Old 04-19-2003, 11:22 PM   #1
black knight
Member#: 21597
Default WRX intake manifold/TB question
I was wondering if anyone knew the functionality of the air passage located above the normal circle TB hold on the intake manifold? also if i were to place a blockage over this passage would it cause any engine problems? thanks BK
black knight is offline   Reply With Quote
Old 04-20-2003, 10:58 AM   #2
Austin
Member#: 7089
2016 STi
Your question is poorly worded...
If you're talking about the small hole inside the throttle body, on the top before the throttle plate, then that's the Idle Air Control solenoid air passage.
The ECU controls what RPM you're idling at by how much air is sucked through that hole at an idle/when your throttle plate is shut.
Don't plug it up.
Austin is offline   Reply With Quote
08 WRX intake manifold/intercooler question. ITP Newbies & FAQs 3 01-24-2009 12:05 AM
FS -Chicago- 02' WRX Intake Manifold, TB, TGV's, VF30 + more..... KenSekiguchi Engine/Power/Exhaust 23 08-13-2008 08:02 PM
NJ WTS/WTT APS 'Type R' FMIC, Stock wrx TGV's, intake manifold, TB ready for porting elsanto Engine/Power/Exhaust 10 09-17-2007 04:32 AM
stock intake manifold TB to manifold flange, stainless uppipe to turbo flange White 2.5rs Engine/Power/Exhaust 6 04-02-2007 01:24 PM
'02-04 WRX intake manifold/tb/sensors annointed Private 'Wanted' Classifieds 6 03-05-2005 02:30 PM
