Old 04-22-2003, 08:51 AM   #1
RALLYT-WRX
Member#: 9369
F#ck U & Your Stance
BLOD
Default Carbon Fiber Hood Install Questions.........
I have some questions for those of you that have installed a Carbon Fiber Hood on your WRX's:
1. Are you using hoodpins, or are they not needed?
2. If you used Hood pins were did you place them on the cross member under the front of the hood? Pics?
3. Also did you guys wax or polish your hood, or just clean them with normal car wash stuff?
Thanks for all the help.
RALLYT-WRX is offline   Reply With Quote
Old 04-22-2003, 08:57 AM   #2
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
1. I didn't use them on mine. The latch seemed beefy enough. Judgement call.
2. n/a
3. I wash and wax my hood just like the rest of my car.
rjrutzky is offline   Reply With Quote
Old 04-22-2003, 08:59 AM   #3
RALLYT-WRX
Member#: 9369
BLOD
Default Carbon Fiber Hood ?
Thanks for the info.
Did you reuse the stock IC splitter, or did you do away with it?
Thanks
Old 04-22-2003, 09:01 AM   #4
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
reused it
Old 04-22-2003, 09:27 AM   #5
RALLYT-WRX
Member#: 9369
BLOD
Default IC Splitter
How did you attach the Splitter? Did you just use some self tapping screws and screw them into the Hood webbing or did your hood have the threads in it for the splitter?
Thanks for all your help.
Old 04-22-2003, 02:52 PM   #6
RALLYT-WRX
Member#: 9369
BLOD
Default Bump
Bump
Old 04-22-2003, 04:59 PM   #7
^jynx^
Member#: 1787
ok so mine is not a wrx but its just to give you an idea.
1. yes i used pins
2. see pics
3. just like a normal car. it has or should have the same clearcoat as your car, so just was and wax
here is how the post is mounted
close up of the pin
under side of hood where post goes threw
^jynx^ is offline   Reply With Quote
Old 04-22-2003, 07:32 PM   #8
ImpreziveWRX
Member#: 17643
2002 WRX Wagon
The reason for the hood pin is the prevent the hood popping out
Most CF hood is 2 pieces. Upper CF face and bottom reinforcement
Everything that holding the chassis and the hood is attached on the bottom reinforcement part of the hood.
If the quality of the hood does not meet certain standard, both part of the hood might tear apart while driving.
When that happened, the upper part of the hood will basically fly away and the bottom part of the hood will stay on your vehicle.
The purpose of the hood pin is to hold upper part of the hood by pushing it down
It is not necessary to have the hood pin, but its is highly recommended for extra secure purposes
I know this place www.rg-s.com they sell CF hood with free sparco hood pin
E-mail them if you guys have any question
ImpreziveWRX is offline   Reply With Quote
Old 04-23-2003, 06:45 AM   #9
Impreza2fast
Member#: 14088
2002 WRX (RIP)
Default my opinion
1. I'm not using a hood pin, because they told me that i didn't need it and that the hood would hold up just fine
2. N/A
3. I'm just washing it and waxing it like the rest of the car
joe
Impreza2fast is offline   Reply With Quote
Old 04-23-2003, 09:07 AM   #10
RALLYT-WRX
Member#: 9369
BLOD
Default Hood
Thanks for the great useful info, and thanks jynx for the close up pics.
I am installing my hood on thursday, so I will let you guys know how I make out.
Old 04-30-2003, 10:42 AM   #11
MK2TMR2
Member#: 18501
1996 Eunos Roadster
R2-Limited
I just installed my VIS Racing CF hood and it re-uses the latch from the stock hood as well as all the "weather stripping" material to keep air turbulence to a minimum. At 70-80mph the hood still wobbles around a bit. I don't *want* to use hood pins, but I may need to just for piece of mind.
Does anyone else have long-term experience using the VIS hood w/o hood pins? I'd rather not drill my new CF hood if I don't have to!
Thanks.
MK2TMR2 is offline   Reply With Quote
Old 04-30-2003, 11:26 AM   #12
Chuck H
Member#: 20442
Just as a FYI, hood pins are required in many states on any composite hood. Also, if you take it to the track at all, I believe that most tracks require them for composite hoods or you can't run. In general they're a good idea on any fiberglass or carbon fiber hood, regardless of what the manufacturer may say.
Chuck H is offline   Reply With Quote
Old 04-30-2003, 11:31 AM   #13
^jynx^
Member#: 1787
i would strongly suggest hood pins. The carbon is VERY easy to drill. Just start small and work your way up in drill bit size till you get to the size you need. Also if you dont like the color of the pics just paint them or get the coated.
Old 04-30-2003, 11:48 AM   #14
MK2TMR2
Member#: 18501
1996 Eunos Roadster
R2-Limited
OEM Carbon Fiber hood 02-03 w/ NRG carbon fiber hood struts evoklr101 Exterior/Styling 9 06-05-2008 02:15 AM
Carbon fiber hood trimming question jakeachy Interior & Exterior Modification 10 01-19-2008 10:34 PM
Carbon Fiber Hood Install Help abi Interior & Exterior Modification 3 02-09-2005 07:31 PM
Carbon Fiber Hood Care questions brcewane Interior & Exterior Modification 5 01-17-2005 11:36 PM
Carbon Fiber hood installed past weekend gonzfather Texas Impreza Club Forum -- TXIC 22 09-23-2002 01:42 PM
