Old 02-16-2001, 10:12 AM   #1
sbsnyder
Member#: 2440
Post Installation of STi V5 suspension
I've really been considering purchasing the STi V5 suspension, but I'm unsure about installation.
How many hours labor would it take a professional to do it?
How many hours would it take a newbie to do it?
The parts are less than $500 so if I can get it installed for a good deal I go that route. If we're talking $200+ for installation I may do it myself.
Any suggestions?
Thanks in advance,
Stacey
[This message has been edited by sbsnyder (edited February 16, 2001).]
sbsnyder is offline   Reply With Quote
Old 02-16-2001, 11:31 AM   #2
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
professional = $250-500 seems to be the going rate, plus you should get it aligned. (another $60-120 there.)
DIY rookie = 5-8 hours, with equally inexperienced help. The center nut on the stock strut rod is the hardest-- Subaru sells a tool just to get it off, and someone in the MWIC welded up their own instead. It's a bugger.
ColinL is offline   Reply With Quote
Old 02-16-2001, 01:06 PM   #3
sbsnyder
Member#: 2440
Post
But what about bleeding out the brake lines?
Did you do that yourself as well?
Stacey
Old 02-16-2001, 01:35 PM   #4
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post
It's a 19mm socket, not 17mm. & you do need an alignment afterwards because like Shawn pointed out, you've messed with the camber.
RidinLow is offline   Reply With Quote
Old 02-16-2001, 01:42 PM   #5
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
Post
I maxed out my negative camber and didn't need an alignment. Yes I bled the brake myself, (start at the front and move back, not opposite)..we did it backwards and I got a limp pedal due to it...to the floor baby. We re-bled from the front to back and now its all good.
STiShawn is offline   Reply With Quote
Old 02-16-2001, 01:44 PM   #6
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
Post
Ridin Low, its a 19mm for the strut bolts on the uprights, its a 17mm for the strut shaft nut.
Old 02-16-2001, 03:01 PM   #7
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Post
I dont remember what size socket I used but it was on the end of my air gun, and it zipped the nut right off, no need for a 6mm hex wrench hehe.
Jay McDade
Auto Tech--Lincoln/Mercury/Jaguar
Old 02-16-2001, 03:04 PM   #8
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Post
StiShawn, most of the time when you mess with camber, you change the toe. So it also needs to be adjusted. Thats why the procedure for doing is an alingment is as follows.
Always start in the rear, with rear Camber if adjustable, then do Toe.
Go to the front, if adjustable you Do Camber, Caster then toe.
just a heads up
Took me 3 hours, to install my suspension, and bleed the brakes, by myself. But I have the added benifit of a heated shop, lift, air tools, and the know how. I would charge, around 250 w/alingment, to do the install, on the side of course.
now if someone had a preassembled set, 150 bucks w/align. But I have no time ,
Jay McDade
[This message has been edited by McDade (edited February 16, 2001).]
Old 02-16-2001, 04:24 PM   #9
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
Post
I've done suspensions before but only the RS once. It took me by myself about 4 hrs with air tools and such. I did the cut the tab short cut so I didn't have to bleed the brakes. I thought it was relatively easy, but make sure to soak all the bottom strut bolts overnight if possible with some sort of penetrating oil. I didn't have any problems removing any of them after that. Here is a link to my pics: http://www.azscooby.com/mods/AZScooby/Peaty/p1.shtml
If you were talking about the top center strut bolt that was a 17MM not 19mm. I have a pass through socket set that makes the job a little easier but an offset box should work just fine too.
<IMG SRC="http://www.azscooby.com/mods/AZScooby/Peaty/images/topbolt.jpg" border=0>
Peaty is offline   Reply With Quote
Old 02-16-2001, 11:17 PM   #10
Marcin
Member#: 2874
2005 CGM WRX WGN
Jorge Tunned BattleWagon
Post
I'm not worried about my future suspension install.
I'll just hold a "Suspension install party", and supply beer to the drunken mob...ahem..I mean skilled profesionals
Marcin is offline   Reply With Quote
Old 02-17-2001, 12:11 AM   #11
10th Warrior
Member#: 2230
2000 2.5RS
Silverthorn, PGT #671
Post
all you need is an offset box end wrench (17mm) and a 6mm allen wrecnh. and two sets of hands.
we did two suspension installs with one manual spring compresor and no air tools in about 8 hours, though we were taking a few beer breaks.
