Go Back   NASIOC > NASIOC Chapters > New England Impreza Club Forum -- NESIC
Old 04-19-2003, 09:14 PM   #1
Siper2
Member#: 1134
2007 BMW 328xi wagon
Talking So I need to buy new brakes. Anyone wanna buy some stuff?
Hola.
Last night the ever-fun Mr. North Ursalia dropped by for pizza, a movie and an evaluation of my pulsing front brake problem. A few good folks told me that my Porterfield R4-S pads were transferring material onto my rotors--which supposedly is normal, but I apparently wasn't braking hard enough to dissipate it. (Since I rarely race and I'm usually docile... compared to you nuts, anyway. )
Well, long story short, it looks like my rotors are warped. Brian pointed it out and I could feel it myself. Definitely some uneven surface, there, up front. I've had them resurfaced once already. Twice would probably kill 'em. These are FrozenRotors.com's cryo-treated Brembo discs, too. Bummer.
So. I decided to just save up and buy some WRX front and Legacy H-6 rear discs and caliper brackets, and pick a full set of less-aggressive pads. Exeter sells these upgrades for we GC guys for about $410, total. So, I'm thinkin' of things I have that I can clear out of my garage space:
- OEM RS suspension, including four struts, four springs, and one 13mm rear swaybar with bushings
- Four 15" Legacy steel wheels, with Nokian Hakkapeliitta 1 tires (P195/65-R15) tires mounted, no studs. They just finished off their third winter. Still grippy, but obviously not as good as new tires.
- My Porterfield pads. I still have my OEMs which I can use if need be.
Maybe it's just my luck. A ton of people have the R4-S pads and haven't had problems. It's just my mojo, I guess. I'll start taking offers for now I guess on the suspension and wheels/tires (which, no, I won't separate, and no I prefer not to ship). The wheels won't clear the new WRX/H-6 brake combo, anyway.
-S2-
Siper2 is offline   Reply With Quote
Old 04-19-2003, 09:17 PM   #2
Sean
Member#: 518
762 PGT Impreza L,
Silverado EXT, Yaris
Dibs on the suspension...what are you looking to get for them?
Team Updates | FAQ | NESIC News | NESIC Calendar | Gallery | Birth
Sean is offline   Reply With Quote
Old 04-19-2003, 09:20 PM   #3
Siper2
Member#: 1134
I was hoping you'd answer. I was going to contact you, Sean, but you beat me to it!
Eh, as much as I can get, I guess. I'd love to just donate them to you and your racing cause, but I'm too broke to do that, at this time. Christine and I are going to be hashing out budgets now that I'm working again. Basically if I sell a bunch of stuff, I should just about break even on the new brakes, so I shouldn't have to take much money out, myself.
-Chris
Old 04-21-2003, 08:10 AM   #4
Slalom RS
Member#: 25577
2004 TS Wagon
How much are you looking for the porterfields?
How many miles on them?
Slalom RS is offline   Reply With Quote
Old 04-21-2003, 11:01 AM   #5
Siper2
Member#: 1134
24,097 miles by my count.
They were a hair short of $200 brand new for the set of four from Exeter. I've been pretty easy on them. I really don't know what to charge... You're the second person to ask so far, so we'll see what kinds of offers I get and then I'll make up my mind!
-Chris
Old 04-21-2003, 11:14 AM   #6
Slalom RS
Member#: 25577
2004 TS Wagon
I think I'll pass anyways...that's a few miles more than I was hoping...
Good luck, thanks anyways.
Joey
Old 04-21-2003, 11:18 AM   #7
Siper2
Member#: 1134
"A few," huh? Somebody's being modest.
No sweat man. I put them on last summer... I just drive a lot. *shrug*
-S2-
Old 04-21-2003, 12:52 PM   #8
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Dibs on the warped rotors !
Brian
Old 04-21-2003, 02:16 PM   #9
Snowphun
Member#: 1800
WRX /WRX/Cooper S
awd/awd/fwd
Why assume the rotors are past turning? A quick measuring by yourself or any machine shop will tell you if they're going to be above spec after another turning. That would cost you $10 or so, use the stock pads you still have and you're done.
Considering you call yourself a mild driver (braker), why would you want to spend more money on an "upgrade" that won't help you at all?
Paul
Snowphun is offline   Reply With Quote
Old 04-21-2003, 02:34 PM   #10
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
92 5MT SVX
Because they have already warped once and been turned once... I think it's time to throw them in the cart and turn over your nine pence .
Brian
Old 04-21-2003, 04:26 PM   #11
Snowphun
Member#: 1800
WRX /WRX/Cooper S
awd/awd/fwd
Hmmm, that's frustrating, but considering the cost that was spent to cyro them, I'd still consider reusing them. Still, that doesn't explain the need to get new calipers front and rear.
Won't pedal travel increase with this mod unless you also upgrade the master cylinder? These are bigger calipers so they probably push more fluid. So pedal feel could be worse after this mod.
Paul
Old 04-21-2003, 04:31 PM   #12
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
92 5MT SVX
Calipers remain the same, the brackets for them and the rotors are the only items changed (unless he goes nuts and gets 4 pots ). Chris is just afraid of his pads !
Brian
Old 04-21-2003, 07:48 PM   #13
Snowphun
Member#: 1800
WRX /WRX/Cooper S
awd/awd/fwd
Ahh, my bad. Carry on, nothing to see here.
Old 04-21-2003, 10:42 PM   #14
Siper2
Member#: 1134
Such witty banter goin' on in my thread whilst I'm away....
I do believe the rotors are beyond help. I turned them the once at Exeter and it helped, but the problem resurfaced (pun intended!) and now I just don't think there's much I can do. I dunno.
As for going bigger, well the WRX/H-6 upgrade is popular for we GC guys, it dissipates heat better and all that good stuff. No, Brian, I am NOT buying 4-pots. If I did, I'd get the 2-pot rears, too. And I haven't the cash for that kind of upgrade!!!
-S2-
Old 04-21-2003, 11:03 PM   #15
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
92 5MT SVX
C'mon... all the cool kids are doing it
Brian
Old 04-21-2003, 11:07 PM   #16
Siper2
Member#: 1134
Riiiiiiiiiight.
I dunno man, the 4-pots are nice, but maybe there's some meaning behind all the overseas guys ditching the 4-pots on their GC STi cars in favor of bigger kits, like ScoobySport's or Prodrive or something. I really like Scoobysport/Rallyperformance's 16" brake kit, the AP/Brembo one. Quite nice.
The only rear "upgrade" they have, though, are new pads and rotors. Doesn't seem to help much with the whole "let's try to even out the brake bias" argument, though. Too bad it's not a complete f/r set. THAT would be worth saving up for.
Old 04-23-2003, 11:44 PM   #17
Siper2
Member#: 1134
TTT
Sean, what's the deal man?
...And anyone else?....
I about to buy new brake pads and rotors need some sugestions knighter Brakes, Steering & Suspension 3 08-07-2008 02:17 AM
I need to fix my brakes! Anyone want to make some money? robsta1 Southern California Impreza Club Forum -- SCIC 7 04-11-2008 06:33 PM
hou: damn i need to change my clutch... anyone wanna help me? chompleh Texas Impreza Club Forum -- TXIC 30 02-29-2008 12:13 AM
So I went to get new brakes... b_tapper Tri-State Area Forum 17 08-27-2002 01:16 PM
