#1 |
Member#: 15552
Vehicle:'87 Hutch TRICKSTAR babyblue on pinkTuff II's |
Hi everyone,
I just picked up a new, OEM rear lip kit for my WRX and am wondering if there is anything I should know before I install it. I glanced over the supplied instructions, and the procedure seems fairly straightforward. I was surprised to find out that some drilling is required though (to mount the center piece). Anyways, if any of you has installed your own OEM rear kit and has any tips, warnings, etc, I'd greatly appreciate it! Peace CL ![]() ![]() ![]()
#2 |
Member#: 10276
Vehicle:2001 Impreza RS 2002 WRX, 2012 535i |
i had to buy some more heavy duty velcro because the supplied velcro did not hold the side pieces on tight to the bumper. i just took off the old and added the new.
#3 |
Member#: 15552
Hi StarDog,
Good timing...just logged on and would have been waay disappointed to see no replies. Thanks for not leaving me hanging! ![]() The supplied velcro does look pretty ineffective. I don't think I've ever seen this type of velcro--rigid plastic instead of the usual fabric type. I guess I'll go pick some heavy duty ones later today. Any suggestions on where to track the stuff down? Peace CL ![]() ![]() ![]() |
#4 |
Member#: 15106
Its effective alright if you mount it correctly. make sure
your surface is clean and warm enough for the adhesive. I use RC car nitro spray (motor spray) to degrease the surface before taping it on. the US front lip was trickier than the rear valance. wear goggles when you're looking up into the rear bumper. ![]() |
#5 |
Member#: 15552
kenchan,
Thanks for your input. I just have one more question about mounting the black, center piece of the OEM rear underspoiler/lip kit. The supplied instructions show a step, which seems like it tells you to trim off and discard (PIC of the part & a trash can next to it) one of the the mounting tabs on the underspoiler's center piece. Only thing is, in a step later on, the directions call for securing the center piece by inserting a screw through the tab (which would not be there anymore). ![]() Can you please help clarify? It seems a little odd to me to trim off the mounting tab, esp since it is not pre-scored. If the tab wasn't necessary, Subaru should have just left it off in the first place! Thanks in advance, CL |
#6 |
Member#: 15106
PM'ed.
![]() oh yah, you may want to trim some of that foam on the center section too as it makes the center piece bulge out on the right hand side. i trimmed off a good 1/2in..enough to have some friction with the rear bumper, but not so much to bulge it out. |
#7 |
Member#: 10276
Come to think of it, I didnt replace the velcro...the rigid velcro is a hell of a lot stronger than the fabric kind anyway..
What I did have to do was buy some more of the double sided adhesive (the thuff that you pull the red backing off of) (HOME DEPOT) as the sides of the rear did not fit up tight to the bumper, it kind of bubbled out. EVEN THOUGH IT WAS INSTALLED CORRECTLY, it still bubbled out. I did this about 8 months ago, I cant remember exactly what I did, sorry. what i do remember is that i had to get 4 rear sets because the rear sides kept coming to me all scratched up. I finally got the rear on at least a month after the front and sides...now it fits perfect, tight to the bumper and i have had no problems at all...and i cut the tabs off of the rear center piece, after the screw. Hope this helps...you may not have to use anything but what was supplied, but its good to have the stuff handy if you need it. |
#8 |
Member#: 3960
I am about to redo my rear OEM lip install. What a pain in the butt that install was. Something that looks so easy is actually very frustrating.
Anyone know where I can source that plastic velcro at?? |
#9 |
Member#: 15106
why dont you just use mounting tape instead and make it
more of a permanent fix? the side pieces are somewhat not contoured correctly so some may have problems with it popping off later...but with a tad bit of heatgun (if needed) you can re contour it to match the curve of the rear bumper. heatgun is your friend. ![]() note: i did not have to use a heatgun on the rear sides. only the front. |
#10 |
Member#: 2394
Vehicle:2005 Legacy GT wagon 2009 Forester X |
Mine went on ok no probs,, 1 other suggestion,,two people ,extra set of eyes and hands always helps get things lined up right.
Rudy ![]() |
| Thread Tools | |
| Display Modes | |
| Anything I should know before installing SPC's camber bolts? | eastcoastGC8G | Brakes, Steering & Suspension | 5 | 03-02-2010 09:20 PM |
| Scooby Noobie taking long high altitude trip, any thing I should know, 08 WRX Sedan | MurphysLaww | Newbies & FAQs | 14 | 03-20-2008 09:29 PM |
| oem wrx rear lip help | Tragic | Interior & Exterior Modification | 0 | 08-24-2003 02:30 PM |
| Anything I should know before installing my COBB intake? | 2.5RSMatt | Normally Aspirated Powertrain | 11 | 04-20-2003 02:30 AM |
| OEM WRX Rear Lip Install? | RooK | Interior & Exterior Modification | 5 | 02-07-2003 06:14 AM |
