Old 04-19-2003, 09:37 PM   #1
Lowball
Member#: 24198
02 WRX Sport Wag
Black to reality.
Arrow question on my S-03's (see photo)
I had a question about tire wear. If you look at this photo the area where the red lines are...that area is acutally higher than the rest of the tread on the tire. This is typical of all 4 tires. Then at the area where I have the blue line, that is a little ridge of melted rubber and that is on all 4 tires as well.
Is this caused by tire pressure or alignment? Right now when the tires are cold the pressure is only at 31 psi. That is what I was running at the track yesterday. I didn't check the pressure after any hot laps...
See IMG below.
Any help would be great.
Lowball
P.S. sorry about the photo size...
Lowball is offline   Reply With Quote
Old 04-19-2003, 09:41 PM   #2
BobbyD
Member#: 27262
02 WRX
the picture doesnt work
--bobby
edit: works now
BobbyD is offline   Reply With Quote
Old 04-20-2003, 05:51 PM   #3
mch
Member#: 30039
2002 wrx wagon
dirt slvr
Photo still no work.
What are your alignment specs?
Cold tire pressure by itself does not tell us enough.
mch is offline   Reply With Quote
Old 04-20-2003, 06:19 PM   #4
Lowball
Member#: 24198
02 WRX Sport Wag
Black to reality.
I can see the photo...
I'll check my alignment specs. and repost.
Old 04-20-2003, 07:59 PM   #5
Lowball
Member#: 24198
02 WRX Sport Wag
Black to reality.
Default alignment specs
This is what it says on my invoice from the alignment shop:
Align front end - road test vehicle
Front camber is 0 -- not adjustable
Align rear & set tracking
Rear camber -1.25
That's it.
Lowball
P.S. if you still can't see the photo then try clicking here...
http://us.f1.yahoofs.com/users/4167b...kCfo.AMNm6SGLM
Old 04-20-2003, 09:06 PM   #6
ellisnc
Member#: 4229
2003 S2000
Did someone say track day
if your front is set to zero camber that's your problem
the front is adjustable, it's partially your fault for not knowing anything before letting someone else work on the car
my front camber is set to around 2.5 degrees negative in the front and only then do I get decent tire wear and grip on the track
I still can't see the pictures though
ellisnc is offline   Reply With Quote
Old 04-20-2003, 10:01 PM   #7
Lowball
Member#: 24198
02 WRX Sport Wag
Black to reality.
It seems to be happening on all 4 tires. I don't know anything about alignment but I did tell them what I wanted and they said the front was not adjustible. I have aftermarket STi struts, could that be part of the problem?
But you are saying I should have more negative camber in the front?
What is a good setting for both track and street?
LB
Old 04-20-2003, 11:58 PM   #8
mch
Member#: 30039
2002 wrx wagon
dirt slvr
I believe if the rear camber is not adjustable unless you have installed camber bolts. The front camber is adjustable though the CASTOR is not.
What is the toe (in/out - Front/rear)??
Who installed your STi suspension?
You need to to find another alignment shop. These people do not seem to know their business.
btw. your picture still does not display.
Old 04-21-2003, 12:12 AM   #9
Lowball
Member#: 24198
02 WRX Sport Wag
Black to reality.
I seem to agree about the alignment shop. I'll be looking ASAP.
I installed the STi suspension with written help from Wayne @ AVSport. Then I took it to get an alignment and they said it was way off and adjusted it to the settings listed. They didn't list teh toe in/out - front/rear. There are not any subaru performance shops in my area so it's kinda hard to know where to take it. I just took it to a brake and alignment shop that had been around for a long time and works on a lot of lowered cars. There are some import performance shops but just not any subaru ones.
LB
Don't know what's up the with photo...
Old 04-21-2003, 06:52 AM   #10
ellisnc
Member#: 4229
2003 S2000
What I'm saying is don't be dumb and find out for yourself where the adjustment points are on the car, then when they tell you some stupid crap like they told you, you can tell them how to adjust the car.
I'd say judging from your experience, you could have installed the eccentric bolts in the wrong places so when the guy at the shop went to look they weren't there and then they said it's not adjustable. Just one possibility.
One word of advice, I realize not everyone is mechanically inclined and some are more noobish than others, but if you're too lazy to spend the time to think about how the car's alignment is adjusted and where it's adjusted before you take it in (being that you just changed the suspension out) then you're going to get taken all the time like you just were.
Old 04-21-2003, 04:55 PM   #11
DDMan
Member#: 11221
2002 2.5 RS
Black as Midnight!!!
