Old 04-18-2003, 10:20 PM   #1
subarucyclist
Member#: 29374
2000 2.5 RS
Silverthorn
Default shifter/tranny..does yours do this?
When shifting from 1st to 2nd or 2nd to 3rd, I can occasionally feel a hard "bump" through the shifter as it's going into gear. I'm shifting gently, pausing in neutral and slowly sliding into the next gear, and rev-matching.
I have a KartBoy shifter and a 2nd generation clutch/pressure plate and 58k on the odo of my 2000 RS. My buddy's 2002 RS has a Cobb adjustable shifter, and it feels tighter, kinda stickier, and that "bump" isn't there.
Do I have worn gears/syncros? Is it the KartBoy shifter? Is there some sort of adjustment I can do?
Help appreciated?
SC
subarucyclist is offline   Reply With Quote
Old 04-18-2003, 11:13 PM   #2
subarucyclist
Member#: 29374
2000 2.5 RS
Silverthorn
...forgot to add, I don't have the stiffer bushings installed (yet) but maybe that's the difference?
Old 04-19-2003, 12:50 AM   #3
Member#: 67
1999 Outlasting
the competition.
Old 04-19-2003, 08:44 AM   #4
obyone
Member#: 16523
Originally posted by [email protected]
Throw them suckers in first
[email protected]
What he said. The bushing makes more of a difference, in the shift feel, than the shifter does.
BTW...I think I know what you're talking about and I assumed it was normal.
obyone is offline   Reply With Quote
Old 04-19-2003, 04:17 PM   #5
joefocker20
Member#: 13745
2015 STI
Its not normal, you have to be very smooth with the clutch. When I first bought my car, mine did it alot, you have to let the clutch out faster or slower varying on how fast you're accelerating, and get on the gas right before the clutch reengages.
joefocker20 is offline   Reply With Quote
Old 04-28-2003, 09:58 PM   #6
scbice
Member#: 35744
2003 WRX Wagon
Sonic Yellow
Default Slight Bump in New 03 WRX Wagon
I'm still breaking in my new 03 wagon. I've noticed a slight "bump" against my hand going from 2nd to 3rd when the clutch engages. Didn't know if this was a shifter/transmission problem, but doesn't seem related to clutch management. I was worried at first, but view it as a very minor idiosyncracy, unless somebody out there knows it's a mechanical problem or what might be causing it.
scbice is offline   Reply With Quote
Old 04-28-2003, 10:38 PM   #7
joefocker20
Member#: 13745
2015 STI
It is related to clutch management, I had the same problem for 2 months after I bought my Subaru. You just have to gain a feel for it. I have the Kartboy shifter, but I can't comment on how well the bushings work, but I seen where the bushing was when I installed my header, and it looks like a very easy install, so I may order a set soon.
LCD Flat Panel Monitor Problems, Does yours do this? STEALTH-WRX Off-Topic 8 03-18-2004 02:30 AM
4eat Paddle Shifters? Can we still do this? tonberryking Transmission (AT/MT) & Driveline 3 12-14-2002 05:05 PM
GFB bov, does yours make this sound? tytlyf Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-30-2002 11:58 PM
does anyone do this? henryh Newbies & FAQs 22 01-06-2002 02:48 AM
My heat vents are driving me crazy! Do yours do this? ChosenWon General Forum Archive 2 03-18-2001 04:55 AM
