Old 05-09-2003, 08:24 AM   #1
rommel
Member#: 32662
black
Default Please Help On Tire Size & Fitment!!!
Im getting NEW wheels 17x8 in 45 offset
my question is will 235/45/17 tires fit
without rubbing or whats the best
set-up for these kind of wheels?
thanx rommel
rommel is offline   Reply With Quote
Old 05-09-2003, 08:38 AM   #2
Tire Rack Moderator
Member#: 1215
ext. 4362
the widest tire I can recommend for you Subi is 225 but, there have been others that have used wider .... also the 45mm offset is too low .... you should use a minimum of 48mm offset
Luke@tirerack is offline   Reply With Quote
Old 05-09-2003, 08:49 AM   #3
rommel
Member#: 32662
black
Default Thanx alot
Thanx for the quick response Luke!
thats why i hear YOUR THE BEST!
in what U do
rommel
Old 05-09-2003, 10:56 AM   #4
rex n effect
Member#: 15289
02 wrx pollen silv
& 07 Hyundai misfire'R'us
If you have the wheels that I think you have, then I have the same ones with 245/40 17 tires. If you want 235 tires, then 235/40 tires will be a little bit smaller than stock, giving you slightly better acceleration due to a shorter gear ratio. 235s should fit fine with those wheels on a sedan. You could go with 245/40 tires if you want, but you may have to roll the fenders in the rear.
rex n effect is offline   Reply With Quote
Old 05-13-2003, 12:10 PM   #5
Takashi
Member#: 2536
2012 STi Hatch
kinda wanted to revive this thread...
i've done a search, and couldn't find an answer to this question:
would a wrx lowered 1.5" be okay with 17x8 wheels, +47 offset and 235/45-17 tires? i know that must be cutting it rather close for rubbing issues.
any info is appreciated
thanks!
greg
Takashi is offline   Reply With Quote
Old 05-13-2003, 12:59 PM   #6
ebeck
Member#: 35585
RIP I'll always be
The Ver8 Magistrate
No wonder every body (including myself) is confused about wheel fitment.
Another thread states
6.5" ....... +53 to +55
7.0" ....... +50 to +53
7.5" ....... +47 to +50
8.0" ....... +43 to +47
Yet above someone states
"45mm offset is too low .... you should use a minimum of 48mm offset" We are talking 8" here.
Oz racing states 53 for 8" if my memory serves me correctly. Or was it 51. Whatever, it matches neither of the other quoted statement of facts. I am guessing many fit it including others not previously stated. Is a matter of optimal. That is where I think the break down is happening. Somewhere someonw is running 245 tires on a 8.5 inch rim successfully. They would tell me it does not rub too I bet. Then you find out they have 750 lb springs.
I do not think any body has actually tried all fitments and actually kows. Very frustrating.
In the end I will listen to the manufacturer if they make a sube specific offset.
It sure would be nice to plunk down $3000 with confidence. Problem is worse with obscure rims and sizes.
ebeck is offline   Reply With Quote
Old 05-13-2003, 03:18 PM   #7
Cosworth
Member#: 3887
08 Taco, 98 M3/4/5
'00 RC51, '08 KTM
I have wheels in 17*8 et45 and 235/40/17 S-03's, so let me speak from experience regarding the size alone. You would be better off running a 235/40/17 (what i use) than the 235/45. that would obviously be a taller (than stock) and heavier tire and as such the shorter 235/40 would be a better choice. Even for gearing reasons, the 235/45 would not be a wise choice.
With the 235/40/17 S-03 tires, I get *no* rubbing whatsoever on my sedan and i am lowered about 1" all around on custom rate gound control springs (medium rate 280f/250r #). I have -2.0 degrees of camber F&R as well. I have pics that show the various clearances when mounted and there is still ample room between the key potental rubbing points. I'll dig them up if requested.
Cosworth is offline   Reply With Quote
Old 05-13-2003, 04:24 PM   #8
Takashi
Member#: 2536
2012 STi Hatch
cosworth: thanks alot, if you find the pics, if you could shoot them over to me i'd really appreciate it, just so i can get an idea... without camber plates, do you think that there would be rubbing?
ebeck: you're right, the general consensus is: confusion
greg
Old 05-13-2003, 07:06 PM   #9
rex n effect
Member#: 15289
02 wrx pollen silv
I wouln't really listen to anyone unless they actually have the setup that you want to use. I have SEEN 255/40 tires on 8.5" wide 17" wheels with 45 offset fit on a sedan, but I don't have them. Cosworth and I have the SAME fitment wheels that you want. The 235/45 tires will hurt your acceleration, but maybe not noticeably. 235/40 tires might help your acceleration a little, and they most likely won't rub. I have 245/40 tires, and they barely rubbed in the rear. My car's lowered 1" with tein h-tech springs, which are the softest aftermarket springs there are for the WRX, so it is my educated opinion that 235/45 or 235/40 tires will fit without rubbing.
!!! Urgent help on tire size !!! coquine Tire & Wheel 16 01-31-2008 10:41 AM
Help on Tire Size.... CU04BlackWRX Tire & Wheel 9 11-08-2006 12:55 PM
need help on tire size! blazerwrx Tire & Wheel 5 10-30-2006 11:23 AM
Help on tire size 18x8.5 wheel BlackSnake Tire & Wheel 18 08-10-2006 05:19 AM
Need help on tire sizes..... bizkit642 Tire & Wheel 3 05-23-2005 08:16 AM
