Welcome to the North American Subaru Impreza Owners Club Friday August 1, 2014
Old 04-23-2003, 11:54 PM   #1
watcher in the sky
Member#: 3513
1997 Legacy Outback
Default surface rust and ways to get rid of ...
Hey Hey guys, I just bought a used midpipe for a VERY good price, and the rust on it, is not bad, just surface rust, nothing near having the famed holes in it at all. Well, i was wanting to know..
Could I take a sander and sand the rust off, or will that be just wasting my time? Because im going to paint it with high temp paint, and just think it would be better if i got all, or most of the rust off.
Also, one other Q. The muffler i ordered is here, but i need some slight modifications to get it to work , so you all dont think that there would be any issues if i went ahead and mounted the midpipe with the stock muffler do you? I know it will mount, but dont know about what kinda backpressure issues if any will arise, or just anything.
Thanks, didnt know where to put this.
Justin
watcher in the sky is offline   Reply With Quote
Old 04-24-2003, 12:45 AM   #2
nySulli
Member#: 32617
2008 STi
10% phosphoric acid and a small amount of rubbing will take the rust right off, or you can resort to using good old coke and a little rubbing, probably easier on both you and the exhaust, paint will hold very well to it, just remember to rinse off the coke
nySulli is offline   Reply With Quote
Old 04-24-2003, 08:19 AM   #3
bigdweeb
Member#: 31035
13 Ford Explorer
14 ISM STi
Yeah... I would remove the rust before painting it. You don't want to trap rust under paint if you can avoid it. If the corrosion is not arrested, there is a possibility it can continue under the paint and ruin your efforts to seal it.
bigdweeb is offline   Reply With Quote
Old 04-24-2003, 11:51 AM   #4
ScoobArmada
Member#: 12974
2005 STi
Whiter than Faded BRP
I had good luck with a metal polish called Noxon from Home Depot for like $5. It seems like a mild abrasive with lots of anmonia in it. Pulled surface rust off with some rubbing/scrubbing using some Noxon, a rag, and occasionally a scotchbrite pad. Probably depends on how much surface rust there is for how well this would work vs. a more heavy-duty approach of sanding.
ScoobArmada is offline   Reply With Quote
Old 04-24-2003, 01:17 PM   #5
watcher in the sky
Member#: 3513
1997 Legacy Outback
thanks alot!
Old 04-25-2003, 10:41 AM   #6
ImprezaVA
Member#: 32846
1998 Impreza L-SOLD
Arcadia Green
Default Rust
Exhaust pipes rust from the inside out, so, if there is rust on the outside then the inside is pretty much toast. This is what I always thought, but I'm just a noOb.
-Charles-
ImprezaVA is offline   Reply With Quote
Old 04-25-2003, 10:53 AM   #7
watcher in the sky
Member#: 3513
1997 Legacy Outback
actually, that is true.. if there is water/moisture stuck in there.
Anyways, the inside of this midpipe is just fine, no sign of rust, just black goop from common use .
FS: 02 WRX Rolling Shell, need to get rid of it!! Willing to Chop-up and Divide!!!! WRXtacy1 Complete Car Part-Out 34 10-10-2008 04:06 AM
can you tell me what this is? and how to get rid of it? rcebowl Newbies & FAQs 33 09-11-2008 03:34 PM
Best way to get rid of lots of flys Jumpy Off-Topic 26 09-12-2005 12:05 PM
Deep scratch in paint, best way to get rid of it? Prod Interior & Exterior Modification 13 07-28-2005 12:33 AM
When Win XP starts, it goes to the Welcome screen. Any way to get rid of that? Eric SS Off-Topic 10 11-11-2003 11:39 AM
