Old 04-24-2003, 12:28 PM   #1
Bunuel
Member#: 346
Default Any experience with 16" Steels?
I found these at discounttire and am thinking of getting them for my R-compound tires for racing and AutoX. Does anyone have any experience with these 16" steels? Will the stickiness of the R-compound be too much for the strength of the wheel? I am wondering about lateral stability and if the wheel will just bend or fold etc. As you can see I don't have much experience with a steel wheel. Except for the stocker that came on my 84 Cavalier which folded in half when I barely hit a curb with it.
Bunuel is offline   Reply With Quote
Old 04-24-2003, 01:58 PM   #2
ForceFed4
Member#: 7370
SGM
Well, at the risk of opening up an old firestorm, I strongly suggest that in addition to matching all the other specs (offset, bolt pattern, etc) you make sure they are hubcentric to the Subaru hubs. Last time I looked at discount tire's steelies, they weren't hubcentric to our cars.
As another note, if you're going to be using these for motorsports-type activities, you might want to look at lighter alternatives. Those steelies are going to be HEAVY. I know they're cheap @ ~$40/wheel, but if you're going to spring for the R compounds, you might as well maximize the advantage they'll give you. You might be able to find a set of 16" OEM wheels for about $300.
Or if you're able to spend more, you could buy some 17" wheels with decent (but not insane) tires for the street for around $1K and use your OEM wheels for the Rs.
I use 16" steelies for my winter tires; got them from TireRack. They are hubcentric also, but I don't know if they're designed to handle motorsports.
ForceFed4 is offline   Reply With Quote
Old 04-24-2003, 10:15 PM   #3
Bunuel
Member#: 346
So an O ring wouldn't work on the steels? Basically I just have the R compound tires sitting around and wanted to spend as little as possible to find something light and cheap to mount them on. Maybe I should look into an old set of stockers.
How much did your 16" steelies from the Rack weigh?
Old 04-25-2003, 12:06 AM   #4
ForceFed4
Member#: 7370
SGM
I've never put them on a scale, but they're definitely heavier than my OEM 16" wheels.
I mean, for the ~$120 the set will cost you it might be worth it to just get them and try them. Maybe test them at a lower-stress event at first, like an autoX to see if you get any vibration or funniness with the wheels before you take it to a true track event where you'd be taking it up to fast speeds.
Any PLC programmers in here, any experience with Opto 22 Optocontrol-Factory Floor??? Aaron'z 2.5RS Off-Topic 7 10-19-2007 06:10 PM
Any audiophiles have any experience with Digital Music Servers? Neek Off-Topic 10 02-16-2007 12:45 PM
Any of you guys know or have any experience with RX-8? Starscream Off-Topic 89 01-01-2007 08:48 AM
Any have any experience with MILITEC-1, a metal strengthener and oil additive? fengshui-fu Factory 2.0L Turbo Powertrain 16 03-12-2003 12:52 PM
Any Of you old dsm guys have any experience with the blitz boost controller? bill harvey New England Impreza Club Forum -- NESIC 0 01-19-2001 11:48 AM
Message Board Statistics All times are GMT -4. The time now is 09:46 AM.
