boy is offline   Reply With Quote
Old 04-21-2003, 12:55 PM   #6
AnimalMother
Member#: 11835
2004 Honda Pilot
Dark Blue
what do you think would be the disadvantages/advantages of a Koni setup versus a true coil-over? I am pretty certain that Koni makes a great shock absorber, but I am not so certain about many of the other brands. Granted, I haven't seen much information either way, but I know I can trust Koni.
Also, is the Koni subject to overheating on the track? Or would you prefer some coil-overs to koni/GC because of the lower spring rates that would most likely be used? Thoughts?
AnimalMother
Old 04-22-2003, 02:41 PM   #7
AnimalMother
Member#: 11835
2004 Honda Pilot
Dark Blue
TTT
Old 04-22-2003, 02:46 PM   #8
Bailey
Member#: 12572
2004 STi
35R is enough
Default need koni feedback
I am in the same boat... currently i have H&R springs with the stock struts. Its a little bouncy but firm. The only real downside is track days where this suspension seems too soft.
Considering Tein coilovers but the koni inserts for 800.00 less is an option. More information would make my choice easier.
Anyone with Koni want to provide an opinion?
Bailey
Bailey is offline   Reply With Quote
Old 04-22-2003, 02:53 PM   #9
AnimalMother
Member#: 11835
2004 Honda Pilot
Dark Blue
I know slater mentioned cosworth above...and I have followed some of cosworth's posts, but we need some more info!
what about trhoppe...he went from DS on Konis to STX on Tein HAs...Tom, any info you can share?
AnimalMother
Old 04-22-2003, 03:16 PM   #10
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
I went to Tein HAs mainly because of a sponsorship.
There are 3 different ways that you could go about getting a nice suspension IMHO.
1) Stock Konis with GC collars and a low springrate. Something like a 275. This would be good for a road car, with occasional autox and occasional track use. It wouldnt be too rough on the street and would be decent on track. Cost = $900
2) A Tein or JIC type of coilover. You can have a nice matched suspension, but with higher spring rates. You know the shocks come valved for your spring rates and will work well together. This will be a stiffer and more jarring ride on the street, but you will have a little more control on the track and autox. Still ok to drive around on, but not as comfy as option 1. You could also run the same spring rates as the Teins with the Konis, as long as you sent them off to get revalved. Cost = $1500 to $2000 ($900 + $400 revalving for Konis)
3) A Leda type of coilover or a GC Advance or Koni DA shock with GC sleeves and HIGH spring rates. This is what you would want on a full track or full autox car, that is seldom daily driven. This suspension is not nearly as easy to setup and tune as #2, because you have seperate bump and compression dampening to deal with, and that is a lot of rope to hang yourself with. Cost = $2400+
I am using option 2, but with custom spring rates. Option 3 was too much $$ for not a huge return on the performance side. Once I drive the car in STX trim for a while and get every little bit out of it. I will probably switch over to the GC Advance Design shock with GC springs. But right now, I really like the Tein HAs and am very happy with them. Also, since switching from DS to STX was such a big jump, I know I'm not getting the full potential out of the car yet.
-Tom
trhoppe is offline   Reply With Quote
Old 04-22-2003, 07:15 PM   #11
Cosworth
Member#: 3887
08 Taco, 98 M3/4/5
'00 RC51, '08 KTM
I'm in full agreement with Tom. I have the Koni/GC/Noltec combo and it has pluses and minuses. I have a "medium" setup that is not too harsh that gives me wonderful street driving feel without the harshness of a really stiff coilover kit. My setup uses 275f/250r # rates so its not outrageous. Offramps are a breeze, but on the track, i don't have the benefit of the heavy spring rates of the JIC/Tein heavy hitters but i don't have to deal with the harshness of daily duty of those either. But don't get me wrong, it has a feel on the track that i would not trade for stock. THe performance increase is good, but i won't ignore the fact that its not as hardcore as a full coilover kit. Also, believe it or not, my car is fairly supple on bumps.
Pro's:
- Relatively inexpensive compared to full coilovers kits.
- adjustable shock rebound gives you an adjustable taught and controlled ride while still giving you comfort on the street since the bound rate is fixed.
- height adjustable coils with full customizable rates/lengths for whatever your needs are both before and after purchasing.
