Old 04-23-2003, 09:07 PM   #1
sszyma
Member#: 31399
07 WRX Wagon
Urban Gray Metallic
Default wrapping da header
Ok my borla header is arriving on Friday and I have searched all post relating to the header CEL and wrapping it also. My question is has anyone ever had a problem when they wrapped the header? I bought the thermo-tec graphite wrap. It seems to me it would be better to wrap it because the outside will not have such a significant delta T. Anyone with experience wrapping their header? i know it should get rid of the CEL though.
sszyma is offline   Reply With Quote
Old 04-23-2003, 09:51 PM   #2
Poppa smurf
Member#: 8257
2004 STI
Silver\Silver
Poppa smurf is offline   Reply With Quote
Old 04-23-2003, 11:32 PM   #3
codger
Member#: 13486
06 Legacy GT wagon
Wrapping may corrode and crack your headers. Get a code reader to clear the inevitable CEL instead.
Jim
codger is offline   Reply With Quote
Old 04-24-2003, 12:28 AM   #4
AustinSTi
Member#: 9386
2000 2.5rs sedan
silverthorn
no problems in my experience, but remember to wear gloves....fiberglass splinters are not fun.
AustinSTi is offline   Reply With Quote
Old 04-24-2003, 03:41 AM   #5
Andrew Bacon
Member#: 2267
00RS
rutherforddesign.com
There is some discussion on another forum about this with some pics:
http://www.rs25.com/Forums/showthrea...ight=thermotec
I've been using thermotec for a couple of months with no problems so far.
Subaru used insulation on the stock manifold to keep things cooler down there and keep the cats hot!
Andrew Bacon is offline   Reply With Quote
Old 04-24-2003, 08:39 AM   #6
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 5MT EJ22T AWIC Swap
Read through all the posted information/threads.
Personally after talking with someone that had a borla header, and have it crack because he wrapped it......I would not wrap it.
If you want to do anything, get it jet coated.
Legacy777 is offline   Reply With Quote
Old 04-24-2003, 09:08 AM   #7
joefocker20
Member#: 13745
2004 STI
I put mine on the other day, and no CEL yet. I din't notice much of a butt dyno gain though. Hopefully when I do away with the cats or buy a high flow cat it will be more noticeable. Then on to a clutch, flywheel, and some cams if I ever get my amended return refund, I'm starting to give up hope on it
joefocker20 is offline   Reply With Quote
Old 04-24-2003, 10:04 AM   #8
Opie
Floresbian
Member#: 470
2013 BRZ, 2011
Forester, '04 Chev 2500HD
If you wrap it, it will crack and wrapped headers are not covered by the warranty.
If you get a CEL get a MIL eliminator or a mechanical CEL fix.
Opie is offline   Reply With Quote
Old 04-24-2003, 10:20 AM   #9
sszyma
Member#: 31399
07 WRX Wagon
Urban Gray Metallic
I've read that many people complain about the header cracking w/o even wrapping it. So maybe if it cracked when wrapped it would have cracked anyway. I just can't see wrap ruining the header. Its only a 4 cylinder not a big-block or anything.
Old 04-24-2003, 11:20 AM   #10
subarumantoo
Member#: 3257
2000 ImprezaRS
Blue Ridge Pearl
Hey, I wrapped my Borla about three weeks ago and so far so good. Here is the link, with pictures...
http://rs25.com/Forums/showthread.php?threadid=7661
subarumantoo is offline   Reply With Quote
Old 04-24-2003, 12:08 PM   #11
DanzBorin
Subaru Bounty Hunter
Member#: 7131
2008 STi DGM (3rd
STI) prev 05 STi (white)
read my post in that thread... header wrap doesn't just crack them... it can be much worse...
DanzBorin is offline   Reply With Quote
Old 04-24-2003, 03:01 PM   #12
Andrew Bacon
Member#: 2267
00RS
Originally posted by legacy777
[B....Personally after talking with someone that had a borla header, and have it crack because he wrapped it......[/b]
Was it a Gen. 4 header? Curious, thanks.
Old 04-24-2003, 06:42 PM   #13
Legacy777
Member#: 4800
No I don't think so.
Old 04-25-2003, 06:43 PM   #14
Bob O
Member#: 1502
2000 2.5RS & SV1kS
BRP
Mine are wrapped, always were wrapped (ie previous owner), and I drive alot. Had them on since like last fall, probably put 20k on them. No evil has occured. And it keeps the CEL away. And they're Gen 3's (oooooh).
If they crack it's likely because the turds at Borla couldn't produce a nice TIG weld to save their lives. I had an EGT and A/F bung put in the headers at work by a certified welder and he makes the Borla welds look like they were done by a blind monkey with the crack withdrawl shakes.
Bob
Bob O is offline   Reply With Quote
Old 04-25-2003, 07:18 PM   #15
codger
Member#: 13486
06 Legacy GT wagon
I had read that they don't crack, they just corrode, like a very bad version of rust. You wont see the damage under the wrap, until it starts to perforate. It may last 1 to 3 years instead of 7 to 10 or longer. Several shops here advised me against wrapping; racers do it, destroy their headers in a season, and get a new one from their sponsor
So as suggested here, if CEL is the only reason for wrapping, instead get it coated, move your sensors, get a MIL eliminator, or keep a code reader handy ( if CELs are infrequent enough)
Jim
Old 04-25-2003, 10:38 PM   #16
Andrew Bacon
Member#: 2267
00RS
Originally posted by Bob O
.....he makes the Borla welds look like they were done by a blind monkey with the crack withdrawl shakes.....
Bob
Didn't you know? Borla has been using crack addicted monkeys in the factory since 1992.
The wrap broke on a spot on my header and it is unraveling!
It is only about 2-3 months old. Maybe I streched it too tight and thermal expansion broke it? I dunno. Pisser.
Old 04-28-2003, 06:44 PM   #17
Andrew Bacon
Member#: 2267
00RS
I spoke to Alex Borla at the mini SEMA show in LA this weekend.
He said he would replace a failed header regardless of what has been wrapped on it, no problems, no questions.
Borla can be reached at 805-986-8600
Header Wrap the Turbo? Got extra material... TEREX Factory 2.0L Turbo Powertrain 19 03-10-2008 10:11 PM
don't wrap borla header suberboy Normally Aspirated Powertrain 24 09-12-2007 06:25 PM
To wrap or not to wrap borla header?? scoobysnack69 Factory 2.0L Turbo Powertrain 23 08-08-2006 05:04 PM
is header wrap the same as exhaust wrap? WRobX Newbies & FAQs 7 12-29-2005 11:34 AM
Turbo Wrap AND header wrap FatCatTurbo Private 'Wanted' Classifieds 4 10-14-2003 01:48 PM
Message Board Statistics All times are GMT -4. The time now is 10:16 PM.
