Old 04-20-2003, 01:36 AM   #1
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
Question Any GC8'ers with 225s?
I was wondering...
with the setup - Tein coils, 17x7 +48 will 225 rub?
Hyper is offline   Reply With Quote
Old 04-20-2003, 01:42 AM   #2
Charge
Member#: 3313
Most likely, yes, if you have the car lowered at all. However, you probably could roll the fenders and be OK if you set the coilovers on the stiff side. This is a guess, but from seeing the limited space I have with 215's on a 17x7.5 et 48 rim, I doubt you'll have much room to deal with.
I know there are several who have fit 225's on their 98-01's, but most have mentioned at least occasional rubbing.
Charge is offline   Reply With Quote
Old 04-20-2003, 02:59 AM   #3
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
the drop would most likely be 1.2" 1" to balance it and make go gaps....
Old 04-20-2003, 12:53 PM   #4
Dooby Do
Member#: 18600
'01 Impreza RS
Sadona Red
I'm running Rotas w/48 offset, 225/45X17 Bridgestone Potenza S-03s on stock suspention and I rub alot! Spring upgrade is next on my list but I'll have to wait until S-03s are gone.
Dooby Do is offline   Reply With Quote
Old 04-20-2003, 02:09 PM   #5
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
will you roll fenreds as Charge suggested?
Old 04-20-2003, 03:07 PM   #6
Safir
Member#: 3873
. Paradise is
like Disney with hookers
I run 225's w/no rubbing
stock springs/shocks, 16x7 ET55 wheels... need a 3mm spacer to clear the strut in the rear though.
Safir is offline   Reply With Quote
Old 04-20-2003, 03:10 PM   #7
mlambert
Member#: 13831
Nobody likes the tire forum?
mlambert is offline   Reply With Quote
Old 04-20-2003, 03:52 PM   #8
Charge
Member#: 3313
True, but obviously you're running a different size diameter wheel, with a total diameter that is also different. Add to that, your offset difference, and that's why yours fit.
It can be done, it just takes work. Most people running 225's, though, are running a 17x7 or 17x7.5 wheel.
Old 04-20-2003, 07:29 PM   #9
scotty305
Member#: 8877
2000 Impreza 2.5RS
(sept '01-jan '04)
Also remember that different tires will be slightly different: you want to go to tire rack and look for section widths. I've read that 9" is about as wide of a section width that will fit on a 93-2001 Impreza w/ stock wheels and suspension, but don't take my word for it, you might want to talk to your tire shop first, ask them if they can guarantee it will fit or they'll get you another size.
-s-
scotty305 is offline   Reply With Quote
Old 04-21-2003, 12:04 AM   #10
Takashi
Member#: 2536
2012 STi Hatch
my friend has a 99rs with prodrive p1 springs (lowers car about an inch...). he has 5zigen wheels in 17x7 +50offset, with 225/45-17 kumho 712s and it rubbed in the rear under hard cornering or with people in the back seat.
he just got the fenders rolled yesterday.
greg
Takashi is offline   Reply With Quote
Old 04-21-2003, 01:01 AM   #11
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
Exclamation
All the reports I have heard is that even with stock ride height, 225/45R17s is going to rub in the back, and especially with the wider treadwidth ones. 17x7 or 17x7.5 wouldn't matter much. Unless you plan on running some crazy negative camber and/or roll your fender....
kgb is offline   Reply With Quote
Old 04-21-2003, 04:05 PM   #12
DDMan
Member#: 11221
2002 2.5 RS
Black as Midnight!!!
Me and my friend put my SDR's (17x7.5) wrapped in 225/45/17 Kumho rubber on his 95 2.2L with Prodrive Springs and KYB AGX's and we couldnt take a corner at more than 5mph without rubbing...
I say for 225's on 17"+ wheels, youre going to have to roll the fenders...period
DDMan is offline   Reply With Quote
Old 04-21-2003, 06:33 PM   #13
Takashi
Member#: 2536
2012 STi Hatch
....exactly.
Old 04-22-2003, 01:31 AM   #14
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Well I just got my 225/50/16's and I'm gonna need some fender rolling for sure. The rear strut is darn close (~1cm) but It should be ok.
Here are some pics too: http://community.webshots.com/album/70429949mJoXEZ
any bg outbacks with 225 on 16" wheels? jharl Outback Forum 0 03-23-2008 06:06 PM
Any one have problem with 225/40-18? pigboy Brakes, Steering & Suspension 7 02-05-2003 11:45 AM
Any suspension clear 225s on GC6? ecfitzgerald Brakes, Steering & Suspension 3 01-09-2003 06:06 PM
Any one running 225/40-17 WR-Xtasy Brakes, Steering & Suspension 11 07-18-2002 09:17 AM
Anyone with Enkei RMP2's with 225/45-17 tires Rocko107 Brakes, Steering & Suspension 6 03-23-2002 06:52 PM
