Old 04-19-2003, 12:57 AM   #1
orndog
Member#: 34670
2013 No gears!
Saltine American
Default Can an OBS handle better?
I know, but I needed the clearance here. I took her out on the backroads today, and while she sure was fun, she gets a bit squirrely - if you know what I mean. Without sacrificing the clearance, what can I do to an OBS to make it handle better?
orndog is online now   Reply With Quote
Old 04-19-2003, 01:23 AM   #2
MattDell
Member#: 16803
Wider tires, stiffer (not lower) springs, bigger rear sway bar..
-Matt
MattDell is offline   Reply With Quote
Old 04-19-2003, 02:56 AM   #3
RK Performance
Member#: 19069
2005 Impreza WRX
2002 RS, RIP
Check out the Suspension and Brakes forum, you should get much more in depth answers in there.
-Ryan
RK Performance is offline   Reply With Quote
Old 04-19-2003, 05:26 AM   #4
speedracer47
Member#: 2765
18mm rear sway bar and better tires will make the biggest difference.
speedracer47 is offline   Reply With Quote
Old 04-19-2003, 10:58 AM   #5
orndog
Member#: 34670
2013 No gears!
Saltine American
Thanks, didn't know if sway bars were available for the OBS. Can you recommend a supplier?
Old 04-19-2003, 03:59 PM   #6
nitrohuffer
Member#: 6982
2001 Legover
04 forester xt
What they said. check the suspension forums and do a search.
nitrohuffer is offline   Reply With Quote
Old 04-20-2003, 01:14 AM   #7
Kostamojen
Member#: 2272
2016 Commodore SS
Heron White
All Impreza rear swaybars are compatible with all model Impreza's.
Old 04-20-2003, 11:34 AM   #8
Matt
Allergic to turbos
Member#: 181
2009 Forester
'09 ImprezaGT '04Frontier
www.teaguesauto.com
Also, get a set of endlinks. Doesn't matter what, but it will help alot. I've got a set of endlinks from MRT and a Cusco sway bar and my RS is great.
We've got an '02 OBS as well and we'll probably do the same for it as well. Good tires help, but get some endlinks and a sway bar, its a great package and will handle quite well.
Matt is offline   Reply With Quote
how much can an STI Type RA Gearset Handle? 03SuBbYWrX Transmission (AT/MT) & Driveline 2 11-01-2007 08:00 PM
how much can an impreza handle? wobblywunk Newbies & FAQs 87 12-09-2006 09:58 PM
Getting the WRX to handle like an STi...or better? MachinesWRX Newbies & FAQs 21 08-22-2005 02:50 PM
how much load can a OBS hitch handle? flyingmachine General Community 8 09-17-2004 10:03 PM
How much Nitrous Oxide can an EJ22E handle? Chi_San Legacy Forum 33 02-07-2004 07:02 PM
