Old 01-28-2001, 06:14 PM   #1
Suba-RAW
Member#: 2831
Question Oil drain plug size...
I know what you guys are thinking. I'm not asking about the stock drain plug size. I know it's 17mm. I have the performance gauge pack with the oil sensor for the oil temp and the drain plug is a lot bigger than 17mm and all I have to fit it is a crescent wrench. You know the old saying, "Use the right tool for the right job" Well, that's my goal. This question was posed on an earlier post and the person was told 17mm. I know that's not right. I asked the question on another post and got no answer. Does anyone know?
Thanks
Suba-RAW is offline   Reply With Quote
Old 01-28-2001, 08:53 PM   #2
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
Post
I have the performance gauage pack installed on my MY00 and yesterday was changing my oil and forgot about the whole "bigger than 17mm plug". So I looked at it some more and decided to use a big C clamp pliers. That's all it took. I'd guess it was around 21mm. The biggest problem was that with the electrical cord coming out of the drain plug, I couldn't fit anything over it. Thus using pliers.
kastle
<a href="http://www.azscooby.com" target="new">azscooby.com</a>
kastle is offline   Reply With Quote
Old 09-28-2001, 04:23 PM   #3
lgkahn
Member#: 9793
2002 2010 legacy gt
red
I need one of the sensor units from the oem oil sensor gauge
anyone have a lead on a new or used one...
thanks
failing that I need a 20X1.5 drain plug with a 1/8-27 npt center to put a sensor in
lgkahn is offline   Reply With Quote
Old 09-28-2001, 06:08 PM   #4
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
Gee. My 19mm socket is the one that's always got oil in it...
Edit: From a different car. The Subie is 17 for sure.
CosmoTheCat is offline   Reply With Quote
Old 09-30-2001, 04:25 AM   #5
Suba-RAW
Member#: 2831
lgkahn,
I think you would be better off starting a new thread and reposting your question, and possibly a little clearer. This is a pretty old thread you brought back that is only slightly related. You might try Sugar at Troncalli Subaru, she can get a lot of OEM stuff. Or try your own local dealer.
I did a quick search on Dogpile and found this site. Maybe they can help.
Quick question: Oil drain plug size, with gauge pack? Siper2 General Community 10 07-27-2005 09:12 AM
Rear differential oil fill and drain bolts, same size as the oil drain plug? scooterforever Transmission (AT/MT) & Driveline 4 01-24-2005 07:06 PM
Oil Drain Plug Size AlanTheWoo Service & Maintenance 6 06-10-2002 09:54 AM
Oil Drain Plug Thread Size daytontp General Community 10 01-04-2002 12:35 PM
oil drain plug size tofu86 Service & Maintenance 3 11-26-2001 05:39 PM