- adjustable caster/camber with the Noltec front plates. Somewhere in the neightborhood or 5* max caster and 2.5* max camber is attainable (setting my plates to max position on both yeilded these values on the alignment rack.
- corner weighting/balancing possible.
- pretty colors.
- Koni's have lifetime warrantly and are EASILY REBUILDABLE in the USA!
Con's:
- Koni's only single adjustable so bound control can be rather underdamped during competition or heavy use.
- limited max damping to about 400# in the SA koni inserts.
- limited to how "severe" you want to go with lowering since the GS's are only single adjustable in height. Lower the car and you compromise the bound travel. Need to compensate by higher spring rates or shortened Koni's which equals $$$.
- not inverted shock design (like RA, A2's, Z2R's).
- can be noisy since all components are not integrated from the factory. that means tolerances not as tight as a fully integrated as a true coilover setup.
MRT/Noltec = Austrailan, and that means rust! (sometimes)
So you can see that some of the cons are not really cons--more of limitations to the system that you need to figure before you buy in. It has its realm of suitable application and if your needs fit it, its great. If your needs exceed thier capabilities, then you need to spend a lot more money on more race oriented equipment. The SA Koni/GC setup is a very nice combo that suits a wide array of needs. It is rather flexible from lite applications to medium/heavy applications. Beyond that, you need to upgrade to DA shocks and as we all know SPEED = MONEY. How fast do you want to spend.
Jon.
Cosworth is offline   Reply With Quote
Old 04-22-2003, 08:39 PM   #12
Rapid_Roo
Member#: 31511
03 GD2 95 GM4
www.ITNRally.org
Question
does anyone know if the GC kit fits over the STi strut that is included in the full SPT/STi kit that is installed by the dealers. I have the SPT kit, and it is pretty good, but I think it could use some tweeking. I called GC and they said no, but on their website it shows a pic of one of theor collars on a pink or red strut that looks like the one from STi.
what do you guys think. I was going to call them again and see if I could talk to someone else.
thanks
RR
Rapid_Roo is offline   Reply With Quote
Old 04-22-2003, 09:02 PM   #13
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
The "WRX" GC kit is probably setup for the WRX factory shock diameter. I want to say that the pink STi struts are going to be fatter then the stock WRX shocks, so that means that the "WRX" GC kit would not fit on them. I'm sure if you took some EXACT measurements of the pink STi struts and sent them over the GC, they could set you up with a collar that would work.
-Tom
Old 04-22-2003, 09:09 PM   #14
AnimalMother
Member#: 11835
2004 Honda Pilot
Dark Blue
Great info from trhoppe and cosworth. Thanks! Out of curiosity, what does GC usually recommend as far as spring rates (assuming you are going to use koni inserts)?
Anyone else have anything to offer???
AnimalMother
Old 04-23-2003, 12:12 AM   #15
slater
Member#: 5848
1992 vw corrado vr6
-Tom
sorry tom, they fit, and fit perfectly!! on both V7 and V6 struts. (i have both sets so i know firsthand ).
the only modification needed on the STi struts (any version) is that the first 'ridge' below the threaded section on the top of the struts needs to be filed down slightly, took me 10 minutes with a bastard cut file. note that this is for the ERS spring top hats to seat snugly on the struts - all 4 struts need to be done of the GC* chassis, only the fronts on the GD* chassis because the rear top mounts and top hats are different than the GC* chassis.
i'm running the same rates as cosworth (275F/250R), and they are an excellent compromise.
peter
Old 04-23-2003, 03:11 AM   #16
Rapid_Roo
Member#: 31511
03 GD2 95 GM4
www.ITNRally.org
peter
thank you. you wouldnt happen to have a picture of the area I would need to file.
I am new to this, what is the difference between an GC* and a GD*?
thanks again.
RR
Old 04-23-2003, 11:30 AM   #17
Cosworth
Member#: 3887
08 Taco, 98 M3/4/5
'00 RC51, '08 KTM
thanks again.
RR
Generally speaking:
GC* is the <=2001 vehicles.
GD* is the 2002>= vehicles.
