Old 04-19-2003, 07:33 PM   #1
ForceFed4
Member#: 7370
SGM
Question Winter steel wheels rusted to hubs...
Okay, this is going to sound extremely dumb, but, I have a problem with this.
So I've been trying to change back to my summer tires now for an hour, but I can't get the steelies off. They seem to be stuck onto the hubs because of rust. I've tried banging them loose, which worked last year when they were just a little stuck. This year they seem to be really stuck on there, and won't just break loose from force.
I haven't tried anything like WD-40 yet because first, I don't have any, and second, I'm not completely comfortable with the idea of spraying that all over my brakes.
Has anyone else ever had a problem like this, and if so, do you have a solution?
Edit: Sorry if this is in the wrong forum, I hadn't noticed the "split" until after posting this.
ForceFed4 is online now   Reply With Quote
Old 04-19-2003, 08:17 PM   #2
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
But you wouldn't be spraying it all over your brakes... direct it with the tube at the "hat" of the rotor and then at the base of your wheel studs. Tap the wheel with a hammer to spread the WD40 and go have a cup of coffee . You should have more luck when you come back. Another trick I personally haven't tried is to remove all your lugs and let the car down on the pavement and rock it a little. The weight of the car combined with the movement breaks the wheel free.
Brian
Old 04-19-2003, 08:38 PM   #3
Chromer
Member#: 20325
08 Yamaha WR250R
07 Suzuki DL650
Don't force it. Get a bigger hammer. ;-) A 10-pounder usually works pretty well for me.
NEXT year, give a liberal smear of anti-sieze compound on any contacting surfaces so they can't rust together.
Chromer is offline   Reply With Quote
Old 04-19-2003, 08:38 PM   #4
Siper2
Member#: 1134
2007 BMW 328xi wagon
The rocking method probably works, but try this first... that is unless you figured it out by now.
When the car's up on the jack, sit/lie down next to the wheel and give one side of the tire a good hard kick. That usually breaks it loose. I had to do that to one of my winter steelies the other day.
So long as cars have parts made of rust-susceptible metal, crap like this will happen. On ANY car!
-S2-
Siper2 is offline   Reply With Quote
Old 04-19-2003, 08:53 PM   #5
ForceFed4
Member#: 7370
SGM
Yeah, so I tightened down the lugs again, went out and got some penetrating oil, brake cleaner, anti-seize, and a wire brush.
It's dark outside now, so I guess I'll re-attempt the change tomorrow when it's light outside again.
Old 04-19-2003, 08:57 PM   #6
Storm
Member#: 5218
96L Most Over-
Developed Beater
You puss....get back out there and do it in the dark!
Jay Storm
www.sourcemotorsports.com
Old 04-19-2003, 09:18 PM   #7
ForceFed4
Member#: 7370
SGM
Actually, I couldn't help myself either, so I went and tried it, and got them to pop loose with WD-40 and a couple of kicks I were sure would drop the car off the jack (luckily they didn't).
What a PITA though. I started all this @ 6:30, thinking I would be an hour at most.
Old 04-19-2003, 09:56 PM   #8
Bottom Feeder
Member#: 2808
Brian
Wouldn't it be a tad safer to leave the lugs on, just loosened up a few turns?
Bottom Feeder is offline   Reply With Quote
Old 04-20-2003, 08:19 PM   #9
RidinLow
Member#: 329
1995 325i
Arctic Gray
I just slowly lower the car without the lugnuts on until the wheel snaps free. Been doing it for years without any trouble.
Just make sure to go slow!
RidinLow is offline   Reply With Quote
Old 04-21-2003, 11:40 AM   #10
kenchan
Member#: 15106
dont lie down under the car to give that kick outwards.
i would spray wd40 between the wheel and hub and let it
sit for a few minutes before malletting it loose. keep your
lugs loosely on the studs so that the wheel doesnt fly off.
kenchan is offline   Reply With Quote
Old 04-21-2003, 04:21 PM   #11
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
92 5MT SVX
Yeah, but the pucker factor isn't nearly as high !
Brian
Are steel wheels from Subaru Hub-centric? sabu Tire & Wheel 2 09-23-2009 10:22 PM
14" Miata Steel Wheels - Looking to put snow tires on your Miata? Rice & Gravy MAIC Private Classifieds 1 09-05-2006 02:25 PM
Good place to buy steel wheels for my Mazda for the winter? 03WRXMA Off-Topic 7 10-07-2004 06:07 PM
Why winter steel wheels? yebokmj Technical Forum Archive 13 10-12-2000 05:20 AM
