Old 04-20-2003, 02:22 AM   #1
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Default K&N Panel Filter and 1/4 mile times
Has anyone noticed a performance increase in their 1/4 mile time using a K&N Panel Filter? How about a K&N Panel Filter and cold air setup (drawing air from outside of car)? I'm not talking seconds being taken off but rather 10ths of a second. Even a 2-3 10ths would do. Any information would be good. Thanks!
Kevin Thomas is offline   Reply With Quote
Old 04-20-2003, 02:46 AM   #2
Ruff
Member#: 32131
2006 Nissan 350Z
Was 01 2.5 RS
Well I have a 2001 2.5 RS with just an Injen intake. Here is my fastest 1/4 mile, actually from last night..
R/T--------.610
60'--------1.979
330'------6.039
1/8-------9.465 at 71.37 mph
1000'----12.459
1/4--------15.005 at 88.51 mph
So yeah, I say it helps considering this is probably the fastest RS time I have seen for someone with just an intake.
Ruff is offline   Reply With Quote
Old 04-20-2003, 10:08 AM   #3
Kevin Thomas
Member#: 110
1989 1989 XT6
Default Reasons
Ruff,
That's an excellent 1/4 mile time considering you only have an aftermarket intake.
The reason why I was asking about just a panel filter is I'm trying to decide whether I want to use the stock air box with cold-air coming in or an aftermarket intake with a rigged up cold-air unit.
Using the stock box, it's easy because it's hooked right up to where there cold-air is coming in. With a JC Sports intake, it's drawing in hot engine bay air and I feel this is really hampering the performance of the intake. The radiator fan blows really hot air all over the air filter. I'm trying to figure out what I can use to isolate the air filter from the engine bay and just have it draw air from the fender well area. Some type of insulation/heat resistant material from a Home Depot type of store would be great.
If a simple panel filter is affective, then I may go about purchasing a K&N panel filter and just use the stock air box instead of the JC Sports unit.
Old 04-20-2003, 10:16 AM   #4
Cabal
Member#: 31159
2006 WRX, 2008 2.5i
San Remo Red
K&N panel filters have been dyno-proven to do absolutely nothing except save you money. A good CAI (Cobb) would make a difference, if slight.
Cabal is offline   Reply With Quote
Old 04-20-2003, 11:17 AM   #5
aj's25rs
Member#: 30160
9900 2.5rs
rbp,srp
i cant see a k&n not helping since all cone filters including cobb are designed the same(cotton filter with oil) and shiv did test his rs-t with the stock air box and stock filter and lost 2psi and then gained the 2psi back by putting in a k&n drop in. just my 2 cents
aj's25rs is offline   Reply With Quote
Old 04-20-2003, 01:52 PM   #6
joefocker20
Member#: 13745
2015 STI
Well, any gains by a K&N are negligible. They just save you money. I have a Ganzflow and K&N in my car, and after I buy cams, a clutch, and a flywheel; I will be replacing it more than likely. It does a good job, but I need all of the help I can get N/A since I live in CO and turbo isn't my thing.
joefocker20 is offline   Reply With Quote
Old 04-21-2003, 04:22 AM   #7
2.5RSMatt
Member#: 30497
00 RSTi
FUK HDR
I had a KN filter in my focus and I only notice a extremely small amont of throttle response difference or that could have been my brain compensating for the fact that I had just got a KN filter. I didnt feel any diff in hp or anything else.
2.5RSMatt is offline   Reply With Quote
Old 04-21-2003, 05:37 PM   #8
Kucheto
Member#: 3688
2002 Impreza 2.5RS
Blue Ridge Pearl
I just dropped K&N filter in my 02rs and the car is just a bit louder past 4000 rpm. As far as performance (hp gain that is) the car feel the same.
Kucheto is offline   Reply With Quote
estimate my horse power and 1/4 mile time! farrell Normally Aspirated Powertrain 30 07-15-2004 03:50 PM
estamite my horse power and 1/4 mile time! farrell Normally Aspirated Powertrain 0 07-11-2004 09:42 PM
What kind of power and 1/4 mile times are FP powered WRX's making? Shaitiger Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 04-01-2003 07:50 PM
Legacy 0-60 and 1/4 mile times traskw Legacy Forum 1 07-20-2002 09:42 PM
0-60 and 1/4 mile times joefocker20 Normally Aspirated Powertrain 1 03-01-2002 08:51 AM