Old 04-23-2003, 03:07 PM   #18
Rapid_Roo
Member#: 31511
03 GD2 95 GM4
www.ITNRally.org
Originally posted by Cosworth
Generally speaking:
thanks,
so having an 03 WRX I have a GD*, or did I get that backwards.
but that would be just like me.
thanks again for all of the help.
RR
Old 04-23-2003, 07:49 PM   #19
slater
Member#: 5848
1992 vw corrado vr6
here's a pic... disregard the f-ed threads, i've fixed those... (these are my V6 fronts).
the red part is where to need to file - basically you're making the circular ridge slightly smaller in diameter.
hope that helps...
peter
Old 04-23-2003, 09:52 PM   #20
Rapid_Roo
Member#: 31511
03 GD2 95 GM4
www.ITNRally.org
hope that helps...
peter
thank you very much. I was worried about performing surgery on the struts, but I think I can do this.
thanks again
RR
Old 04-23-2003, 10:24 PM   #21
slater
Member#: 5848
1992 vw corrado vr6
thanks again
RR
no problem. yeah, it's not a big deal by any means - took me 10 minutes to do all 4 struts. and if you decide to go back to a regular strut/spring combo, it doesn't affect that at all.
peter
Old 04-23-2003, 10:30 PM   #22
sdecker
Member#: 14717
2002 WRX, WR Blue
Complete n00b Racing
I don't know if this helps any, but I recently put Koni inserts on my Prodrive springs (215F/195R is claimed as the spring rates). I also installed Cusco camber plates in the front.
I chose this combo over coilovers because:
1) I didn't want to have to re-corner weight the car every time I made an adjustment in ride height;
2) I didn't want obscene spring rates (I'm not into the kidney beating 8k/6k combo, thank you)
3) I wanted better bound control on the track
4) I didn't want to drop 2 grand+ on a 'good' set of coilovers
I considered and rejected the GC setup for reason #1 above, but otherwise I think it would be a good combo if you don't mind tweaking constantly and have a set of scales. I don't...
While the spring rates may not be ideal for a heavy autox or track car, I can definitely say that this combo is far superior to the stock setup. The best part is that it cost 1000.00 for all.
I have a recent thread with driving impressions and all the gory details if any of you are interested...
Good luck!
Scott
sdecker is offline   Reply With Quote
Old 04-24-2003, 12:55 AM   #23
ForceFed4
Member#: 7370
SGM
One thing I haven't heard anyone mention with regard to the Koni inserts is the piston diameter, and what effect that might have on performance. If it fits inside the stock strut housing, I imagine that it must have a smaller piston than stock, is this going to result in any noticable effects?
I'm investigating various suspension options for my car, and it seems that without spending $1500+ on a coilover system (that I wouldn't even know how to tune) my options are to find some STi take-offs or go with Koni inserts & prodrive springs w/ STi top-mounts. Both of those seem to fall in about the $1K range, and I'm wondering what the main differences are. Right now I like the STi option better because I'm not totally comfortable with the idea of hacking up my OEM pieces, but everyone that has the Konis seems to like them a lot, so I don't know...
ForceFed4 is offline   Reply With Quote
Old 04-25-2003, 10:04 AM   #24
ConeMasher
Member#: 2135
If I recall correctly, the koni insert shaft diameter was actually larger than stock. Miracles of packaging I suppose.
ConeMasher is offline   Reply With Quote
Old 04-25-2003, 10:10 AM   #25
sdecker
Member#: 14717
2002 WRX, WR Blue
Yes, I can confirm that. I didn't measure, but it was definitely larger. I would put it in the 40mm range or so, just eyeballing it.
Scott
FS: Tein, Ground Control, Koni, Perrin, Helix Parts (from 03 WRX) R3DR3X MWSOC Private Classifieds 10 05-24-2006 02:02 AM
Stoptech, progress, Cusco, Ground Control, Koni Etc... NinosAutoAccesories Suspension/Brakes/Handling 6 09-14-2004 04:49 PM
noise with ground control/koni csleee Texas Impreza Club Forum -- TXIC 14 06-25-2004 05:44 PM
help with ground controls/koni csleee Texas Impreza Club Forum -- TXIC 1 05-21-2004 03:01 PM
Ground Control/Koni need help deuce.five Brakes, Steering & Suspension 1 04-12-2004 04:50 PM
