Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 04-19-2003, 01:17 AM   #1
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
Default The STi Instrument Cluster contains
Idiot light/display list:
DCCD: Auto, Lock, <arrows>
Outside Temp
Check engine
Fuel warning
Cruise, (cruise) Set
Oil pressure warning
Brake warning
I/C Spray (low)
R Diff Temp (high)
Door Ajar
Seat Belt reminder
Alternator warning
Security
ABS
Airbag
"STi"
Turn signals (L & R)
High beam
something that looks like "parking lights"? (perhaps it comes on if you use the switch on the top of the steering column?)
ANZAC_1915 is offline
Old 04-19-2003, 02:01 AM   #2
kenzo
Member#: 6422
2015 A4 Quattro MT6
Monsoon-like
I'm especially thankful for the "STi" indicator - God knows how easy it will be to forget which Impreza you're driving.
After all, it's only indicated on the trunk lid, (non) fog light covers, fenders, seat backs, key, optional floor mats... I must be forgetting some.
Sorry for the rant - this is one of my (few) pet peeves about the car. I half expect the horn / alarm chirp to be a digitized audio clip ("S-T-i !").
(Won't stop me from getting one, though.)
Glenn, thanks as always for the detailed info.
kenzo is offline
Old 04-19-2003, 03:16 AM   #3
clamdip
Member#: 18709
are these gauges the ones that are very similar to the defi BF gauges, basically blacked out in the off position then nicely lit when turned on, with a full sweep check of the needles.
clamdip is offline
Old 04-19-2003, 05:11 AM   #4
HFTuRbo
Member#: 34388
04 WRX STi
Black w/gunmetal
Arrow
are these gauges the ones that are... basically blacked out in the off position then nicely lit when turned on, with a full sweep check of the needles
Why, yes they are!
...and hear that? Audible time to shift sound...
It may not be heard during break-in period.
HFTuRbo is offline
Old 04-19-2003, 08:51 AM   #5
clamdip
Member#: 18709
you think these will work with the 02 WRX? i'm planning a swap with one from japan.
clamdip is offline
Old 04-19-2003, 10:27 AM   #6
skuttledude
Member#: 738
2008 Lexus IS-F
Ducati Monster 800
Default Re: The STi Instrument Cluster contains
Outside Temp
Check engine
Fuel warning
Brake warning
I/C Spray (low)
R Diff Temp (high)
Door Ajar
Seat Belt reminder
Alternator warning
Security
ABS
Airbag
"STi"
High beam
I don't believe you! Where you hear that from? Who's your source. Actually I'm just joking!
We know you have some inside source...the truth is out there.Thanks for the facts on the instrument cluster. Looks rather busy...which is totally fine. However didn't you forget the Tach and Speedo? Maybe the Sti has the new voice controlled tach and speedo (hahaha).
Cheers,
Davis
skuttledude is offline
Old 04-19-2003, 10:37 AM   #7
StiDreams
Member#: 26315
07 Outback
Silver/Silver
Hey Glenn,
It sounds like you have access to some manuals. While you're perusing the pages, maybe you can look some stuff up for me. I remember reading (quite some time ago) that a coolant line went through the throttle body. Some were making a bypass mod to bypass the throttle body. Is that coolant path still present?
Thanks.
StiDreams is offline
Old 04-19-2003, 11:09 AM   #8
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
I don't have that info, sorry.
And perhaps I just looked at a show car's instrument cluster in great detail....
WRX/STi Instrument Cluster in 02RS millenix Electrical & Lighting 0 10-13-2003 11:46 AM
JDM STi instrument cluster mod??? MK19 Electrical & Lighting 1 09-15-2003 02:27 PM
Hooking up JDM STi Instrument Cluster on '02 WRX Hoop-D Electrical & Lighting 8 08-06-2003 01:19 PM
03 JDM STi instrument cluster clamdip Electrical & Lighting 4 04-21-2003 10:40 PM
Anybody know when the Autometer instrument cluster bezel will be available? -=C=- Interior & Exterior Modification 7 01-30-2002 12:33 AM