Links still no worky
But here is my take on it.
1. Make sure everything is in the right place (escentric bolts and all) and take it back, throw the paper in their face, and have them RE-Align youre car with a FULL spec printout before AND after (For Free of course). I have never heard of an alignment shop NOT printing out a full sheet for you to take home (has L/R, F/R camber, toe, and castor...along with how its all centered).
The alignment should have at least a 30 day warranty (even if not, they did the work incorrectly and screwed up).
Also, how much did you pay? Where did u go? I had guys do the same thing to me, and they said it couldnt be adjusted. I went back and got it re-aligned for free after I told them off.
DDMan is offline   Reply With Quote
Old 04-21-2003, 05:34 PM   #12
Lowball
Member#: 24198
02 WRX Sport Wag
Black to reality.
DDMan-
Thanks for responding. Where did you take yours to get aligned?
On the eccentric strut bolts, they can only go in at one location but I guess I could have put them in upside down or something. Does it make a differance?
I think it's been over 30-days but I guess I can still take it back and see what they say and point out all the alignment points...if I knew where they all were
Lowball
Old 04-21-2003, 08:02 PM   #13
Lowball
Member#: 24198
02 WRX Sport Wag
Black to reality.
Unhappy The photo for the last time I hope
Old 04-21-2003, 09:15 PM   #14
DDMan
Member#: 11221
2002 2.5 RS
My alignment had a 90 day warranty (most are 90 days). I got it done at Clarks Frame and Body here in Roseville. If that wear is tire pressure, it would be overinflation, but if youre at 31, then youre 100% safe. Definately get the alignment checked out.
Here are the adjustment points (for front):
Camber: Top bolt where strut conncts to wheel hub. Escentric bolt, rotate to change camber.
Toe: Adjust tie-rod's. Loosen lut, then rotate in or out.
Caster: Non-adjustable
Rear Points:
Camber: Non adj. unless you have a camber kit
Toe: Where the rear lateral link connects to the rear subframe, rotate the large bolt.
For Putting the bolts in backwards...I dont think the escentric bolt would fit in the bottom spot. It also SOULDNT matter if it were backwards, but there is a front and back where its "supposed" to be. The bolt face should be facing the back of the car, the nut should be towards the front. Hope this helps!
Old 04-21-2003, 09:22 PM   #15
Lowball
Member#: 24198
02 WRX Sport Wag
Black to reality.
Rear Points:
Thanks DDMan. I have it all installed correctly then. I just matched the stock set up when I took it out and I only did one side at a time for reference, so I should be all good. Just my alignment shop must suck and not know how to work on Subaru's correctly. I may try Motor Sport Dy, they said only 70 bucks. Or I may take it back to the original shop and see if they can fix it with me telling them how to do it
Thanks again and this matter is closed!
Old 04-22-2003, 12:33 AM   #16
wylie
Member#: 7387
02 wrx wagon
blue
Lowball,
Are both outer edges of your tire higher than the center, ie. the center is worn the most? If yes, then you were over inflated and/or got your tires too hot. I saw exactly what you have on a set of S0-3s on the track. Except in my case I checked the cold pressure at sea level and then went to 4000 feet or so and overheated my tires on the track (Spring Mountain, Pahrump NV).
Also: Bridgestone uses different rubber compounds at different depth levels of the tread (read the descriptions on the Tire Rack website), and my feeling is the center is a softer compound or more susceptible to overheating on the track.
Next time you are at the track, check your tire pressures when hot. You will gain 5-8 psi from your cold temperatures.
Tire wear due to alignment issues (toe or camber) would wear one side of the tire more than the other.
wylie is offline   Reply With Quote
Old 04-22-2003, 03:38 AM   #17
Lowball
Member#: 24198
02 WRX Sport Wag
Black to reality.
Wylie-
That is very interesting as well. I only had my tires inflated to about 31 on all 4. So I'm sure it may have be the "to hot" part of the deal.
All four tires are are seeing the same ware patern. It's from the inter edge closest to the strut and the to the 2nd to last outer edge.
Lowball
clutch question on my 6speed in my wrx evo 3ater Subaru Conversions 13 08-12-2009 06:46 PM
I did it, I just put C on every question on my final.... Keith Off-Topic 21 12-16-2003 03:09 AM
Quick question on my speeding ticket... Beam Tri-State Area Forum 4 06-12-2003 01:30 AM
question on my suspension plan.. RChampion Brakes, Steering & Suspension 0 05-31-2003 02:59 AM
Some questions on my Compression test : MINO Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 08-21-2002 01:55 PM
