![]() Tire & Wheel Forum sponsored by The Tire Rack |
#1 |
Member#: 28876
NWIC
Vehicle:2000 Impreza 2.5 RS Blue Ridge Pearl |
Well its about new tire time. And me having no money I think I'm going to see about getting some credit at Discount or somewhere. Rather than just getting tires, I'm thinking I need some rims too. But I was wondering if anyone knows if you roll the fenders on a GC8 how wide of 17" rims/tires you could fit under the fender without any rub on corners. Also with maybe a 1" lowering too.
this whole "rolling the fenders" is new to me.
#2 |
Member#: 2272
BAIC
Vehicle:95 L AWD LIFTED!!! 1970 Subaru FF-1 Coupe |
I dont think you can fit more than a 225 series tire under the fenders. I just rolled my fenders TODAY (ghetto style) so my 225/50/16's wont rub anymore, and I dont think any larger of tire will fit without bending the fender outwards quite a bit.
Wheel width isnt really that relevent, but 7.5" is about optimum for 225 series tires, 8" would work too. |
#3 |
Member#: 4830
SCIC
Vehicle:13 Ducati SF/350Z Red/Blue |
Offset is a factor.
I have rota subsero's 17" on my 2001 RS, wrapped with 215/45-17's Summitomo's, and they rubbed with the car being lowered 1", requiring the fenders to be rolled. |
#4 |
Member#: 28876
NWIC
GQ~So you do have your fenders rolled? And whats your off set and how wide of wheels?
#5 |
Member#: 4830
SCIC
Yes, My fenders are rolled. The Sub zero's have a 48mm off set, and are a 17"x 7.5" wheel. They barely rubbed. Just removing the rubber liner on the wheel well might work, however, I went all out and also rolled the fenders. Oh, this is only on the rear wheels, the fronts clear fine.
#6 |
Member#: 4830
SCIC
Some info on professional fender rolling:
http://www.bmwdiy.info/fender-rolling/index.html http://www.robsaudiworld.com/fender.htm Some info on the quick cheap way to roll your fenders. I would recomend a plastic vacumm pipe(the long shop vac pipes) instead of a baseball bat. Whatever you use, make sure it is soft and won't cause the paint to chip. http://www.quickhonda.net/fenderRolling.htm |
#7 |
Member#: 28876
NWIC
Thanks GQ for the info. Lucky for me I have a few friends in the body work buisness. SO when they fix my left rear quarter panel I'm going to ask them to do the fenders. I need to save money now that I have a job again though.
#8 |
Member#: 6945
Vehicle:2001 Impreza RS Black |
I've been finding it interesting with most of you that have rubbing issues it's always in the rear and not in the front. For me it is the opposite.
I have the car lowered about 30mm. I just bought the 17x7 Superleggera's with an offset of +48 with continental conti extreme tires 215-45-17 and they rub slightly when the nose of the car goes down quite a bit. But no rubbing in the rear. This tire has quite a large tread area and this is not helping. I'm just wondering if someone as had the front rolled and how they dealed with the plastic liner. Was it trimmed back? |
#9 |
Member#: 2272
BAIC
I cut the plastic liner with sissors. Yes, its ghetto
But it worked. No more rubbing. |
#10 |
Member#: 19542
SCIC
Vehicle:05 GSX-R 1000 02 WRX Gold |
Im running 17x8.5's and Im rubbing in the back only... Im also lowered about an inch... I need that fender roller gadget
| Thread Tools | |
| Display Modes | |
| pulled and/or rolled fenders | imprezagirl06 | Mid Atlantic Impreza Club -- MAIC | 13 | 04-01-2010 01:04 PM |
| rolled front and back fenders? | DCsubieSTI | Newbies & FAQs | 3 | 02-12-2010 03:41 PM |
| stock wheels. Prodrive springs. will i need to roll fenders? | binx159 | Brakes, Steering & Suspension | 2 | 03-16-2009 12:14 AM |
| Retaining Fender Liner with rolled fenders | blahhblahh | Interior & Exterior Modification | 15 | 08-20-2008 07:41 PM |
| Stock height MY00 RS w/ Prodrive 18's to roll or not to roll fenders? | aussiebrydon | Bay Area Impreza Club Forum -- BAIC | 5 | 02-11-2002 12:04 AM |
