Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 04-20-2003, 12:03 PM   #1
strangerq
Member#: 13095
Default Dccd.
For those of you who've driven the DCCD cars......what exactly does opening and closing the center dif do to the handling?
I would assume that with the center diff open the torque split is 35 - 65 and the front and rear wheels are allowed to spin as they may - respectively.
With the diff closed I assume no wheel spin is allowed, but does that mean you are still doing 35 - 65 until/unless the rears (most likely) want to spin?
When you move the dccd control slider up and down from open to locked.....what do you actually notice in terms of handling changes?
strangerq is offline
Old 04-20-2003, 12:22 PM   #2
jaypride
Member#: 33424
2004 STI
Blue/Gold
The center diff is never open. The dccd is either in auto or manual mode, but always on.
jaypride is offline
Old 04-20-2003, 12:35 PM   #3
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
There was an extended discussion of this a while ago, and I think where we wound up was that in manual mode with the knob fully rearward, the diff was indeed open.
Given that, with the knob fully forward it is locked (and even says so on the dash).
Paul?
Glenn
ANZAC_1915 is offline
Old 04-20-2003, 05:08 PM   #4
archmanzREX04
Member#: 35551
04 STI
Default Re: Dccd.
In short: as you adjust the split further rearward, the car will tend to rotate (oversteer) upon application of throttle instead pushing (understeer) normally exhibited by FWD and AWD vehicles. In automatic mode, both the EVO and STi adjust the torque-split during the turn based on accelerometer data (and other sensors) to balance the handling of the car. Turn the knob all the way back and you can hang it out Steve Kinser style!
archmanzREX04 is offline
Old 04-20-2003, 08:45 PM   #5
shirokuma
Member#: 5489
2013 FR-S
AVO Orange
You are mainly adjusting the FWD to RWD bias the car will have under power in corners.
To be very honest, once I experienced the auto mode, I never switched out of it. Unless I'm at a gymkhana, I doubt I ever would.
Cheers,
Paul Hansen
www.apexjapan.com
shirokuma is offline
Old 04-23-2003, 02:36 PM   #6
akoshy
Member#: 20931
09 Subaru
Default Re: Re: Dccd.
The STi...yes. The US-spec EVO...NO. The US-spec EVO has a viscous coupler center diff, similar in design to what is available in the manual trans WRX. It splits the torque at 50/50 with very little variability.
akoshy is offline
Old 04-23-2003, 05:31 PM   #7
archmanzREX04
Member#: 35551
04 STI
AKOSHY,
Good catch!
I forgot to add in that one very important bit of information, it was the Euro EVO.
Here is a link about the AYC system. They had an awesome PDF datasheet on the EVO VII last year about this...I can't find it anymore. Oh well, enjoy!
http://www.mitsubishi-cars.co.uk/features/ayc.asp
No-dccd center diff fits a DCCD 6 speed and DCCD fit no mater the year of the tranny? mudbug Transmission (AT/MT) & Driveline 21 11-21-2009 05:42 PM
Dccd or no dccd? RaDZio Transmission (AT/MT) & Driveline 5 06-18-2005 09:11 PM
Help needed: RA DCCD 5-speed -> DCCD 6-speed dmross Subaru Conversions 14 04-14-2005 11:29 AM
JDM STi 5 Speed's DCCD & Non-DCCD & Tiptronic gr8wheels Drivetrain 25 02-07-2005 08:50 PM
dccd tranny with no dccd box = broken parts ImprezaRSfan! Subaru Conversions 10 10-11-2004 06:06 PM
