Old 04-23-2003, 10:24 AM   #1
Teamugi
Member#: 7771
Default Sunroof and vent controls
Interesting thing happened to me today. I had the sunroof opened, all the other windows up, and set the air to be re-circulating. Air was not blowing. I drive on the interstate, get up to 65 and suddenly see the lever move from re-circulate to vent. Freaked me out.
So, I pushed to lever back to re-circulate when I reach the toll booth and drive off. Again it did it again. I don't know if the owner's manual explains this occurence, but I am guessing this happens because of the vacuum I have created in the cabin because of the sunroof up, windows closed, and airflow on re-circulating.
Not a huge problem, but I just wanted to see who else had this occurence. Maybe my car just has a mind of its own........
Teamugi is offline   Reply With Quote
Old 04-23-2003, 11:32 AM   #2
Brad Pittiful
Member#: 34931
thats crazy and weird
Brad Pittiful is online now   Reply With Quote
Old 04-23-2003, 12:48 PM   #3
EvasionOfTruth
Member#: 13282
2007 FXT
WRB SPB Edition
I gotta try this on the way home....
EvasionOfTruth is offline   Reply With Quote
Old 04-23-2003, 01:01 PM   #4
RokketRide
Member#: 17984
1967 Barracuda
2000 OBSTi
Your car is haunted. Get rid of it.
Give it to me
RokketRide is offline   Reply With Quote
Old 04-23-2003, 02:15 PM   #5
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
The door is binding, the tension is slowly overcoming the friction in the lever.
Old 04-23-2003, 02:39 PM   #6
Slalom RS
Member#: 25577
2004 TS Wagon
Sounds like a problem I had a few weeks ago...
I'd put it on one setting, a few minutes later I'd go to change it and it wasn't where I left it. Wierd.
What my problem turned out to be was the wire lever that controls the vents/heat came off completely. Figured this out when I was only getting hot air. Look under the passenger side dash, closer in towards the center of the car. Make sure that wire cable thing is connected where it should be...mine was in a clear sheath, sort of like a derallieur cable for a bicycle...
Slalom RS is offline   Reply With Quote
Old 04-23-2003, 07:18 PM   #7
EvasionOfTruth
Member#: 13282
2007 FXT
WRB SPB Edition
Tried doing that trick on the way home to no avail.
Buster
Old 04-23-2003, 08:27 PM   #8
Teamugi
Member#: 7771
I will take a look at the wires. I think I must have loosen something when I took the dash apart (doing some wiring work).
Oh well, if that doesn't fix it, I think my car is haunted. Hey does a haunted car give me more hps and torque?
Oh well, if I can't fix it, it is a neat trick that freaks out my passengers.
Old 04-23-2003, 08:39 PM   #9
Slalom RS
Member#: 25577
2004 TS Wagon
Don't go taking apart your dash just yet. That's what I did. Took apart half the dash, fiddled around with everything I could find, then eventually just followed that rod/cable down to the passenger floor area. I never had to take off so much as a screw...
Old 04-24-2003, 01:20 PM   #10
goobie
Member#: 8273
2006 WRX Wagon
That happend to me one time as well.
It got to the point where every time I switched to re-circ it would slide it's self back to vent. Eventually it seized completly on vent and I could no longer slide the tab... Then as mysteriously as the problem came, a week or so later, It fixed itself. I've given up trying to explain that one to myself!
Cheers,
Chad
goobie is offline   Reply With Quote
Old 04-25-2003, 03:38 AM   #11
Foz
Member#: 1776
2000 2.5RS
BRP
Yup, same thing happened to me.
What I noticed during that day, it was extremely windy outside while I was driving down on the highway (wind gusts of 40KM+).
I wasn't able to switch it during the drive, but afterwards, not a problem.
I'm thinking it's the wind that was keeping one of the air vents into the cabin opened.
Foz is offline   Reply With Quote
Old 04-25-2003, 06:23 PM   #12
Boxologist
Member#: 21118
Maybe u have a squirrel or cat in the dash or firewall?
Boxologist is offline   Reply With Quote
Old 04-26-2003, 12:56 AM   #13
obyone
Member#: 16523
I thought it was normal.
I figured that there was a blocking plate, keeping fresh air from entering the system when you moved the lever to recirculate. At speeds and with the sunroof open, the pressure outside is enough to force the blocking plate open and thus moves the lever to fresh because they are connected mechanically. But I may just be nuts and you have gremlins.
obyone is offline   Reply With Quote
Old 04-26-2003, 01:46 AM   #14
Blindeye_03
Member#: 4418
2016 Focus ST
My car takes itself off of recirculate at about 80-90mph, and switches it to vent...talk about annoying..
its like the airflow pushes it open?
weird and annoying.
time 4 bed.
-justin
Blindeye_03 is offline   Reply With Quote
P1443 Evaporative emission control system vent control function problem gtlegg Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 09-21-2009 04:09 PM
Evaporative emission control system vent control function problem holtian143 Newbies & FAQs 8 09-30-2005 11:19 AM
Evaporative emission control system vent control function problem holtian143 Service & Maintenance 3 09-29-2005 06:24 AM
Check engine code P1443: Evaporative emission control system vent control function? garface Normally Aspirated Powertrain 7 11-20-2002 06:53 PM
