Old 04-21-2003, 01:34 PM   #1
boxer02
Member#: 18037
Platinum Silver
Default autox in rain: HTR+ or V700
ok, i have new all-season sumitomor htr + and new kumho victoracer V700's mounted on 16" OEM wrx wheels.
if its raining out, which would be better to run on? i am guessing the new V700's, but i'm not sure, also at what point would the htr+ be better than the V700's if any???? (i am assuming that with 6-7 autox's on the V700's the htr+ would be better for the rain, but just wanted to get some opinions....)
thanks...
boxer02 is offline   Reply With Quote
Old 04-21-2003, 02:48 PM   #2
Tire Rack Moderator
Member#: 1215
ext. 4362
if it's real heavy rain and some standing water the HTR+ would be the choice to make but if the VictoRacers are new and it's not a heavy downpour the Kumho's will do the job
Old 04-22-2003, 08:41 AM   #3
omahasubaru
Member#: 1594
1995 WRX
2002 Legacy
Are your V700's full tread depth or shaved? Just curious. Full tread depth would probablly give you some impressive results in the rain.
Jon
omahasubaru is offline   Reply With Quote
Old 04-22-2003, 10:30 AM   #4
boxer02
Member#: 18037
Platinum Silver
well, currently they are full-tread depth, but my guess is the first autox won't be in the rain.
i just figured that at some point, the v700's would wear down to a point that they would do worse in the rain than the (basically new) htr+, just not sure at what point....
Old 04-22-2003, 02:30 PM   #5
omahasubaru
Member#: 1594
1995 WRX
2002 Legacy
Did you at least get your V700's heat cycled?
Old 04-27-2003, 01:19 PM   #6
boxer02
Member#: 18037
Platinum Silver
i heat cycled them myself.
Old 04-27-2003, 09:48 PM   #7
Gonz
Member#: 18642
2005 Impreza WRX STi
if it's simply a wet surface the V700's will be better, even when well worn.
However, if you have a surface that is not draining well and is puddling, then your V700's will sail across those sections. You'll notice this when you turn the wheel and the car goes straight.
hen you do.
If you have to drive through puddles or streams of water go with the street tires.
Gonz is offline   Reply With Quote
Old 05-13-2003, 06:40 PM   #8
boxer02
Member#: 18037
Platinum Silver
thanks for the info gonz.
i havent had the oppurtunity to autox in rain yet, and am relishing the idea.... i just know my AWD will kick some 2WD butt....
HTR+ or ASX or Ziex 512? impreya Tire & Wheel 2 10-18-2004 10:28 AM
The lesser of two evils: Sumitomo HTR+ or Falken Zeix 512? Red Rocket Tire & Wheel 18 11-11-2003 10:05 PM
Help me decide....HTR+ or SP 5000 JoeBloggz23 Tire & Wheel 7 10-17-2003 07:34 PM
Sumitomo HTR+ or ContiExtremeContact natethomas Tire & Wheel 0 08-18-2003 09:13 PM
Mod suspension or AutoX in DS? AWDconvert Motorsports 21 08-10-2002 02:18 PM