10th Warrior is offline   Reply With Quote
Old 02-17-2001, 12:26 AM   #12
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
Post
10th Warrior helped me do mine, its a pain in the ass, but do-able. Make sure you have metric wrenches and sockets, a spring compressor, pliers and jackstands. Plus 2-3 people. Svae your self the money, do it yourself. I didnt need an alignment afterwards, all your changing is the camber of the wheel, your toe and caster should remain as was.
Old 02-17-2001, 04:38 AM   #13
JGard
pooptastic
Member#: 1904
2011 E70 X5 35D
E36 M3/4/5
Post
yeah, i had never done anything major before, but i had no problem with this. I had a couple helpers, and after a bit, got a 2ft. breaker bar, and it was good from there.
JGard is offline   Reply With Quote
Old 02-17-2001, 04:51 PM   #14
10th Warrior
Member#: 2230
2000 2.5RS
Post
sounds like shawn's instalation
we used a cheater bar to get the bottom bolts loose. i know its bad, and i did break a rachet, but that's why you do it with garunteed for life stuff
Old 02-18-2001, 10:15 PM   #15
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Post
When I installed my v5 suspension it took 52 minutes from wheels on, to wheels back on again. That includes a brake bleed, none of that cheating cutting the mount bit.
Midwayman is offline   Reply With Quote
Old 02-19-2001, 10:58 AM   #16
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
Post
We did 2 cars at the same time remember...no air tools, no lift..and no tab cutting either.
Old 02-19-2001, 11:55 AM   #17
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
Post
i still have trouble believing the 52 min story.. it took a good 10 min to get the rear strut top bolts undone + all the time compressing + uncompressing the springs
to get the strut top nut off i ened up using a pipe wrench with a 17mm socket and a 6mm allen wrench+pipe
only thing i see missing from the above is a torque wrench subaru bolts are crappy...
3 computer (nonautomotive types)guys took about 6 hrs w/cutting break clips to do one car next time 3-4hrs or less... had to do a couple of struts twice
[This message has been edited by Jaxx (edited February 19, 2001).]
Old 02-19-2001, 06:53 PM   #18
jagcars26
Member#: 2394
2005 Legacy GT wagon
2009 Forester X
Wink
Yeah right, 52 mins,no way, or did it take you 52 minutes to figure out ya did it wrong.Not flaming you just dont believe it.
Rudy
jagcars26 is offline   Reply With Quote
Old 02-19-2001, 07:01 PM   #19
RidinLow
Member#: 329
1995 325i
Arctic Gray
Smile
What do you want him to do, videotape him doing another suspension?
Old 02-19-2001, 09:58 PM   #20
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Post
If you dont believe me, ask 8complex and Donnie. They did the install with me. We had air tools, 3 people, no spring compressors and the means to keep all four wheels off the ground at once. Helped that this was like the 6th install Donnie had done.
edit: Actually we were somewhat annoyed we didnt make the 45min WRC stage mark.
[This message has been edited by Midwayman (edited February 19, 2001).]
Old 02-19-2001, 10:21 PM   #21
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Post
For those who dont believe...
here is the thread about the install http://www.i-club.com/ubb-files/Arch...-005022-2.html
In the archieve so I *cant* have edited it.
Posted oct 6 4:13pm
Old 02-20-2001, 12:55 AM   #22
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
Post
52 minutes huh? Come prove it. Did you 4 spring compressors, or a wall mountes one, and was this on a wagon (much easier to work on).....I just cant beleive that claim of under an hour.
Old 02-20-2001, 07:28 PM   #23
jagcars26
Member#: 2394
2009 Forester X
Thumbs up
Ok OK ok I believe it,,damn thats fast.
Rudy
('93-'01) Any interest in a set of STi v5 struts? Speedwagon Impreza Forum 1 03-15-2007 06:17 PM
Installation of STI V5 Wing on GC8 willguidry Interior & Exterior Modification 16 02-28-2003 11:17 PM
Got the STi v5 suspension installed... lucien2 Legacy Forum 28 02-12-2003 08:18 PM
experience with STi v5 suspension? deepbeep Technical Forum Archive 31 07-21-2000 01:35 PM
STi V5 suspension observations FatChanceTi Technical Forum Archive 3 05-15-2000 09:52 AM
