Old 04-20-2003, 07:34 PM   #1
2002whitewrx
Member#: 21414
02 wrx
white
Default I Need Help Quick Please!!!
My car blew the gasket out between the turbo and d/p and gas is pouring out through it! It's blowing huge clouds of white smoke out of the exhaust and barely runs it smells like gas bad and it has a flashing cel but wouldn't make it to autozone to have it tested. My mods are stage 4 with a vf22 help quickly no coolant in the oil either.
2002whitewrx is offline   Reply With Quote
Old 04-20-2003, 07:44 PM   #2
vile
Member#: 32371
'02 t-rex wagon
platinum
dude, if u got gas pouring out, dont' even turn your motor on. the dp gasket is easy enough to take care of, but it sounds like something else blew or went bad......blowing a dp gasket shouldn't cause the loss of gas......the white smoke is probably telling ya you were running lean.....maybe the gas line gave out, causing some really high egt, and blowing out your dp gasket
vile is offline   Reply With Quote
Old 04-20-2003, 08:42 PM   #3
2002whitewrx
Member#: 21414
02 wrx
white
Ok I unplugged the unichip the cel quite flashing but it's still on no more gas out of where the d/p and turbo meat it's now blowing black smoke instead of white and the egt's are low around 800 f. just driving normal it still feels like it has a slight miss but it might be cause there is no engine management.
Old 04-23-2003, 12:57 PM   #4
Austin
Member#: 7089
2016 STi
Are you saying that exhaust gas/fumes are coming from between the turbo and downpipe, or are you saying that liquid gasoline is spilling from near that location?
Austin is offline   Reply With Quote
Autometer a/f ratio gage- best location to hook up power. Need help quick-please. odin1 Electrical & Lighting 11 12-09-2003 12:17 AM
Need help quick...please read..! Porkchop-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 06-18-2003 09:07 PM
Need Help Quickly Please! P03w Interior & Exterior Modification 5 12-05-2002 01:10 PM
I Need Help Quick, Please!!!! Dirty B South East Region Forum 3 09-03-2002 09:32 PM
('93-'01) Need HELP quick please... kaos200 Impreza Forum 2 04-21-2001 08:22 AM
