![]() Tire & Wheel Forum sponsored by The Tire Rack |
#1 |
Member#: 18588
Vehicle:1999 busted car silverthorn |
has anyone purchased extended wheel studs for thier impreza? Im having some trouble finding a 12x1.25 extended wheel stud... does anyone make them?
#2 |
Member#: 31506
Vehicle:05 Tacoma on TE37' White |
BUMP....also wondering if anyone makes extended studs for subarus
#3 |
Member#: 60316
Vehicle:2004 STi WRB |
the only place I've found them were located in the UK...
#4 |
Member#: 16200
Vehicle:OK Houston we have an Uncle |
There is a recent, ongiong thread, here, on just this subject....
#5 |
Tire Rack Moderator
Member#: 1215
Vehicle:800 -428-8355 ext. 4362 |
if you are changing the studs you can change the thread pitch to something more common like 12 x 1.5
#6 |
Member#: 8343
Vehicle:2005 2012 Jeep 2013 DGM BRZ |
Some rally shops in the UK sell longer 12x1.25 studs, or you can get NISMO ones (Nissan performance brand) at most Nissan dealers. You are better off however getting ARP 12x1.5 ones and just getting new lugnuts, they are much cheaper.
#7 |
Member#: 60316
sorry, but the ARP ones do NOT fit. the honda versions are WAY too small at the knurling, and the only other 12x1.5 avaliable is with a 0.658? knurl which WILL press into the subaru hub, BUT the knurl length is 1/2" too long, so you will either have to machine each stud down to size, OR bore out your brake disc holes and/or spacer and wheel holes.
but machining the bolts are pretty easy since I've got access to a lathe, so I might have to get those, or order them form teh UK. NISMO studs I have heard will fit, but they cost an arm and leg... $60 for 10, so $120 a set!!!! OMFG... yet another option is to bore out your hubs and use studs w/ larger knurling... hey, anyone interested in a a group buy of studs form the UK>??? |
| Thread Tools | |
| Display Modes | |
| Wheel Spacers/Wheel Studs, Help | Ric WRX | Tire & Wheel | 6 | 03-25-2009 09:56 PM |
| NISMO wheel studs for frequent wheel changes | leecea | Motorsports | 24 | 03-21-2009 09:11 AM |
| Mayday, Mayday! Wheel Spacers and longer wheel studs needed. | Imprezer | Bay Area Impreza Club Forum -- BAIC | 6 | 06-22-2001 02:29 PM |
| Wheel Studs | DigDug | Brakes, Steering & Suspension | 7 | 06-12-2001 12:47 AM |
| X-threaded wheel studs.. oopsies | wistful | Brakes, Steering & Suspension | 5 | 04-18-2001 08:53 AM |
